Originally posted by Michelinho
If you don't want to purchase a larger unit because of abusing and breaking a smaller unit, that is your choice, but it needs to be absolutely clear that it was the fact that you delivered 65 watts to a 45 watt unit that burnt it out and not a flaw or defect of the products.
The circuit and any soldering is only the highest of quality. With overloading it by 20 watts, the heat has to dissipate somewhere and that is the source of the problem - you will melt things.
With or without the resin, you will overhead and burn out the circuit if you're supplying 65 watts to a 45 watt unit. That is why it is rated as such.
Small fan is not necessary if you are within the rated input for the unit.
These charge controllers remain the finest in the world and they need to be operated within the rated power for each unit.
Solar 3 Amp 12 Volt Lead Acid - Tesla Chargers
