Low Drag Bedini SG with Low Drag Generator Coil
  • Low Drag Bedini SG with Low Drag Generator Coil
    I’m posting this SG machine because I believe this is the direction the bread crumb trail John Bedini left for us leads. My posts about the machine are provided in the link below. In that thread there is a lot of valuable information, it took years of archiving information and study to put it into this format so it can be explained in a way that makes sense. Jim Murray, Paul Babcock, Peter Lindemann, erfinder, Chris Sykes all point to this direction.
    This machine is the equivalent of the Kromrey generator, it uses the same magnetic fields I’m using.
    Dave Wing
    Here is a link to my first video I posted 5 months ago
      Here is another one with 70 percent real recovery. In vs out.
        Here is another video with 50 percent recovery.
          Here is a clip from Bearden about John Bedini’s machine…rotate one way it is positive rotate the other way it is negative.
          Here Bearden talks about John Bedini's machine warping one way it is positive warp the otherway it is negative.
            Here is the waveform produced counter clockwise vs clockwise.
              The only differences are the magnets are used on their sides, orthogonal and the coils a quite large with lots of turns on an iron core. The magnets repel the iron instead of attracting just like the Kromrey converter.
                This is another short from Energy From The Vacuum 6 where John draws out his asymmetrical waveform for a separate generator and then jumps right into the description of the motor waveform, which is the typical SG waveform we are all familiar with.
                This video clips shows John Bedini in the top left hand corner drawing a portion of the generator waveform, he does not complete the waveform or even call i...
                  Here is the image drawn of the generator waveform, spin the rotor counter clockwise the generated waveform is more positive than negative, spin the rotor counterclockwise and the generated waveform becomes more negative.
                    Here is the completed generator waveform…spin the rotor counter clockwise and get a more positive peak, spin the motor clockwise and get a more negative peak. This is the 1984 generator in John’s Book dc motor running in the SG circuit and a separate generator section using the magnets on their sides with only half wave rectification.
                    Remember John said that he combined the motor and generator, 1984 Free Energy Generator and or Watson machine into one unit called the SSG motor.
                      Here is the link for the dedicated thread on Overunity.com.
                      Self Looped Cap Dump Bedini Motor by Dave Wing
