Bedini RPX Sideband Generators
This is a sticky topic.
  • #31
    low frequency pumpwave
    Originally posted by marathonman View Post
    Yes, i do understand it and have collected all i can and i am telling you the output needs to be hooked up to an amp.
    there is no 8 hz wave and no the others are not carried on it.
    the audio wave modulated the 3.1, 3.3 or 3.8 carrier wave that caused upper and lower side bands.
    Rife machine's output 75 watts and was left there.
    audio signals can barely penetrate the skin let alone the cells that is why the high frequency carrier wave is necessary .
    read the part on skin penetration and you will understand.
    if you watch Bedini's video you will see a MOPA RF Amp he designed and used not the RPX because it has to little output to do anything.
    the number 5 Rife was designed by Hoiland to hide the original frequencies put out 75 watts RMS and 150 peak.
    MM
    You are incorrect.
    https://youtu.be/tsuwfGja1m4?t=17m45s
    It is all carried on a 8 cycle per second square wave and is why low power is all that is needed. You are misinformed.
    John shows and explains it in no uncertain terms here: Bedini RPX - Book & DVD Set
    RPX & MWO http://vril.io
    • #32
      marathonman banned
      At no time did Rife use a few watts of low power. even in the video of him using his machine did he not use low power. his bulbs he used would not even light with the power you are talking about let alone kick a virus butt.
      I laugh at the gullibility of people as his video's of him using his machine says the RPX won't work. not enough power.
      Marathonman is here for disinformation and will be banned. His attitude, mouth and lies are simply not going to be tolerated. There are no more chances for trolls.
      You obviously haven't the slightest clue as to what the technology is or how it works. You're a parrot chirping away what you think you know based on what you think you comprehended of what you've read.
      You're ignorant of the fact that almost all the power going into a tube setup is lost in the plasma creating heat. Only a fraction of that is transmitted RF.
      After the LOW FREQUENCY carrier is explained AFTER it is shown to him on the scope, he continues the deception that low power is ineffective without understanding how it works.
