Eric's "Crystal Radio Initiative" Challenge
  • Jeff Pearson
    CKLW is a 50,000 watt, Class B, AM radio station . Is this the station your trying to pick up and have you done any receiving yet LeeBob. The local station I built for only puts out a thousand watts. I think maybe I could do pretty good by taking it to town and connecting to a fire hydrant for ground.
  • LeeBob84
    Originally posted by Jeff Pearson View Post
    Also, there is about a thousand foot deep rift in the earth between here and town "Rio Grande Gorge" I wonder what that does to the ground signal. I'm gonna have to take it to the other side of the Gorge and do testing there also
    What is your ground?
  • LeeBob84
    CRI Update
    Woo Hoo I won the CRI
    Just want to throw out a special thanks to Aaron and Eric for the "Crystal Radio Initiative". It has been a time consuming build but very educational for me. Also a shout out to the annonymous donor of funds for the CRI Challenge. The funds are going to good use on the build.
    I have now finished the extra coilIMG_0719.jpg and have added a precision adjustor to my capacitorIMG_0717.jpg IMG_0718.jpg Lol. Crude but effective. This is the beast with the extra coil and new toploadIMG_0716.jpg. I have pounded my holes in the grounding and am just waiting to receive funds for the aluminum to fill themIMG_0720.jpg. I have also decided that instead of using the 4awg copper, i am going to dig a thin trench about 12" deep and pour aluminum between all holes. I will also be pouring an extra eight holes in addition to these in the same pattern only 10 feet out. Also connected the same way. I am hoping i can get about 200lbs+ of aluminum in the ground. This should be effective as a good grounding system for now.
  • Jeff Pearson
  • Jeff Pearson
    CRI coil for 1340Khz Kvot
    Corrected 1/4 wavelength= 142.25 ft.
    using .7752 correction factor. 102% velocity factor X 76% burden factor.
    I avoided all rounding till the end
    Length per turn= 85.35 inches
    At this point I figured for an octagon instead of a circle since my coil form is an octagon and I'm trying to be as accurate as possible so I calculated 10.67 inches per facet of octagon
    Diameter of circle would be 27.18 inches
    Height= 5.44 inches
    The tuning seems to be right on. With topload and ground connected I can hear the radio station clearly through a regular crystal detector consisting of a germanium diode, demodulation capacitor, load resistor and crystal earpiece. It makes noise but unintelligable with no ground or top load.
    At the moment the detector is connected across the secondary. I put together a simple amplifier using a LM386 IC driving a piezo element.
    With the amplifier 1340Khz comes in clear with the secondary connected to nothing. When I add the top load the signal gets a little bit stronger and when I connect the ground the signal gets a lot stronger. I have tuned it up to 1510Khz by tapping the top load at the 16th or 17th turn. And I have accidentally tuned it down to 950Khz by adding a long ground wire one day when I didn't want to carry it out to the ground rod.
    That's what I have done for testing so far. Oh and I did put a temporary primary on it with variable capacitor. There is a sweet spot where it raises the power of the secondary. Getting ready to rewind the whole thing. I am happy with the frame. More appropriate wire for the secondary and some 4 inch wide copper flashing for the primary coming soon.
    Great Looking coil Leebob.
  • LeeBob84
    CRI Update
    Did some calculating for my capacitor and have built a fairly crude looking but hopefully effective capacitor.IMG_0705.jpgIMG_0706.jpgIMG_0707.jpgIMG_0708.jpg The size of plates and how many is based on surface area of the secondary coil windings surface area. I calculated the surface area of the entire coil and adjusted my primary as well IMG_0709.jpgIMG_0710.jpg so that the surface area of all 3 components is within 100sq/in of eachother. This hopefully will cause the coil to resonate better. Also I have got the material now for the extra coil so I will be starting work on it next. This coil will be 1'6" tall and wide, it is a 1:1 ratio coil. Coil will be 90 turns with a wire length of 439'4" and close to 10awg so that is what i am going to use. Also I am changing my topload, The copper hemisphere I have built could possibly cause what looks like a dead short in the coil so i will be replacing it with 2 Toroids made from 6" aluminum foil ducting which will be capped with an insulator on each end to prevent this dead short in the coil.The big toroid will be around 3 ft in diameter and the smaller will be around 2 ft.
  • LeeBob84
    Did the calculations for this in January finally building it. 1340Khz. 3/4 inch tubing would be close to the ideal conductor but winding it with what I got right now. I think its 20awg
    Nice work
    So i guess there is someone else out there who is doing this.. I was beginning to think I was the only person working on this
    Best part is the way my neighbors look at this 5ft tall 4 ft diameter coil in my back yard. Some think its a chicken coop, some think its a fort for my kids, and I'm sure there are a few who think its some sort of ufo landing pad lol ... So far I have only met one person (in person, not on the net) who actually appreciates what this is actually designed for, and kinda understands what I'm talking about when I try to explain it, and he is an old military guy.
    Hope u keep posting updates here. Will be nice to have someone to bounce ideas off of who is building one too.
  • Jeff Pearson
    Did the calculations for this in January finally building it. 1340Khz. 1/8 inch tubing would be close to the ideal conductor but winding it with what I got right now. I think its 20awg
  • Aaron
    cri
    Originally posted by LeeBob84 View Post
    Wow that is awesome thanks Aaron.I have the primary and secondary windings wound, and have been trying to get a good ground system put in. I am living in a rental house at the moment so my original idea of digging four large holes with radiators buried in the yard is a no go. So i have come up with the idea of pounding holes about 4 to 6 feet deep with a 1 inch piece if pipe then removing the pipe, feeding a piece of 4 gauge copper wire to the bottom and pouring molten aluminum down the holes till they are full. I have finally completed mt foundry and poured about 3 pounds of aluminum in the first hole. My biggest hold up now is trying to come up with funds to buy scrap aluminum and fuel for my foundry. I figure that i will need a total of about 75 pounds of aluminum and probably 100lbs of propane to finish. Any Help with that would be more than appreciated. Also I am in need of a good adjustable capacitor for this project to.
    [ATTACH]17235[/ATTACH][ATTACH]17236[/ATTACH][ATTACH]17237[/ATTACH][ATTACH]17238[/ATTACH][ATTACH]17239[/ATTACH][ATTACH]17240[/ATTACH]
    Thanks again
    Let me know
    Please email me at info at emediapress dot com and copy and paste your message here to me - I can help.
  • LeeBob84
    The recording is on his site embedded as a youtube video.
    What do you need to finish your project in terms of parts and funds?
    Thanks again
    Let me know
  • Aaron
    Thanks Aaron,
    Unfortunatlly I missed that call with Eric, Where would I be able to listen to the recording of the call?
    One question I did want to ask him was about using a ribbon conductor supposed to the traditional round wire conductor and if there were significant differences calculating for it?
  • LeeBob84
    That's great LeeBob!
    If you have any questions for Eric, we have a live call tomorrow:
    This coming Sunday the 27th at 11AM Pacific Daylight Savings Time, we will be having a LIVE Q & A call with Eric Dollard.
    Conference Dial-in: 1-857-232-0155 and Conference Code: 582590 It will be recorded in case you cannot make the call.
    Thanks Aaron,
  • Aaron
    Live call with Eric
    I have been working on a large coil for the crystal radio initiative. This is a few pics of it
    [ATTACH]16937[/ATTACH]
    [ATTACH]16938[/ATTACH]
    Frequency : 800khz
    Coil diameter:4'10"
    Number of turns: 18
    Wire length : 247'
    Coil height:14.4"
    Wire diameter : 0.5"
    I made a hemisphere from copper pipe, with a 16 point aluminum star as my top load. All that is left is to bury my 4 a/c radiators as my ground, wrap a 12" by 2 turn secondary coil on the bottom and build my resonant capacitor. Hopefully I can tune it up to receive some usable energy. U can follow me https://youtu.be/HyRhUStqzt4 , https://youtu.be/jncwulYUpV4
  • LeeBob84
    Crystal radio initiative
    Frequency : 800khz
    Coil diameter:4'10"
    Number of turns: 18
    Wire length : 247'
    Coil height:14.4"
  • Aaron
    crystal radio initiative book updated
    Book for Crystal Radio Initiative page 20 & 21 has been corrected and is available at same download link.
