Peter, whatever happened with Eric P. Dollard?
This topic is closed.
This is a sticky topic.
  • Garrett's Posts Missing - NFG
    I'm not sure what NFG actually stands for - but the loss of Garrett's posts from this thread is definitely NFG
    Garrett, hope all is well with you.
    • NFG = No F***ing Good
      • Agreed, a SNAFU.
        Hopefully he returns.
        In other news...
        I built another set of coils for 4Mhz, It's the upper end of the amateur radio band and should prove to be more difficult to receive on. Although I'm not getting any 'sound' I did notice one thing of interest, with no circuit load there is little to no voltage potential, set up a load and the potential climbs. at the moment it'll fluctuate between .7~1 volt of potential between the ground plane and radial ground antenna. capacitance value is critical and I'm going to sit and see what I can calculate to tune this.
        The larger crystal set is awaiting wider copper strap at the moment.
        • Garrett ?? No ..Why ... uuggg.. Did anyone copy his post by chance?? you have been such a help in all this. What a shame hope you come back and all is well ...
          • I should clarify, this is AC voltage reading
            • Hmm I'm not sure where Garrett's posts went however if you're quick google cache is your friend
              Originally posted by Web000x View Post
              So you still think that the electrons are the source of electricity? Or do you believe there are lines of force, or aether, being the cause of electricity?
              You mean actually listen to and verify what Eric is saying Blasphemy!
              • he deleted his own posts
                Energetic Forum did NOT get hacked. Plenty of members have asked me so I'll post it here instead of replying to every personally. Garrettm4 deleted his own posts.
                RPX & MWO http://vril.io
                • Garrett4, Gone without a trace, almost!
                  Google Cache turned up nothing http://webcache.googleusercontent.co...p-dollard.html
                  Internet Archive "Waybackmachine" turned up nothing, latest search was May 2010. Garrett joined August 2011. http://web.archive.org/web/201005220...p-dollard.html
                  But Energetic Forum still has 37 Quoted Posts when you do a Thread Search for "Garrettm4".
                  http://www.energeticforum.com/search...earchid=598383
                  Have fun
                  Mike
                  • Primary/Secondary Assembly Iteration #1
                    Secondary: Roughly 24 turns of RG316 (L-com.com) on 13.74 inch diameter form, with wire spacing 0.120".
                    Primary: 1.5" wide Georgia Copper (2.71 grams/in specific weight), 1 turn on 13.74 in diameter, and ending with an additonal 3/16 turn on 13.24 inch diameter.
                    Center frequency: Theoretical 1.87Mhz, Measured 1.6Mhz, which just barely enters the AM band.
                    Test setup for measuring center frequency:
                    Input: 2.8V pk, sinusoid, 1.6Mhz, from a 50 ohm input impedance function generator source connected directly to the primary loop with mini-grabber test clips.
                    Output: 174V pk, sinusoid, with oscilloscope probe shunted directly across secondary. Probe is a 60Mhz bandwidth, 46 pF input capacitance, 10Meg ohm input resistance, cheapo ebay special, using a Tektronix TDS210 oscillscope. Secondary is very senstive and output characteristics change with objects moving 6-8 inches and closer to the coil.
                    I do have a basic python script for calculations, some emc2 g-code files for router manufacturing, conductor empirical measurements, and other associated files if anyone would like to use/modify.
                    • new thread for continuation
                      Please continue this thread here:
                      http://www.energeticforum.com/renewa...p-dollard.html
                      This thread is being closed to prevent any more posts from being deleted.
                      NOTE: All of Garrettm4's posts in this thread have been recovered.
