i was "maybe" a bit too fast in my speculation so ill give it a try , ill do your experiment this week and ill post result, good or bad, i have a decent lab and a bit of time to work on it but ill keep it the way it should be , all the calculation that fit the "normal way" and ill compare the result against it.
Best Regards,
EgmQC
Thanks, this is the spirit I like. Instead of wasting meaningless words the truth should be uncovered through experimentation and an open mind.
Originally posted by LtBolo
Well, we ran it. It works.
There are some caveats, however. As predicted by the formula, the output current increases geometrically, which means the magnetic field is also increasing geometrically. Unfortunately, the high magnetic field causes our motor shaft to pull in, which causes our 030" gap to close loudly...metal on metal. We do see the motor current increase a bit due to the lateral shaft force, but we don't think that the increase in motor load matches the amount of output. Unfortunately, until we can get a better mechanical arrangement, it will be impossible to verify that there isn't an equivalent load on the motor. Of course, once the core pieces start hitting each other, the motor draws far more current still...and it gets loud.
That said, it works exactly as predicted. We managed to get it stable at about 100VAC for a while. At 100VAC, we measured about 1.8 watts of dissipation across a 1.5 ohm resistor, as well as about another watt in one of our caps that was breaking down. That cap was a mistake, but it worked out well...it became the non-linear load that kept it all stable. This agreed very well with the predicted 2.5 to 3 watts of excess power at 1 amp.
Note the scopeshot: This is the output going critical. I pulled the wire to shut it down. Note that it hit 381vpp before I pulled the plug. Obviously it showed no signs of slowing down, and the current was well above 1 amp at that point, but we had no way of measuring.
I think this is the real deal...
Good work LtBolo. I'm curious, is this an AC motor? If so at what frequency was it running? The point I'm getting at is that closing the loop might be a simple task if the motor is running at the same frequency as the output. That is if the output is regulated first.
Variable frequency drive, running at about 65-66Hz. We are limited to about 71Hz max speed by the drive and motor, so we picked caps to be near the top of the range.
We are rebuilding now to eliminate the lateral force on the motor, and then will determine whether this is simply loading on the motor with no free power...or free power. Either way, we have conclusively proven that you can generate power via synchronous parameter change...pretty amazing.
Not sure how we'll regulate. The Russian paper talked about using non-linear loads like incandescent bulbs, so we may go that route for power evaluation. Once we have proven that the power isn't simply from the motor, we'll look at an electronic closed loop control.
I have a question: what kind of metal you use for the rotor?
It is just a piece of transformer core material, same as the rest of it...actually it was cut from the same transformer. We attached it to an aluminum cylinder to mount to the motor.
Once I wrapped my head around synchronous parameter change, it started to become pretty obvious that many of the devices that people have been playing with for decades could potentially work. The problem is that until you evaluate the expected power gain against the power loss, you don't know what you are looking for.
I think the other issue than many face is that according to Dollard, you can either add or remove energy dependent on phase. I think that many of the solid state approaches are doing it exactly backwards. It would be very interesting to do a thermal analysis in a resonant saturated core setup. I would speculate that there is some energy missing in many cases.
Our device sits on the edge of working/not working...we don't have quite enough inductance change...probably could use another 200 turns on the coil. From our experience, when the parameters aren't quite right, you get nothing. When you get them right, however, hold on to your hat!
We are still struggling to evaluate input to output power ratio. When the current gets very high, the magnetic stresses get very high, and we keep having mechanical problems. When you are grinding metal off of the core, it becomes very difficult to evaluate whether you are getting more out than in. We are making another mechanical change now, and hopefully that will be enough. If not, we may have to scrap this one and build it right. I really didn't want to spend the money and time until we were convinced this isn't simply a 1:1 generator.
Strange. In trying to get the mechanical stable, we moved the rotor to the inside of the 'C'. This reduced the inductance, but still worked. It also appeared to saturate the core and limit the output. So we added about 200 more turns and increased the inductance to something higher than it was before. Now the output barely resonates, only showing about a volt or so at resonance.
Weird thing is that it still gets loud and the motor definitely loads...increases current by about 1.5amps....and...the rotor gets smoking hot, although nothing is touching now. It appears that there are eddy currents in the rotor that are causing the loading.
So, parameter change will induce power and Lenz still lives. The Russian paper used aluminum for the rotor. Guess I know why now.
Just a brief thought. Maybe you have accidentally hit the spot where energy "disappears". It can only be assumed that this would coincide with heat but might not be measurable, if you compare it to energy creation as in negative energy entering the system which is supposedly always cooling the components.
So maybe there is a sweetspot in your device that would in fact create energy and you are just tuned to the "bitterspot" right now.
All just speculation, and maybe i am just wrong. If this was any kind of other motor without inductance variation, it could certainly just be attributed to friction.
You will improve this eventually.
Big respect to your hard experimental work, many people appreciate it.
Keep it up!
That's a good thought, but I'm pretty sure the rotor is getting very hot due to eddy currents and I'm pretty sure we aren't losing any power. In an effort to fix the rotor stability problems, we welded the plates together. Not so sure that was a good idea.
Regardless, I'm 90% convinced that the rotor is loading the motor because of eddy currents, and whether it loads due to the extra power generated will be impossible to tell until we eliminate them. We'll get there.
Jury is still out.
yes, I agree.
Maldestam used a rotor of aluminum (or copper). The distance between pairs of coils was 5 mm and the thickness of the rotor was 3 mm. He used a rotor of iron and did not work (no excitement, too many losses due of eddy currents). (from the russian original paper)
Bedini pointed out that the Kromrey converter would also need a non-magnetic shaft. He explained it that the magnetic loop would be diverted into the shaft (if it is magnetic) and thereby could not complete the entire circle.
So in any way LtBolo will be probably be able to eliminate the detrimental effects by using an aluminum shaft.
Do you have an English copy of the original 1934 paper? I do not, other than the few paragraphs that Fred Epps quoted on Naudin's site. I do have the English translation of the later paper paper he did, but would really like to have the original.
