Time travel
  • Time travel
    Good morning
    I just finished "A Connecticut Yankee in King Author's Court" I also started reading "1632"(an excellent book!!), which got me to thinking....
    I know this may not be germaine to this forum, but I also know most members are very knowledgable and like to delve deep into all matters scientific, so I thought I would ask the question....
    Is time travel possible? And if so how would it work?
    Just curious
    Bizzy
    44
    NO!
    22.73%
    10
    YES!
    65.91%
    29
    MAYBE!?!?
    11.36%
    5
    Smile it doesn't hurt!
    Jesus said,"...all things are possible through God." Mk10:27
    From some recent articles I read it appears the human mind can predict events or see them before they happen. This would be proof that time isn't linear, and could possibly be traveled through in any direction maybe by taking shortcuts across the curves?
    I'm a maybe guy on this one..
      Here we go, time to theorise, or theorize, depending on inbuilt spell checker !
      What is inbuilt is total to the understanding of time, be that internal to a PC in its software, or within ourselves.
      Is time linear ? does it march forward predictably, does it stop, reverse, forward and yet is never seen or understood for those effects.
      Time is our creation.
      If you take note of the time now and take note after I finish wittering, you may expect the amount read to correspond with time passed - and so that time will have passed.
      Apparently watches slow down for astronauts. Apparently time does go faster for those enjoying themselves than someone bored skull-less.
      Time, in my opinion, has been chained to expectation - whatever we do in our lives follows our expectations. We make our own future by the thoughts we have, we also experience time in that way.
      'Time flies when youre having fun' - quite.
      IF Bearden and Bedini are correct, we harness a reversal of time within pulse motors. The energies flip time in such a way that a circuit will run cold, it is reversing or opposing exactly oppositely the effects of time moving forwards. The extra electrons bounce into our space time and reverse heat for one thing, circuits run cold.
      Electrons are themselves, before they were in our space time - that's where we get those extras from. They're not extra, they are the same ones, in a previous state, which is why they bounce in and out only at critical moments
      Opposites, what are they ?
      A dead battery returns to life, a hot transistor goes cold. When linked with natural magnetism states of matter and man made artificial magnetism, we can experience opposite gravitational effects. This has implications for writings within faiths, so I won't get into it.
      Now, if we put an object within the fields that are generated by the forces, we may expect the object within to experience time reversal.
      A time machine, a way of going backwards, oppositely to the forward perceived time that we daily experience.
      Imagine now an experiment that is intended to show time travel backwards.
      When you start the machine, the effects are difficult to measure. Why ? because BEFORE the experiment began, there were no readings
      We hear that when properly constructed a Bedini type circuit will have a flat zero of result...an equating out of parameters that produce, well, nothing. That's the correct result, because we're trying to take measurements of before the experiment began !
      Forward time travel ?
      Take that well performing Bedini circuit and link to another same circuit running along side. Feed the collected energies of the first into the second to FLIP the resultant 'extra' electrons again when we produce negative energy from the second circuit. Now, the readings may be forward of their original values. We may see 4 electrons, a doubling of the reversed and the forward electrons. Chain such units up to move around time in a predictable way.
      Use what would amount to a variable Darlington cascade to move through time.
      Twaddle ? probably
        fluid
        Hi Mark,
        Your explaination has much merrit and deserves some more thought I recall a movie about Tesla also explaining about alternators harvesting energy in the opposite flow of time or opposite the passing of the rotor over the stator...
        I always thought of time as being fluid, in that it is constantly flowing forward. But just as you can use a boat to travel on water either up stream or down stream so too can a person travel on time, either against the flow or faster than the flow. Thus we would simply need a "time boat"
        Bizzy
          Hi Dougyt
          A good point, a freind of mine also mentioned that once as well although he also thought that just becuase our minds could travel through time doesnt mean our bodies could. But you are right it does show that time is not linear or at best can atleast be traversted in some way.
          Bizzy
            Just for the record here is a link to the article I read in Fortean times about Precognition experiments. The experiment used sexual images so the title may set off some filters
            Precognition and Porn | Science | Fortean Times
              All matter has memory
              This is not exactly time travel, but I have to say that it has been proven several times that matter has memory, at least acoustic. When you play something, speak or make some noise, the matter has a natural mechanism to record that acoustic phenomenon.
              That acoustic information can be played again if you know the exact date when it happened. The basic mechanism doesn't seems to be very complex. It works similar to a tape recorder. A tape recorder sends information throught a magnetic field and the tape aligns the charges. When you playback the info, the electromagnet of the recorder can read the information of the tape and after amplyfing the signal, you can hear it.
              To recover information from physical objects you need to do something similar.
              With an air-core coil, you send a scalar pulse to the matter. After applying the pulse, you get a backward pulse (an echo). In that echo, the information that is naturally stored in matter is sent you back. The other step is to look at "specific points" of that echo in the oscilloscope and you can playback the information. The thing I don't know how it's done is how you select the time you want to read. The man used a function generator. That is the only thing I know. A lot of cultures speak about the Akashic Records.
              You know there is a "background radiation" in the universe and is sure that the acoustic and luminic information is stored there. I don't know if time travel could be a reality, but the thing I know is that past events can be seen again!!
              Someone want to start experimenting in that?? Only for fun.
                Being as i've run out of storage space on the forum, i've started using Photobucket again...a pic on there relates to your thoughts AetherScientist.
                Here's wacky - I myself seem to have been a ghost at one point !
                We can become ghosts, without passing along to the other realms...environment memory is similar to how you describe.
                Here's the pic:
                i wish it were larger, but Photobucket seems to have chopped the size.
                Here's the back story.
                My wife and I met on a paranormal interests board. At the time I was researching with Jackie and Christine, who later went on to host Rescue Mediums on TV. My wife had a possible odd few things going on and posted a video of something going on in her house. She was attacked viciously by idiots on the board and I came to her rescue, berating the trolls. She thanked me, we emailed more, she visited the UK, I came over to the USA for Thanksgiving that year...etc etc...we're now married
                Long story short, we lived at her house in MN til moving to OK.
                In the garage i'd put my arcade machines, salvaged, repaired, worked on to bring back from tattered rubbish and lots of learning as a hobby too. We had put webcams around the house and 1 in the garage...for a security measure and because they were $20 from a thrift shop ! But of course, just in case anything paranormal happened again and ran a live stream online through Ustream.tv
                During the summer of 2007 there was an informal very fun contest going on between a few of us arcade game collectors and the mission was to complete OutRun.
                I'd never completed a game before and all of that summer I edged nearer and nearer to the finish line with each night spent on the machine... when that car roared over the finish line I was completely overjoyed and ecstatic !!!
                So much so, that someone watching the cameras caught a very odd picture a couple of days later.
                The picture above shows me in the middle of the shot, reaching up to place a flourescent in one of the machines...BUT...it also shows me playing the driving game behind, reflected in the mirror !!!!
                You can see me stood there in light jeans, dark shirt, arms forward onto the steering wheel.
                It would seem that I energy dumped into the surrounding area at the point I completed the game.
                My theory is that time travel in such ways was a normal everyday experience in Stone Age times. Places where tribe hunters had been attacked or other strong events had happened, would forever be indicated by such energy dumps and picked up upon in future expeditions.
                Psychic seeings would be received by those back at the living area, an ability we have almost completely lost.
                  The mechanism for the USS Eldridge is right in front of us, when we view a pic of her.
                  See that middle mast ?
                  See the round thing up near the top ?
                  That's a Muller generator right there
                    Time travel is definitely possible. Haven't you seen back to the future? All we need is the flux capacitor.
                      Time is a measure of periocity, we are travelling through time right now, it is impossible to "not" travel through time because then time would stand still and nothing would function in any way, at such point everything would cease to exsist, which cannot happen, fortunately.
                      It is possibile people have misstook other effects of energy and matter exchange as "time travel" however it would be more like a change in the state of matter to or from energy and a change in mass and soforth, I can imagine these things would appear to be "time travel" and if one was to be temporarily changed to a different state of Matter it would have serious effects on the person, ranging from death of the body to scrambling of the brains and some of the things said to have been seen in the ship experiment would indicate some problems when the people were released from the temporary change of the state of the matter making up thier bodies.
                      One question I must ask though is.
                      Is our mind or are our thoughts "Matter" or are our thoughts and mind pure energy ?
                        Hi Farmhand,
                        That is a great question, becuase if it is sure pure energy than we can certainly transport it we just need to find the method or medium to do it. I recall reading that Nikola Tesla was devising a machine that could record thoughts, which would give way to the idea that brain wave or thoughts are something that can be transmitted/recorded. And if that is the case then we could possably go back in time or forward in time.
                        The other possability is that if it is energy and we can traverse time, it may very well be that we can but only as observors not participants. In other words God may have a built insafe guard in time so that we can observe different times while we physically dwell in our present time, but not influence and change the other time. (which kind of ruins my time vacation plans )
                        Clarivoiance(sp) or deja vue could very well be proof of that ability.
                        Bizzy
                          I am sure time travel will be possible. It will happen through use of our own dormant mental power. No machines Necessary.
                          • #14
                            The concern here: The Anderson Institute does not seem to be whether it is possible or not but that we need to keep it from destroying us as he says a number of countries and elite few already have the capability and that laws need to be made to prevent rogue individuals or countries from altering things in a possible catastrophic way. He seems to have very good credentials too.
                            • #15
                              If people could travel to the future, why on Earth would they come back to the present ? Or more to the point, to go to the future and then come back would involve both forward and reverse travel in time, which would also mean that just going back in time would also possible and staying there aswell, also going to the future and staying there.
                              A period of time that has not yet passed cannot be interacted with, just think of it this way. What would happen if everybody on the planet went forward in time 5 years ? What would happen to the 5 years in between ?
                              Would there be a space in time of 5 years when no humans inhabited the planet then all of a suddenly after that five years everybody is there again ?
                              Or would that 5 years just not happen for all the other animals on the planet and we just skip time.
                              Traveling through time is impossible, only the peception of time slowing or speeding up is possible.
                              There is no time like the present. There is only one way to travel through time and thats the way we are doing it now.
