Originally posted by pault
The key is how to mix them.
If you have what I have then whats happening is you fire the motor. The energy you fire go's to ground. Then windings pass the magnets in one direction and make a pulse they turn 180 degrees and pulse again. This creates somewhat of a sine wave on the scope.
Now if you want to add amperage from another source the output of the generator that makes it has to make it in the same time frame or all the time.
All the time is going to drag the motor down unless you use a means that does not hinder your mechanical energy via Lenz. (*We'll get back to this)
The 2 sources of power also do not need to mix within the source. IE...2 batteries in serial are a mix in the source..
You can accomplish this by adding an equal bridge rectifier to the output of both the generator and the motor. Then you serialize the 2 bridges. This keep each power source independent of each other. But the power accumulates.
So if the motor is dumping 100 volt at .01 amp and the generator at the same time is dumping 2 volt at 4 amp, granted they do it in the same time frame, and you serialize the outputs (NOT COUNTING DIODE LOSS) you have have 102 volt at 4.1 amps.
Just like 2 batteries in serial.
So you need to test to prove to yourself this can happen. But you do not have a low drag generator YET.
*So now all you need is a relatively low drag, low voltage, high to mid amperage generator.
We have several options. I have tested 3 options and only one is looking like a candidate at this time. But I have 2 tests slated when I get the time and money before I settle on anything particular. 1 test was 2 coils wound with heavy wire, 2 magnets, ect.... It didn't work. The second test was homopolar generator. It bogged down to much.
The third test which is a candidate was N machine type assembly, it actually put out a small amount of amperage and did not bog down the dremel tool I ran it on very bad. We have to test larger magnets and better brush assembly. Peter also said this machine had some problems. So I am not counting on it 100% till I see the marriage of the motor and generator actually work together.
The next test though I am going to do, is to try and inductive style generator with no magnets. And this is where some of you might be able to help if you have the time. I am not promising results, but it needs to be looked at.
The output of the motor could be discharged through a set of coils on a rotor to create a magnetic field. This field in turn could be used to generate a low voltage high amperage pulse on a coil and the stator. Then both could be output at the same time.
This allows for several possibilities. We could store the output of the motor. Then put the charge we're storing to the gen.rotor coil while the motor is ON. So that we can negate the small amount of Lenz that will be present at the time we generate.
We can also use the gen.rotor coil to step up the output voltage to above the motor input voltage. So we have a higher potential when we finally collect the power. Everything will be separate when leaving the generator and can be collected separately or as described above.
Now I have background info to base this test on, in fact its so much that I cannot possibly write it all down.
I will make up an slide show of images or some pseudo schematic to help someone along if anybody else is willing to test this.
I DO NOT HAVE specifics for windings to regauge the magnetic fields into the power structure that is needed. I have been reading alot and I have some idea of how to do it, and I am sure Peter could answer a few of the specific questions as to where to start or where to look for the info.
I know its good test a good place to look.
The fifth test I have slated someone else gave me at first it didn't interest me but then I decided it might be worth looking at. But I am not going share it as its not mine.
I know this direction will lead to something good. I do not have a working prototype and if I DID I would not give it away in the open in light of some peoples behavior when it comes to PROFIT and CREDIT. I have only done tests to see if going further in this direction is the right thing to do. But everything I have done leads me to believe this is going to work if done correctly, with the correct apparatus.
So there it is. Take it or leave it. I'll be moving forward with this as time and money allows. How about YOU????
Your probably going to need more detail to understand what I am saying. And I home today so please ask away. And I'll work on some drawing to help explain.
