Lockridge Device - Peter Lindemann
  • With my setup, you don't need diodes in the rotor. I tried to figure out how to do the same with power brushes 180 degrees apart as Peter suggested, but jumpers would not work in that type of configuration. You need to put diodes as Matt found out, because when the rotor rotates 180 degrees after the pulse, the polarity changes causing a lockup (attraction) condition. So you can only pulse once per rev, requiring the need for larger commutator segments to get past the magnets. The small segments in the 20 pole rotor needs to be doubled up as Matt said earlier. Or you can do what I did and put the power brushes 90 degrees apart.
    Brian
    • Sorry Guys
      Hi folks,
      Sorry for the problems. I had figured this out for a two pole stator and simple windings. When you guys started showing these four pole stator motors, I thought I had figured out how to modify them to my idea, but apparently I hadn't quite figured it out.
      It seems that Brian's brush placement and commutator set-up does make the motor work, but it doesn't give the windings sufficient OFF TIME to cool off when we crank up the power. So other problems will show up later.
      I will think this through again and see if I can come up with a winding that will work for these four pole stator systems.
      Peter
      Peter Lindemann, D.Sc.
      • Same situation
        Brian
        Although I abandoned the idea of using the fan motor I was working on for a
        Lockridge type setup, I experienced this same lockup condition. By pulsing less
        the motor operated in a correct fashion.
        FRC
        • 2 pulses per rev
          I've figured out how to pulse twice per rev a 4 stator pole motor like what Matt, Mark, and I have. This should satisfy all of Peter's criteria. Not only will it pulse twice per rev but it will have that cooling time the motor needs, and also no need for diodes in the rotor. All you need to do is offset the power brushes from 180 degrees to say 135 degrees. Then place the recovery brushes half to one commutator segment ahead of the power brushes. I like half because it ensures that you fully capture the spikes. It would also be good to double up on the segments. The diodes outside the motor prevents "feeding" the charge battery with input power. The second part of trick is to place the contact points and jumpers on the commutator segments in a way so that it will pulse the armature coil one way during the two contacts per rev, and put jumpers between the segments in the right place. Kind of like what I did with my 4 pulse per rev setup. When you see my diagram, it should make more sense.
          Brian
          • Well I got it going.
            I haven't moved the recovery brush's yet, I left them at 90 deg.
            I used 2 commutator sections as one was almost 2 weak to get it to flip. Also 2 sections was just about right for recovery.
            But with the incoming power unhooked to the recovery, the recovery is next to nothing. 6.4 volt AC. And as soon as you pull a load off of it, it bogs down. So its only generated voltage.
            I think 4 traditional coils wound with 1 wire, N-S-N-S, is probably going to give the most power. 2 pulses per revolution.
            Your also going to need to hit recovery point while the power is on so you get the step up action out of the coil.
            It would work and recover just like my simple motor. No heat and high amp recovery.
            IMHO
            Matt
            • I was thinking most of the night and agree with you Matt. I'm going to wind 4 coils with 1 wire. I'll wind each coil on 4 sections of my 20 section rotor so I can maximize the size of each coil and use 2 sections of the commutator for the winding ends.
              What a headache! Time to go unwind and start over. My fingers are raw from all the time I spent last night spining the rotor shaft and trying to adjust the timing. Not to mention all the cursing that was involved .
              • Well I unwraped my rotor and wound the first coil. Now I'm totally confused again as to how to wind the coils. I thought I'd just wind 2 to start with across from each other get that going and add 2 more in parallel. I had taken a piece of solder and wound it around a pen to look at how to wind it but now I dont think you can wind 2 coils across from each other and turn it 180 degrees and and fire it again, I think it will just lock up!
                • Very Interested
                  Brian
                  Brian,
                  I am very interested to see what you have come up with.
                  Peter
                  • Originally posted by Peter Lindemann View Post
                    Brian,
                    Peter
                    Peter,
                    Here's what I was talking about from my previous post. I don't see any problems with it working.
                    Brian
                    • Originally posted by Mark View Post
                      Here's an even cheaper motor that appears to be a 2 pole (only has 2 bolts) but doesn't give a lot on info on:
                      12 VDC MOTOR | AllElectronics.com
                      I, too, have two of these from Princess Auto.
                      I disassembled one last night. The two immediate issues I see are:
                      1) The windings appear to be glued. Initial prodding with a screwdriver makes it seem that the windings are rock solid and may need to be destroyed during removal.
                      2) It has only two brushes, with an external spring, which uses up realestate and might (or might not) make it tricky to place the 2nd set in just the right place. If I can't find similar brushes at a motor supply house, I'm going to have to scavenge them from a 2nd motor (rendering it useless). The brush mounting board is cut down and not big enough to hold 4 brushes, so it will probably need to be replaced.
                      @Peter - What is the plan for when we get to the generator step? Am I going to need a 3rd one of these exact same motors to act as the generator (if I scavenge from the 2nd)? There were only 4 left at P.A., I should go back soon if I need the same kind.
                      @anyone - Will I need 6 12V batteries for this test (3 and 3)? Any tricks for economizing in this department?
                      @Kyle and other Princess Auto-ans: p.m. me, let's see if we shop at the same place and if we wish to collaborate.
                      thanks
                      pt
                      • Originally posted by pault View Post
                        thanks
                        pt
                        pt,
                        I'm interested in this motor. Would it be possible to take a picture of the brush assembly? Maybe I can use the brushes from my current motor for the recovery and do some grinding on the end cover.
                        I would prefer a 12V motor because my 24V motor would require 72V, and this one only 36V plus it's cheaper.
                        Brian
                        • Originally posted by n84dafun View Post
                          I'm interested in this motor. Would it be possible to take a picture of the brush assembly? ...
                          I can post some pics tonight, but in the meantime, Kyle posted a youtube in message #238. He shows the brush assembly at 1:36.
                          Here's the direct link:
                          YouTube - 12volt DC motor - Bedini Mod?
                            Pt,
                            Thanks for the YouTube link. I think the video gave a pretty good picture of the brush assembly. That looks like the perfect motor for this project.
                            Brian
                            • Princess Auto motor
                              That motor is Princess Auto part no. 8366916.
                              I spoke to a guy at an electric motor shop. He doesn't stock anything less than 90V and the brushes for those motors wouldn't be compatible with this one. He did mention that there is a place nearby that will custom-make brushes for $100 min. order.
                              He said that I might find brushes at an automotive electric supply, but couldn't suggest one.
                              The windings are coated with baked-on varnish. He said that it might be possible to use heat to melt or burn the varnish off, otherwise I'd have to destroy the windings to take them off.
                              pt
                              • Remarkably Cleaver!!!!
                                Peter,
                                Brian
                                Brian,
                                This is awesome. I think you are correct. It looks like it will work. This is a remarkably cleaver solution. I look forward to the successful tests.
                                Peter
