Pavel Generator
  • Pavel Generator
    Credit: https://commons.wikimedia.org/wiki/F..._schematic.svg
    This is shared under the creative commons license indicated on the link above.
    The motor shown in the very first picture is NOT the motor modified in the pictures. But it is very similar and meets the same specifications. The part number is shown so that those interested can order it and build the device as I am doing.
    This has been run on a SIMULATOR recently. I have NO INFORMATION about the original build, only simulator results.
    Motor data.jpg Motor Circuit.png Motor for modification1.png Motor Modifications.png
    David
    long time ….
    thanks for starting an open source topic on a very interesting claim!
    sharing the news …
    https://overunity.com/19341/pavel-ge...tempt/new/#new
    The world desperately needs an open source breakthrough !
    respectfully
    Chet
    BE that change !!
      More info from a source...
      At the time I wrote this, I imagined the possibility of using a crystal radio style of circuitry supplementing the use of a mere whip antenna. But Bob reminded me of the use of a living tree instead of an aerial.
      In any case, an elevated current will be drawn through this circuitry while the radio is intended to deliver a single frequency which it "tunes", ie. selects, from what is available in the environment. And now that I think about it, that won't deliver 2.6V unless a solar panel replaces the whip antenna. But it'll probably have to be a whole bunch of solar panels linked in parallel to handle the increased strain of current drawn from and through them. The circuit makes this demand upon them while they have to supply it due to the magnetic coupling among the coils, the low resistance wire used along the pathway of the smaller coils and the intentionally increased resistance placed inline with the larger coils. This creates a shorted step-up and simultaneous step-down transformer such as what Pavel had demonstrated, but puts it to use as a circuit which boosts the demand that it makes upon a conventional source of voltage which, in this case, are sources of medium rate of sine wave frequencies. This is not intended to rotate the motor unless the standard arrangement (expectation) of coils in a motor is replaced with something which can handle such elevated frequencies and still provide for rotation. Tesla provided for this and then Alexanderson (his assistant) went and patented his own version.
        Last edited by bistander; 02-05-2023, 09:34 PM. Reason: No need to play childish games
