  • schemk.png - Speedy Share - upload your files here were mf if uF
      Mr Clean
      Can you replicate experiment with low voltage setup like ferrite core transformer ? You have so nice frequency generator the only missing would be also nice scope with integrating power function.... Unfortunately I haven't any of them , but if you or somebody has such tools and is willing to do experiment with all disclosure in video available for us here then I would have something important to test ....
      hmm i assume so, but as oldscientist has said, there is something about high voltage that makes it work, most likely to try to get rid of the current for obvious reasons.
      and actually all my stuff is broken at the moment ( dont keep your scope next to the coils)
      this recent magnifier experimenting has really wrecked all my nice modern goodies, so beware, all you can do is run hardcore loads, or observe field intensity by proximity with a one end grounded neon
      i want to run my DC centertap Mazzili circuit, to do self- run experiments, but the is a tremendous skin effect all over the circuit, and its hurting the battery
      -Shunryu Suzuki
      • Originally posted by Gedfire View Post
        Hi WorkshopElf,
        Wow!
        I watched the Energy Propagation Video.Thanks for that:
        Energy Propagation - YouTube
        May I humbly suggest trying resonant multiple secondaries? You know the idea is to prove Don's postulations that multiple tuned secondaries (when properly tuned) will not load the L1 tank at all.Then the magic is to feedback from one or two of those resonant secondaries to the power source for self sustaining action.
        What do you think?
        Ged
        ...and I haven't done it yet, but here would be your multiple tuned remote secondaries you were wondering about.
        which I am note entirely sure would be OU, but anyway
        and one problem is, in the video he uses LEDs, they are components, not a load
        smit1 - YouTube
        -Shunryu Suzuki
        • Hendershot
          Thank you a lot Dunfasto,
          Yess very impressive the Hendershot device, it really looks like it is possible, I believe it .. here the 2 and half hour video.
          We ordered some Litz wire and we will be doing our best to continue our project. We are very happy with your answers.
          Utopia Now.
          • Originally posted by dunfasto View Post
            Hi Utopia!
            see this HENDERSHOT IN ACTION
            Generador sin combustible Hendershot - YouTube
            REGARDING YOUR QUESTIONS FABRICE ANDRE
            L1 coil is of litz wire filo litz is italian company making that wire which has no skin effect. you can use any litz wire. its simple coil to which spark is connected
            L2 coil is caduceus coil thru which 50 hz signal is induced
            L3 coil is simple coil for output
            L4 is single turn copper tube. you can try alluminium also
            every coil one end is connected to earth
            yes ferrite rings make difference in tunning. high permeability ferrite helps in faster tuning.
            the ferrites must be placed at three places of 3 rings as two sets at the ends of tube and one set in the middle of tube on which coils are wound
            000 000 000
            yes L1 coil must be resonant with L2(caduceus)
            connect pf capacitors hv like chubinidze to your Hv + and cold ened to earth So L1 is oscillating. Adjust L4 that is copper tube to tune L1 to L2.
            magnets are used to get resonance in a quick way otherwise it will take time for you to find the sweet spot.
            try filter caps at output to test the energy generation otherwise not needed in output.
            dunfasto
            Hi,
            Which sheme is this?
            L1 should be HV
            L2 output
            L3 50Hz
            L4 ?????
            What magnets, where?
            Do you have some photos of this L4 or the complete coil?
            Thanks in advance.
            editor
            • Schematic editor`s questions
              Hallo Editor,
              The schematic is from Fabrice. If you go back a few posts on this page 328, there are 2 post in which there is a lot of info. post 9821 and post 9825
              Yes L1 is HV ... L2 and L3 maybe are mixed up by Dunfasto, maybe.
              L4 could be the copper piece inside L1 ... in this thread ( Chubinidze coil ) is info about a single turn copper tube.
              Utopia Now
                Hallo Editor,
                Utopia Now
                Hi Utopia Now and thanks for your help.
                editor
                  Hi Utopia!
                  000 000 000
                  dunfasto
                  Hi Dunfasto.
                  Basicly I have all the hardware to finish the device.
                  I did check the red sun pdf and I did't find any L4.
                  If I understand correctly it is copper ( oxide) tube with the gap,
                  how is connected and where is physically located. Can you draw on the pic where is it.
                  I will apreciate any additional help. Seams you have a lot of
                  knolege of the fabrice device.
                  regards, editor
                    Utopia Now.
                    http://www.energeticforum.com/renewa...tml#post234818
                    • Originally posted by editor View Post
                      Hi Dunfasto.
                      regards, editor
                      Hi Editor!
                      here you go!
                      see the image attached with everything.
                      use litz wire for L1 coil. and for output and input use thicker wire for amps
                      see fabrice andre pdf also.
                      MAINTAIN RESONANCE BETWEEN L1 AND OUTPUT COIL. L2
                      DUNFASTO
                      • don smith overunity circuit air core
                        For all
                        dunfasto
                          Hi Editor!
                          here you go!
                          DUNFASTO
                          Thanks Dunfasto, I will assemble the coil and see if I will get lucky!
                          editor
                          • dally free energy
                            for all
                            dunfasto
                            • hendershot free energy
                              for all
                              all coils are wound clock wise same direction as inductive coils.
                              dunfasto
                              • No light
                                Hi Dunfasto,
                                do you have any other tips, this is not working.
                                For 50hz i'm using fg and car amplifier.
                                Can you post some photos from your device?
                                Regards, editor
