  • Nice!!!
    Nice Soundiceuk!!!
    Originally posted by soundiceuk View Post
    @ Xilo, Xee2, Dave45 & all members.
    The yarn turns into a super conductor for cold electricity when given high voltage.
    The negative charge on the antenna creates an ion sink hole in the sea of energy in which the earth floats.
    The HVM pumps the ions from the sea, through the tank circuit.
    Don was drawing off the battery that powered his HVM. We are drawing off the sea of energy that our antenna floats in. This makes a big difference..
      In this schematic I'm amazed 6000v cap; than what voltage rating are D3 and D4 8000v?!!!!!!
      yes the diodes must be of higher voltage ratings than caps else the capacitor charge will block the charging and try to reverse feed.
      example an in4007 is rated for 1000v if u have 8 in4007 in series then ur antline diode acts as big diode capable of handling 8000v secondary voltage.
      remember the diodes must be higher rated than secondary voltage. and also if u want ur capacitor to spark constantly then capacitor rated voltage must be equal to the secondary voltage or a little less. so cap remain filled and takes less time to overflow when discharged by spark.
      rgds
      zzzz
      • hi zzzz
        i test new setup for L2 has very low voltage as ur circut
        http://www.energeticforum.com/renewa...tml#post197112
        raadawad
        FREE ENERGY = FREEDOM
        raadawad[at]yahoo.com
        eng.raied[at]yahoo.com
        • Originally posted by zilano View Post
          ....... and also if u want ur capacitor to spark constantly ..........
          rgds
          zzzz
          Hi,
          still trying to follow the thread.
          Does C6 0,047mikroFarad 6000V really spark?
          magnetO
          http://www.energeticforum.com/attach...ue-zzz_p5a.jpg
          • Originally posted by Eng.raied View Post
            hi zzzz
            raadawad
            did u use diode ? and achieved resonance?
            rgds
            zzzz
              rgds
              zzzz
              i test two case with and without diodes L2 very low voltage
              the output voltage can't charge the caps
              my setup as b4
              http://www.energeticforum.com/attach...e-img_0083.jpg
              RaadAwad
              • Originally posted by magnetO View Post
                Hi,
                magnetO
                the capacitor u mentioned is for maintaining resonance not for sparking. yes it will spark if charged by secondary after diodes.
                u can use don way diodes or avramenko type diodes to charge cap
                donway diodes work to charge cap if u have magnetic resonance.
                avramenko diodes work when u have electrostatic resonance.
                rgds
                zzzz
                  RaadAwad
                  did u achieve resonance?
                  if resonance is not achived the secondary wont develop voltage. and will show only air induction effects that r low.
                  rgds
                  zzzz
                    rgds
                    zzzz
                    resonance is not achived.
                    ur circut has cap on half of L2 coil not the ends as u suggest.
                    do u have a method make auto resonance for L1 and L2 without using caps?
                    • Originally posted by xilo View Post
                      Hi Zelina!
                      what you mean to convey with these pics and videos?
                      i cant get your point.
                      are you really a woman?
                      never mind.
                      Best Regards!
                      XILO
                      Those who have mind they will understand.
                      yes am a woman Do u have any problem with that?
                      rgds
                      zzzz
                      • Hi All
                        Zelina could We analyze the video Don Smith replication first step by ingener99
                        Don Smith replication first step - YouTube
                        His effect sparking L2 is not the same, there the spark is white or bluish
                        , but in my case the spark is reddish
                        and as I can see there are no diodes.
                        the spark is after the capacitor on the hot side, not like DS between the negative side of the transformer and a capacitor
                        How colud he achieve such a spark on L2 side, there is a spark gap, and as he lit the light there is no capacitor no diodes nothing just a spark gap.
                        As I can see, maybe I am wrong?!
                        I will be here later!
                        rdgs blakcrobi
                        • HV diodes
                          rgds
                          zzzz
                          So what diodes would you propose on secondary uf4007 1amp and fast or BY399 3amp less fast?
                          Thanks Zilano
                          • Originally Posted by zilano
                            its called tyre blowing the compressor effect!
                            add diode in series like ant line one after another.
                            also if u have insufficient voltage that is less than the rated voltage cap it wont charge fully. so always have cap rated with less voltage than ur secondary can provide and have parallel spark across cap to overshoot xcess voltage.
                            rgds
                            zzzz
                            Originally posted by Seeker2011 View Post
                            You lost me here... I thought you always wanted caps rated higher than needed to prevent damage.
                            Yes you are correct Seeker2011, in my experience if capacitors are exposed
                            to AC they should be rated to at least a bit more than double the AC voltage
                            to prevent damage and if in a resonant system where the voltage could vary
                            in my opinion they should be rated to a bit more than double the maximum
                            possibly expected peak AC voltage. Therefore if a system can produce 8000v DC when
                            rectified the DC cap should be rated a bit more than 8000v and the AC
                            cap/caps on the secondary coil should be rated to a bit more than 16 kV.
                            In that situation I would go for 20kV rated caps for the AC and 10kV rated
                            caps for the DC.
                            I know this by experience and it is especially important with the tank caps across
                            the primary that they can handle more than 2 and up to 3 times the DC
                            voltage applied to them, so if using a spark gap to fire at 2000v then the tank
                            caps should be rated to 5000v or 6000v to prevent puncturing the dielectric.
                            A damaged capacitor can be frustrating to identify and cause all kinds of funny
                            problems. Safety spark gaps can malfunction and HV caps can be expensive.
                            • Originally posted by soundiceuk View Post
                              Luckily some of us were too busy getting high at school and didn't swallow the BS.
                              So that is what happened. LOL.
                              It does not matter whether you make so called cold or hot electricity, electrons or ions, or whether emanations exceed the speed of light, e=mc^2 is still correct when it comes to releasing energy from matter.
                              None of those links provided measured evidence, nor explanation, for transducing more energy from a transiently charged system via the so-called aether, than is initially applied to it.
                              Tesla was exceedingly clever, and yet even he did not demonstrate 'energy from free space'.
                              This thread started over 2.5 years ago, and you are still chasing a flawed *belief*, whilst other known possibilities exist. TPTB must be loving this and all of the websites which carry similar diversions with time wasting instructions.
                              Indeed did not Tesla himself say that he had another use for iron ?
                              (One which can be tested via spark gaps and field coils, and where e=mc^2 does apply, irrespectively of any particle velocities.)
                              Tesla visualised his inventions before he tried them. Are you ?
                                caps for the DC.
                                I think Z was talking about the cap on the secondary side. Would that make any difference?
