  • Channel available
    Hi Vidbid,
    Unfortunately, that channel is no longer available.
    oeps, seems i needed to set some flag which is done now.
    Thanks for reporting this.
    Regards Itsu
      Whether inventor or scientist, we need an English translation of what he is saying.
      Hi, vidbid !
      At this part which you got a screen he talks about design of Kapanadze coil.
      Previously, he explained the principle of the hydraulic and mechanical models.
      All of this he compares with the principle of Smiths scheme .
      Also he says that everywhere here is used the same principle.
      I must say it (coil on the screen)reminded me Joule Trief design(ferrite tube resistor).
      It is also the same design that zilano describes in her previos posts.
      But why we have got it all at the same time?
      In my opinion It is very suspicious.
      In addition :
      Just see the video Kapanadze with green box and see carefully at the coil design.
      Then try to compare it with ferrite tube resistor.
      And this is for the completion
      The Worldwide KAPAGEN successful replications
      I would like to see you opinion about this all.
      Best regads,
      Sergey.
      • Originally posted by Itsu View Post
        Hi Vidbid,
        Regards Itsu
        Use this one
        20111211213444.mpg - YouTube
        JJ
        • MO diodes
          Hi guys are Microwave Oven diodes fast? I mean good for Don circuit?
          Anyone knows?
          • Originally posted by myenergetic View Post
            Use this one
            JJ
            Hi, myenergetic!
            My advice is :
            Place the primery coil in to the center of second coil (same as Donald sheme)
            Don't use spiral coil .Use usual winding.
            Make a space between first and second coils.
            The primary coil should be more thickness as possible
            You will see the better result.
            my video post#4270
            Best regads,
            Sergey.
            • Datasheets
              For Datasheets, click here.
              International Rectifier
              Corporate Mailing Address
              101 N Sepulveda Blvd
              El Segundo, CA 90245
              To learn more about this company, click here
              VIDBID
              • Originally posted by zilano View Post
                @ kdkinen
                moray used leadplate Pb++
                silver plate Ag++
                and a wire Cu++(those were not days of Alluminium Al++)
                dissimilar metals
                experimenters use ferrite counter part of Fe++
                copper Cu++
                wire Cu++
                two similar one different
                if u look at closely all are ++
                why?
                this is the catch. think why.
                zzzz
                Interesting. I know that for a while, electricians used to wire houses in the US with aluminum, in fact, they may still do, but aluminum wire only has 61% of the conductivity of copper.(1)
                VIDBID
                • Brovin Kacher Tesla Output
                  Hi Vidbid,
                  Regards Itsu
                  Great, that video is available now.
                  VIDBID
                  • Originally posted by usu View Post
                    Hi, vidbid !
                    In addition :
                    Best regads,
                    Sergey.
                    @Sergey,
                    Thanks for that translation and analysis.
                    A "Kapagen" is not a Kapanadze replication in my humble opinion; at least, that was my conclusion.
                    VIDBID
                    • Brovin Kacher Tesla Circuit
                      @Itsu,
                      Thanks for that video. I see the schematic I was trying to find and was asking about.
                      Reference: http://www.energeticforum.com/191108-post4383.html
                      Last edited by vidbid; 05-04-2012, 09:09 PM. Reason: Added Link to Video and 2nd Image
                      VIDBID
                        individually both are hot but combined this way they become cold meaning radiant.
                        and this radiant is capacitered with split copper tube inside ferrite rings and inverted with usual iron cored trafo and we get hot electricity. radiant is captured by one plate of cap shaped in C and there is another c within this big C which is fed to the ferrite rings and we get dc that can be inverted. cold electricity is polarized form and there are otherways too to convert it. Leedskalnin was so right in his concept of helical resonating magnetic currents they are always two. we get hot electricity when they r two and running against each other giving hot electricity. the ferrite make it provide the lacking helical in cold electricity. anyways thats it. we can see individual poles cant do any work we need both. destroying the dipole gives us energy we call it as hot electricity. and thats what we need. yes for generation the dipole must be saved but separated as polarized to reconvert it back again.
                        i need to be travelling again got to rush to the airport. cya later another time!
                        rgds
                        zzzz
                        Hi,zilano!
                        An amazing description.
                        I have not seen this view before.
                        Who is the author of the idea?
                        Could you provide me an additional explanations about the dipole theory.
                        I realized that the positive and negative part of the divided dipole have to seek
                        each other for getting the new one.
                        My question is:
                        How do you imagine the design of the collector whech can to collect
                        each part of the dipole(devided parts)?
                        Perhaps it can be used for the converter.
                        Also could you explain more clearly this part:
                        silver plate Ag++
                        dissimilar metals
                        copper Cu++
                        wire Cu++
                        why?
                        Best regads,
                        Sergey.
                          @Itsu,
                          Hi,vidbid!
                          If you remember i asked you the link.
                          It was the video about device which collected under this scheme.
                          And there we see again the method that zelina described before.
                          Best regads,
                          Sergey.
                          • Capindres' Device
                            Originally posted by Guruji View Post
                            Hi Vidbid thanks for sharing. How much consumption is taking that JT cause if it's lighting those leds for a whole year is something but if it's lighting those leds for one min only it's another thing.
                            @Guruji Thanks for offering your input.
                            I'm not making any claims regarding Capindres' device either way. If anybody wants to ask Capindres about his device, I included a link to his video in that post. See #4515
                            VIDBID
                              coz its current amplifier device and a convertor for rf/hf for usable electricity.
                              moray tapped fine hf vibrations that cudnt drive the secondary of trafo. so this energy has to be amplified by some device. moray used copper wire running between lead plate and silver plate.
                              amazing Capindres' Device do the same it uses fe and cu and cu all ++ we must not call it a resistor coz its not.
                              rgds
                              zzzz
                                Hi!
                                What the program do you use for making the screen shots?
                                Sergey.
