  • Originally posted by kajunkreations View Post
    The natural resonant freq of the L2 is 31.5 mhz. I calculated the 40K by using LC meter and LC resonance calculator.
    Are you suggesting tune to natural resonance of L2 and run the same circuit?
    Yes, the natural resonance works much better and this is why N. Tesla calculated resonant frequencies by wire length.
      Ok, so do i use the L1 or L2 to set the desired frequency by wire length? and what frequency should the L1 with?
      • Originally posted by soundiceuk View Post
        Sorry I haven't got back to your email yet John.
        Please can you explain what do you mean in the quote?
        This one: Regarding recent Don circuits. Please note that the transistors in the inverter are drawn reverse. This is not meant as instructable.
        See first schematic in post: #3616.
        The npn transistors are connected to + ?!?!??! Apart form not functioning this wil shoot the BE junction because there are 5 to 10V specified only.
        ~o0o~
        Regarding voltage deviders. Thanks for the hints. This will help some replicators for initial calculations.
        For calculation in terms of common science it is OK. But do not expect to get there lots of amps out - like Don (40 KW). Your resistors will be in megawatt range. Calculate in LT spice! Resistors there are not power restricted.
        So there seems to be something special with it. I add some notions I've red:
        1. This strange cold energy prefers higher resistances unlike normal "hot" current. Nevertheless incandescent bulbs are lit. The neg energy will travel there to becaue it is easyer to pass. Think of 100mA current source being short circuited.
        2. The primary winding of the inverter does not carry current. The neg. energy enrgizes it and the current occures at secondary only - where we intend to use it. Many replicators blew their inverter because they did't notice that before.
        Please do not take that for true because I can not witness it. But this are some notion gatherd (sorry no link available) being able to possibly throw some light on the voltage deviders.This are some notions to ponder on.
        • Don’t shoot the messenger!
          Isn't that what I've been posting all along over the last year or so.... ?
          I quess if you guys are on the right track your going to reach the same conclusions ....
          • Cap Wiring
            Hi Folks,
            as we have now some corrected Don circuits some of you will concentrate on these. I want to give you a hint regarding the correct wiring fo capacitors.
            Please understand that every piece of wire is a resistance and an inductance as well. In normal life and tinkering this is mostly of no importance. Not so if we build Don's circuits. Independent if we wire the primary cap befor SG or the output cap - you have to obey some rules. Otherwise the cap will not work correctly.
            (I encourage you to simulate the circuits above with i.e. LTspice. Add GND and a generator for short pulses less than µS. Probe voltage and amps at the cap lead. You will be amazed!)
            1. The left most diagram shows a very usual und extremely minor wiring. In order to understand the minority you should get the notion that as we deal with steep HV pulses and we intend to get very instantly enormous amounts of amperage.
            Imagine: You sprinkle with a garden hose above a bucket and some droplets enter the bucket.
            Basics:
            Please understand that experets measured at a simple spark plug peak amps of 100 amps. No, not the coil delivers this amps but the charge is being accumulated in the ignition wires and the spark plug itself. At ignition event - bang - you have it - 100 amps for some nanoseconds. But this is essential in order to maintain a good spark later on . Did you get it? The charge is being accumulated! Not so in the most left diagram. One Ohm of tiny baby wires with alligator clips (all of you have it - is it?) corresponds to 100V at 100 amps. Some lazy charge will get there to in the capacitor but not as expected. And if you want to get it back you will get some lazy charge but not as expected.
            2. The middle diagram shows a much mor better wiring. The current will be forced to visit the (hopely short) leads of the capacitor and will poor into it as it is easy now. Same as you get it out. You suffer only of one resistance while you have two in series in the 1st diagram.
            Imagine: You sprinkle with a garden hose partly in a bucket and some serious amount will remain in the bucket.
            3. The right most diagramm shows a very special wiring with a feed through capacitor. The current is forced to enter the capacitor and every electron energized will get the chance first to be stored there.
            Imagine: You hold the nozzle of your garden hose directly into the bucket and will get back all water.
            Explanation:
            Please take in account that we inted to kick serious pulses even if the total amount of energy contained is small. Imagine a half pound hammer and you drive a nail into timber. This "tiny" hammer kicks with a forth of 8 tons - for short time. The nail prefers to displace himself. This is an example for a good build circuit.
            Now get a hammer with a rubber protection above the metal. These are used in order to protect cobblestones when setting a pavement. You never will get 8 tons of forth - no shock. And any nail will laugh excessively if you try to hammer it with this tool into timber. This is an example of minor wiring.
            So decide yourself what you intend to get! BTW: braided leads are the best. See one of Don's setup without coils. He used braided leads like the GND leads at your starter battery. He definitely knew why!
            In summary: Designs for huge pulses need to be setup like high current setups. It does not matter if you require these pulses 1nS 1mS or constantly. Imagine what will happen if you connect your automotive starter motor with these tiny baby alligator clips. You will never get huge amps not for a nS nor for a pS. At these short time slices they never will burn nor get hot and you say: All connected - why does it not work? The problem might sit in front of the setup
            PLEASE note and don't forget: At Don's circuits we have high current / high voltage designs!!!!!
            Be careful if you buy havy HV capacitors. Most parts available are build for mains frequency only. For this application it is not essential if you have connected the complete roll of metal foil or only a part of it.
            If you pulse these kind of capacitors only a small part of it will get the stress reqired in order to emit OU.
            I have an idea how to build pulse capacitors with readily available material. Stand by. I will give information as soon I have proved it functioning.
            • Absolutely marvellous John!
              We should all watch at least the first 5 minutes of this:
              Manly Hall - Magnetic Fields of the Human Body and Their Functions - YouTube
              Any pain sufferers amongst us?
              Pulsating Electromagnetic Field Therapy on Dr. OZ - YouTube
              Here are some very rare texts. Cheers Google
              The dark red and italic writing are different people but not Don.
              When using electromagnetic resonate flux energy systems, the electro side, when used, dies the classic heat death. Not so with magnetic flux systems, which provide the classic amplification demonstrated - found in radio type devices. As the frequency increases the commutative result is a Fibnache multiplication of the energy present. The speed of gravity exceeded, it becomes radioactive, at the higher frequencies the Van Allen magnetic Belt is penetrated and the resonate magnetic flux travels onward through space. Off and on as found in high voltage - high frequency devices provides the required electron spin as the magnetic flux system source. Magnetic Flux Systems are not controlled - contained in the normal sense. Ungrounded transformers when exposed to resonate magnetic flux, change it to the classic useful electrical energy. We see this everyday when the electric power company uses their high voltage - high frequency system in transmitting energy into their distribution system. Typically they use from the source, 100,000 to 500,000 cycles per second, which the down line transformer system changes to the useful energy we recognize. Very high energy loss results from using lower frequencies when transmitting energy. This magnetic flux when transferred up stream by the transformer contains the amplified - greater output than input energy system which is written out of classic physics. J.P. Morgan and Thomas Edison doctored the physics books so that any effort in that direction would be said to violate the natural laws. If this is the case, the classic radio devices ever present could - would not exist. Earth grounding below 20,000 cycles per seconds provides current flow - amperage being volts times amperes, classic Watts.
              Regards, Don Smith
              The inverter can be done away with by using a capacitive transformer and a variable earth connection!!
              RESONANT SYSTEMS ARE SELF RESTORING, ANY ENERGY LOSS IS TEMPORAL, THIS IS WHERE THE CONFUSION IS.
              REGARDS, DON SMITH
              FROM THE PROOF OF CONCEPT, REPLACE THE TESLA COIL WITH THE 65,000.
              AUTOMOTIVE COIL. THE SPARK CHANGES INTO RESONATE MAGNETIS WHICH
              FREELY AMPLIFIES YIELDING MORE ENERGY OUT THAN IN. ENERGY IN MILLIWATTS AND MAGNETIC RESONANCE FLUX ENERGY OUT OF THE BALL PARK!
              USE A GAUSS METER SINCE OHM'S LAW DOES NOT APPLY. THE OSCILLOSCOPE
              WAS NOT DESIGNED FOR THIS TYPE OF PROJECT, IT CONVERTS MAGNETIC FLUX AND THEN MEASURES IT, GIVING DISTORTED INFORMATION.
              REGARDS, DON SMITH
              DEAR ALL,
              SCALAR = MAGNETIC FLUX’S = INFINITY COP. THIS SYSTEM AMPLIFIES AND WHEN
              CAPTURED AND AT THE HIGHER LEVEL PROVIDES SELF POWERED DEVICES.
              REGARDS,
              DON SMITH
              I have several custom built pancake transformers, one with 3 layers high, each cable being approximately one inch diameter multi-stranded welding cable. Using a 20,000 Volt – 200 Ampere diode bridge resulted vaporization of the bridge. This was with input of 14 Watts.
              The amplification factor of the resonant magnetic flux is very large. Electrical flux dies a heat death and only degrades - attenuates.
              Regards, Don Smith
              Dear All,
              Two kinds of electro-magnetic = longitudinal electro = latitudinal waves.
              Regards, Don Smith
              Dear All,
              Concerning radiated energy, from my view, there are three types of related radiant energy being - - -
              1. Electro flux subject to heat death ='s hot.
              2. Magnetic flux ='s which does not obey Ohm's Law and the effect is cooling or cold.
              3. Gravity - flux reaction of mass to or from mass. All three are - depend on the electron spin mechanism.
              Don Smith
              Dear All,
              When electrons are spun they radiate flux, being electro and magnetic. The electro dies a heat death when used. Not so for the magnetic which can be amplified to infinity, radiating through space as common radio transmission.
              Materials having high magnetic permeability such as METGLAS with Cobalt, check the internet, have magnetic permeability's several million times that available from congenital industrial transformers. The main function of transformers is changing magnetic flux into useful electrical flux. The spark gap produces millions of times the suspected - recognized magnetic flux and when used with used with the Metglas transformer shows the energy amplification herein indicated. The excess energy obtained is from the Earth's ambient background, being Tesla's wheel work of nature. Mass can neither be created or destroyed,
              only change form. The electron spin mechanism provides an excess as radiated energy, being free energy. What you are seeing here is from an unpublished Patent Application.
              Regards, Don Smith
              http://en.wikipedia.org/wiki/Telluric_current
              I presume telluric potential is the same as resonating the ionosphere at the Schumann resonances to tap the same. This is pretty simple to do with a 555 IC and some pots for the R positions.
              The interesting note about the transformers has peaked my interest as they are not physically attached... Presuming the transformers are capable of coupling with the radiant flux this seems it should work... this would work much better though if we used pancake coils to do away with needing to frequency match the output.
              This is exactly what Don Smith has been telling people in so many words.
              It is my understanding that "telluric currents" is generated when lightning strikes somewhere on the planet. They range from e.l.f. to rf. There are several frequencies that end on or around 6Khz.
              Don,
              In your experience, have you been able to obtain energy without the use of a spark-gap?
              There are two kinds of energy [electro and magnetic] when used electric when earth grounded dies the classic heat death , how ever resonate magnetic flux is everywhere present throughout the universe , for example it's the source which spins the Earth at 1,000 miles per hour.
              Since the weight of the Earth is known, the energy required to do this is known. This Energy is the Ambient Background everywhere present. Next step, transformers change magnetic flux into electrical flux which is useful energy. I have gone FAR, FAR beyond this stage and am already where you will be in about 20 years if you truly understand what you are doing.
              Don Smith
              Don,
              Please bring us up to speed with you. What you have learned will not do anyone any good if you take it to your grave with you. All of your work will have been done in vain and will be gone forever and will be as if never were. This is why I am open with my own work. I don't want my work to be all for nothing. Credit for my work will allow me to be immortal, in a sense of reality, at least for those who survive me.
              Dear All, the Colleges, Universities and such with their Books are written with Special Interest controlling every word. Free Energy in Chemistry is that excess energy remaining after a reaction.
              Examples are explosions of any sort including atomic, and many other reactions not here mentioned. The most obvious being our Sun and its Radiated Magnetic Flux - Solar Wind, which spins - rotates the Earth. There is no Free Lunch, only the form changes allowing
              radiated energy to become available. A transformer changes radiated magnetic flux into usable electrical energy. Understanding these functions will be a start on Your Trip.
              Ed Leedskalnin called this "other" energy magnetricity.
              Coral Castle of Ed Leedskalnin
              • Kindly sent by Romero
                "This is how this diagram should look like."
                  hehe i'd be lying if i said i really knew, but what im doing is:
                  using 14 gauge 80 turn L2 half (62.8 ft is 15.66 Mhz)
                  so i type that into a conversion site and it tells me that the 1/4 wavelength is ...
                  ...15.70 ft ... which happens to be the exact physical 1/4 wire length
                  Then i use a .005 uf cap for L1 which is now... 15.70 ft of 8 gauge
                  And after playing around, i found that L1 was significantly heavier than L2...
                  So i cut off 6'' at a time and re-weighed the coil, also stripping off the insulation and weighing that as well...
                  ...to know the weight involved in the insulation to an accuracy of the 6'' increment,
                  then subtracted that from the total 15.70 ft
                  **you now have followed basic Tesla coil rules**
                  NOW, take an equal L2 and add that to the other side, (tapping it)
                  Now you have basically 2 back-to-back Tesla coils, and you only work in the midpoint of the one L2 half, the center-tap is neutralizing
                  now both halves of L2 are singing together well
                  Kind of like using 2 tesla coils tuned to eachother and duplicating the original
                  Like mentioned above, that will match nicely with NO tank caps on L2...
                  Its own self capacitance is enough
                  And adding ferrite will make you smile
                  Unless you really wanted to match the driver, BUT as Joe and others have found, REGARDLESS of the driver freq.... the values will be constant, only the spark needs adjusting
                  -Shunryu Suzuki
                  • Wow
                    Regards, Don Smith
                    REGARDS, DON SMITH
                    REGARDS, DON SMITH
                    DEAR ALL,
                    REGARDS,
                    DON SMITH
                    Regards, Don Smith
                    Dear All,
                    Regards, Don Smith
                    Dear All,
                    Don Smith
                    Dear All,
                    Regards, Don Smith
                    Don,
                    Don Smith
                    Don,
                    Thankyou so much for this !!!
                    -Shunryu Suzuki
                      To try and help with voltage dividers, here are some diagrams..... Hopefully they might provide something helpful to someone.
                      Hello soundiceuk This is really close too the circuit I'm currently using, Except I strongly suggest using a Variac (for AC) or PWM (dc) before the HV transformer, Flyback or HV source.Being able to controll the imput voltage on the transformer was a must for tuning mine...
                      Randy
                      • Another gem from Don
                        AMBIENT BACKGROUND FOR THE EARTH - - - - Various attempts have been made including Gauss and Oersted. Gauss was at day time and Oersted at night. At their European locations, Gauss measured 100,000 Volts and Oersted 50,000 Volts. This is misleading in several ways. In part, the Voltage increase upwards very dramatically from the Earth’s surface. The length of the string used by the contenders in part gave different readings. Electrons are normally pared which their quiescent state makes their net charge neutral. However when resonate - cycling they radiate electro and magnetic flux which by transforming from magnetic changes to electrical, becoming useful energy which we recognize. The Ambient background then is a complex composed of the Plasma Energy condition present every where and available as an endless source available energy. The Engine which provides this is the resonate magnetic Solar Plasma arriving at the Earth. The Ambient Energy Source available then becomes obvious. Devices which excite the Earth’s Plasma field allows a window for seeing this. Based upon ths writer’s the current knowledge base this is 20 Tesla’s and can be expected as being greater.
                        From a Human standpoint harvesting - mining this Energy becomes the Keystone to preventing their extinction. Methods for doing this known and have been available for more than 100 years. The Problem is Special Interest, not Technology. The past 20 years has be a full time job, undoing the degradation intentional put there by Special Interest. Tapping into and using this Universally available Energy Resource is of Great Importance. This Energy is available to Present Technology through Resonate Magnetic Flux. A Proper Transformer changes the every where available Magnetic Flux into Electrical Flux, becoming useful Energy as know it.
                        Special Interest teaches from the Lorentz Factor that being equal and opposite that the net energy available is ZERO . Unaccounted for is the Radiant Flux Energy present and available is the Energy Transfer Mechanism. This Freeing of Energy does not in any way diminish the Resonate Electrons Present. Energy excess from a reaction is named FREE ENERGY by Gibbs. Therefor all Electrical Energy is Free Energy until Special Interest Blocks and Claims the Source as Private Property for Gain. There for using the every where present, Resonate Electrons as a Source of this Free Energy is both Logical and Reasonable. This Resonate Radiant Energy comes in two flavors, being Electrical Flux and Magnetic Flux. The Electrical Flux is controlled by Ohm’s Law, resulting in a Heat Death when used. Not so for Resonate Magnetic Flux which Freely Amplifies to Infinity. When captured at the Higher Level and Transformed into Electrical Flux, which is Recognized as Useful Energy. Resonating - Fluxing of these None Ionic Electrons provides Useful Energy. From a Gauss Meter and a Spark Gap using a High Voltage and High Frequency Source the Magnetic Flux available ranges from two to greater than two thousand Gauss. One Gauss is the Magnetic Flux Equivalent of 100,000 Volts of Energy. Self Powered Electrical Devices are then a Reality and only Special Interest Prevents It.
                        Donald L. Smith , CEO TransWorld Energy Phone / Fax 903 989 2821
                        Registered Professional Engineer
                        2009 FM 815
                        Trenton , Texas 75490
                        U.S.A.
                          Try it yourself. Get an old professional foto flash device. Open the lead between the flash capacitor and the flash tube. Insert a coil. . Alternatively mount your coil on a cooking spoon made out of wood and attach longer leads.
                          Shoot your pain area.
                            The free end of the bridge rectifier confuses me. Either we can omit both diodes completely or it is the input for an antenna. Any suggestions available?
                            • I had the same thoughts earlier... http://www.energeticforum.com/renewa...tml#post184404
                              If the NST ( 3) has a center taped secondary connected to earth ground then there is a return path and it functions like a buck converter. As drawn it cannot provide an output to the charging cap unless the diodes are "leaky" and providing a pulsed feedback. If there were an antenna at the DC- then it would entice the ambient to enter because of the spark gap. Maybe a large parasitic plate connected there would work as well.
                              I plan to do some experiments with that circuit when time allows, I have several HV DC modules that should provide a reasonable test bed.
                              • Pwm
                                Randy
                                What PWM are you using to the flyback? Do you have a schematic?
                                That circuit very interesting.
                                Regarding the voltage divider it should be to 12v not 120v for the inverter.
                                Ok thanks guys
