Originally posted by wayne.ct
Hi Janost,
I noticed your supercap failed after running the circuit for a few hours, that would indicate a strong AC feedback from the circuit that tended to destroy the electrolytic supercap.
You may need to change it to a non-polarized cap, say, a 200~300mfd 450V AC one.
I insist it is good to check whether the charged battery has a solid charge after all by taking it out from the ckt and discharge it through a resistive load.
There has been cases of researchers in the past who discovered at the end of their experiments that similar charging setups did not provide a solid charge to the batteries, rather, it was merely pure potential charging, and very little current charging.
Still, I am not discouraging your work, this circuit of yours maybe different though.
Thanks for taking our suggestions into account.
aaron5120
aaron5120
Originally posted by Kokomoj0 View PostSo I am curious, where is the cutoff where we can officially say its too good to be true? 10,000 posts maybe?
It seems there are many reasons, which almost all paved and "analysed"
in this thread/topic, so I think there`s no reason to repeat them and lose our time.
Here we have different mindset-groups, the main ones being the guys&girls
who, after carefull analysis have come to the conclusion that Don L. Smith Devices
in fact worked really as claimed, despite the fact that we cannot make an exact
copy of one of them and obtaining the same results.
Me, happens to be in this first group for reasons I have already expressed in this thread.
Code:The Radiant Energy Receiver of T.Henry Moray devices worked, and we know this for sure, despite - again - the fact, that we are unable to do the same thing.
are fake ones, most probably depends on it`s hard-cored laws of physics.
Others, are in conflict of interests if this finally be confirmed to the main public as real-working devices, this in turn means less or no huge money incoming..
aka Big Petrolioum Oil companies, Governments: could be losing very huge incomes
from taxes which is their "vampire blood" so to say.
Yes there are other group-mindsets I might have missed.
One of them being the real faking guys who destroy the reputation of good inventors.
Originally posted by Kokomoj0 View PostIt only takes stiffler a few posts to get his resonant sec to work and produce, what seems to be the problem with this one?
I think you know the story of John Bedini, having a visit to him by 2 "m.i.b`s"
said him to keep his devices to toy level
Maybe Stiffer has already taken care to keep to "toy level" ?!
Just thinking.
Science ? Is a perverse of itself, because they cannot explain the most basic laws of nature
Gravity i.e. and how our star: the Sun "works" with theories coming ang going
with no real answers....
cheers folks.
Regards.<< BP Ultimate + Shell-V Power + Allies (opec) = the Ultimate Power Aligators to Suck People`s Blood !-! >>
It only takes stiffler a few posts to get his resonant sec to work and produce, what seems to be the problem with this one?Last edited by janost; 03-10-2013, 10:14 AM.
Capacitors and Resistors
Originally posted by wayne.ct View PostWhen dealing with slowly changing voltages and currents you may apply these two general rules:
1. A resistor in SERIES with a cap will limit or control the RISING energy in the cap.
2. A resistor in PARALLEL with a cap will limit or control the DECLINING energy stored in the cap.
I asked because,I saw a don schematic that said the resistor was across the cap as frequency and voltage control.Patrick Kelly suggested that it was done to set the capacitor at a certain frequency.I assume the time constant was converted to frequency in that case.
As for me, I ordered some stuff and they should arrive within a month.I am drooling to get back to experimenting again...I don't want to harm my new supercaps.
BTW , how do I calculate the self resonant frequency of a cap.I see it does have inductance.Do I use the same LC formula, does it matter? What if i dc pulse cap at its self resonant frequency?
Best regards,
GedLast edited by Gedfire; 03-10-2013, 03:45 AM.
Originally posted by Gedfire View Post@Janost, Peculian and Wayne.ct, thanks for taking time out to respond.Your efforts are appreciated.
Best regards,
Ged
But it does have a timeconstant defined as T=RC and the R component is the ESR of the cap.
Capacior and Resonance Back To Basics and Big Capacitors
Also ,I would like to know the capacitance of those commercial device capacitors Don had and Voltage.I don't see the capacitance written on it or is it something to calculate?
Has anyone every replication the simplest resonant device don mentioned? Yeah, complete with 1.5 volt 1 Mhz driver and neon bulb.The modern version has been dummied down.Leds .darn.Don spoke too soon.I might replicate later in the year.But first things first.
I was thinking about using speaker coils of similar specs as transmitter and multiple receivers.My problem is building the 1 Mhz driver...I find 555 timer stuff painstaking.
Just asking.
GedLast edited by Gedfire; 07-10-2013, 01:52 AM.
hi gedfire.the 555 chip is said to run to 500 khz max.patrick kelly wrote somewhere the limit is about a tenth of that with most 555 chips in most applications.i dont know what the upper limit is on the 1 transistor/mosfet blocker circuits.i've seen 576khz with an air cored setup.higher speed should be attainable with less turns/inductance than what i've played with.anyone out there like to suggest an oscltr on a chip that runs up to 1.5 mhz or more? maybe a fancy signal generator ,or a diy of one is what's required.anybodyLast edited by hotrod68r; 03-12-2013, 07:44 AM.
signal generator
Blackchisel97 suggested one of these a while back on another forum. I got one similar to this and it works great. Depending on how much you want to spend you can get them up to 5 Mhz output. They produce sine, square and triangular waveforms. They also have a frequency counter built in. A really nice simple piece of test equipment. Here's a link to one model:
1pc 0 01 3MHz DDS Function Signal Generator Module Wave 0 01 3MHz | eBay
CarrollJust because someone disagrees with you does NOT make them your enemy. We can disagree without attacking someone. This means YOU especially BroMikey.
555 drivers
Originally posted by hotrod68r View Posthi gedfire.the 555 chip is said to run to 500 khz max.patrick kelly wrote somewhere the limit is about a tenth of that with most 555 chips in most applications.i dont know what the upper limit is on the 1 transistor/mosfet blocker circuits.i've seen 576khz with an air cored setup.higher speed should be attainable with less turns/inductance than what i've played with.anyone out there like to suggest an oscltr on a chip that runs up to 1.5 mhz or more? maybe a fancy signal generator ,or a diy of one is what's required.anybody
I have ordered some off the shelf drivers but one of them only goes up to 100khz.The company said they are about to release a 1 Mhz version later.
Ged
Originally posted by Gedfire View Postthanks for replying.when i google self resonance of caps I find stuff that ,well i dont understand. I am thinking if caps also have inductance, mainly from the leads they say, then might we calculate its self resonant frequency?
Just asking.
Ged
That is a frequency with a center around 500MHz.
So yes, it works by looping legs directly on the cap.
3 Mhz Driver YEAH!
Originally posted by citfta View PostBlackchisel97 suggested one of these a while back on another forum. I got one similar to this and it works great. Depending on how much you want to spend you can get them up to 5 Mhz output. They produce sine, square and triangular waveforms. They also have a frequency counter built in. A really nice simple piece of test equipment. Here's a link to one model:
Carroll
BTW , I ended up buying 12 volt NSTs and DC Drivers for starters.Guess I will test these things when they come then go for higher frequencies later on.
Appreciate the efforts.
Ged
