  • Originally posted by woopy View Post
    Hi all
    Thank's to all contributors
    going on the hard working
    hope this helps
    good luck at all
    Laurent
    phase shifting with grounding 1.wmv - YouTube
    Hi Woopy!
    great vdo !
    great work!
    keep rolling!
    you are incredible!
    keep up the good work!
    rgds
    zelina
    • Simple Experiment-cold Electricity/back Emf In A Coil
      AVRAMENKO COIL
      TURN YOUR MULTIMETER SET ON MEASURING MILIVOLT (DC)SETTING IF VOLTAGE OVERSHOOTS THE LIMIT OF MILIVOLT. SET IT TO VOLT(DC) SETTING.
      TRY WITH ALL THREE TERMINALS NAMELY EARTH/ NEUTRAL AND LIVE AND SEE DIFFERENT EFFECTS.
      CAUTION:THE ARRANGEMENT BELOW MUST NEVER BE CONNECTED TO LIVE TERMINAL. CONNCTED TO EARTH TERMINAL ONLY AND MULTIPLE FERRITE RODS CAN BE USED TO ENHANCE THE EFFECT
      • the plauson converter
        Hi All!
        The plauson converter
        new test Ver.2
        with parallel coils on SG and one capacitor for each coil
        IMG 0078 - YouTube
        FREE ENERGY = FREEDOM
        raadawad[at]yahoo.com
        eng.raied[at]yahoo.com
        • Mystery solved
          Hi all
          hope this helps
          good luck at all
          Laurent
          You've just explained an effect I've had in my experiments. THANKYOU!!!!
          Can you try the following:
          1 Replace the earth ground with the negative terminal of a lead acid accumulator ( car battery) recommended by Tesla.(and Kapanadze) and see if the effect is the same.
          2 Replace the earth ground with a STRAIGHT length of wire say 10 meters long and see if the effect is the same (Oliver Lodge - Standing wave reflection).
          Thankyou.
          GREAT WORK.
          • Originally posted by zilano
            wot short circuit plz explain.
            did u not use transformer say 120/230 v ac to 9v ac 500 ma?
            did u directly fed Ac from wall outlet to the 8 turn coil?
            u have to feed ac thru a 9 volt ac transformer.
            or your circuit stopped working?
            zzzz
            relax please
            i know what i do
            i make test 2 minute ago
            i get another transformer 12v Ac
            and winding 8 T as you ask
            the light of bulb become less then before when i connect 12 V ac to 8T
            • with 4T and diode no affect on output
              • Originally posted by Eng.raied View Post
                that shows that u r using pure scalar energy. thinner wire turns in 20 turn coil and thicker wire turns on 5 turn coil. use magnet wire in both coils and see its effect on output power.
                change ratio like 20 to 1 or 50 to 5 etc and check output power. diode(full wave) the output and try measuring amps. if u r able to measure amps and the bulb heats its good sign!
                rgds
                zelina
                • Originally posted by zilano View Post
                  rgds
                  zelina
                  i lose alot of capacitors when i make testings.
                  then i need high quality capacitors .
                  i thinking by using x-ray paper it is excellent .
                  i made one has 4.4nF with voltage more 4000V from big x-ray paper and two foil paper
                  i test it with flyback it is work without problem
                    sorry about ur lost caps. always use caps with overhead. if u need 3 nf for 3000 volt cap use a cap 3nf 5000 volt rating. so it wont get damaged if voltage overshoots 3000 range and homemade caps r best u can make and mend them also. u can also use salt water bottle caps but they r bulky and dangerous if glass breaks. i wont recommend u salt water bottle caps. for higher capacity caps u can use motor run caps and also microwave oven transformer caps. they r rated at higher voltage and u can series or parallel them to get required mfd's.
                    u can make variable caps using computer's damaged hard disk drive platters can be procured from friends and from the sellers of electronic trash they also sell everything electronic and u can get it much cheaper than buying from stores. can even get motor run caps and electrolytic caps at the cheapest.
                    air variable capacitor from scrap aluminum sheets
                    Plastic Best Choice For High Voltage Capacitors | THE PLASTIC SPORK BLOG
                    off the topic but for the topic who r interested in Moray tinkering
                    Radio a cristallo - Foxhole radio with Hard disk drive platter as detector! - YouTube
                    rgds
                    zelina
                      rgds
                      zelina
                      Don't know what frequency you are using but at some point dv/dt becomes an issue. Wonder if anyone has a way to test homemade caps for dv/dt? That would be handy to have.
                        rgds
                        zelina
                        i read all pages on this thread there are alot of circuits.
                        i will rebuild my device from zero.
                        what best one i can choose it to build i need 4kw device for my small house
                          Do not be discouraged Eng I think you are on track.
                          For cheap parts look at the capacitors and HV diode of old oven microwave, they are good alternatives in series and in parallel. Available and very high voltage.
                          regards spark2
                            what about this
                            http://www.energeticforum.com/attach...e-img_0072.jpg
                            please more info
                            serial with what?
                            if serial with 2.5 uF cap that no loop to discharge .
                            rgds
                            raadawad
                            impedance of your bulb is around 20 ohms. impedance of capacitor :
                            For frequency of 30000 Hertz and Capacitance of 2,5 μFarads,
                            capacitive reactance (xc) = 2.65258238486 Ohms.
                            impedance of your load must match with source impedance.you must decrease your capacitance.
                            For frequency of 30000 Hertz and Capacitance of 0.25 μFarads,
                            capacitive reactance (xc) = 21.2206590789 Ohms
                            • Originally posted by m786 View Post
                              i use flyback driver i don't know the frequency of circuit i am waiting (Channel-Digital-Oscilloscope-Electronic-Engineering) device
                                Look this link eng.raied it explains how the resonance is automatically tune with a flyback and what we need to know it will help you i hope.
                                POWERLABS' High Voltage Solid State Flyback Driver
                                rgds spark2
