Originally posted by a.king21
Better translation ?
Accessories and materials part 1
A) the High-voltage power supply 3000V 100 - 200 watts.
It is possible to apply transformers to neon lamps, or any similar radio amateur designs with high EFFICIENCY of transformation and stabilization of a target current.
Possible version of execution of converter TVS
2) High-frequency resonant system L1/L2
Coil L1 is wound by a high-quality audio cable sechenirem 6.10 mm2, or make-it-yourself litz by appropriate sections. Rough length with conclusions received litz (audio cable) - roughly two meters.
Winding is made on kanlizatsionnoy to a pipe £ 50mm, quantity of coils 4-5 (left coiling).
The remained conclusions of the coil not brezaem, and it is deduced through the middle of a pipe for connection to an arrester and condensers of a contour of the primary.
Possible version of execution:
Secondary coil L2 of a resonant contour is carried out naked copper (it is desirable silvered, is worse tinned) by a wire in diameter of 2-3 mm. Diameter of winding secondary coil-nearby 75mm. The coil is carried out with tap from the middle. Both half have one direction of winding (clockwise, ie right).
Rough number of coils, coil 2x16, 2h18 coils. The coil is mandatory for executing an air version with fastenings in apertures 3-4 locating brackets.
Fastening kotuschek should not suppose a drain vyokochastotnyh high-voltage charges on any other parts of the diagram and a design. Deduce coils are clamped in Enclosures placed on the assembly panel for earthly connections of other elements of the diagram. A parity of lengths of wires of coils.
Possible version of execution vtorinoy coils:
High-voltage diodes (columns)
It is possible to apply purchased, or to make independently.
Diodes of each shoulder should have face value on a current not less than 10 amperes at a return pressure 25-30 kilo-volts
Probably parallel connection of several columns for maintenance of a required current.
Version of the high-voltage diode:
Planimetric condensers (for coils L1, L2)
Kondenysator circuits of the primary gets out on working nepryazhenie not less than 4 kV, the capacity of the condenser depends on working frequency of a secondary contour (at the author nanofarads 28 at resonant frequency 600 kHz). The condenser should have the minimal dielectric losses and hold Soline capacity (quartz)
The compound battery of condensers and more low-power is usually typed. The optimal types kondensaktorov-
- K78-2, k78-15, k78-25, or others similar capable well to maintain pulse currents of the category.
- The condenser of the secondary.
It is better to apply condensers specified above types but with a pressure not less than 10 kilo-volts . Condensers of types KVI-3, and still better-K15-y2 work perfectly.
Secondary katuschka with capacity of the condenser shape a resonant contour. Capacity of the condenser of the secondary zayisit from required resonant frequency (at the author - the condenser kvi3 10 square meters in 2200 picofarads) ..
Photo of the condenser of the secondary:
High-frequency recuperation a throttle with the minimal through passage capacity
Olrientirovochnaya inductance of a throttle 100 200 uH. Versions with sectioning obmotkok are possible. Diameter Wire-1 ,5-2mm in enamel izolitsii.
Photo of a version of a throttle:
The throttle is wound on a mandrel 50 PVC 75 mm.
The battery of storage condensers
It is possible to apply condensers a pressure 5-15 square in the general capacity in area 2 microfarads.
Any types of oil-filled condensers of types k41-1, K75-53 and other approach ..
The diagram of the converter:
Diodes VD1, VD2 - high-voltage columns.
Diode VD5-ultrafast volt30 1200-150 ampere.
Drosse5l L3 Luba with not closed magnetic core a wire (trunk) not less 6mm2, 5.1 mH inductive ..
Load (the inverter or the motor of a direct current) to apply with a low entrance pressure of 12-110 volt (nirzhe the pressure - is more energy on an output)
Extension follows ...
At assembly and experiments do not forget about the Safety precautions at work on pressure more than 1000 Volt.
The constant link for uploading an original file:
http://www.001-lab.com/001lab/index....downfile&id=91
