Earth Rods
  • Earth Rods
    The purpose of this thread Earth Rods is to discuss Earth Rod applications on Bedini SG's or other circuits and maybe even with Peter's type of attraction motor concepts.
    A variation was discovered with Technical Remote Viewing.The method Jetijs mentioned in the Bedini SG thread is the one discovered with TRV.
    One thing to realize about Earth Rod applications from my experience is that the results are NOT consistent. This doesn't mean that you can't always have positive benefit, it just means the results change over time. ALSO, depending on other variables, the results can GROW over time.
    I have shared this concept with a few Bedini experimenters and have received such a wide range of reports. I'm sure the geography has a lot to do with it...where are the Earth's acupuncture meridians in relation to the rods, etc...
    I used to have Earth Rod systems going to grids laying under a bed mattress for healing purposes at a house about 7-8 years ago. John Bedini turned me onto the Earth Rod concepts back then.
    A good way to find a good spot to put a rod is to get a multimeter and put it on DC volts. I had some long wires and alligator clips attached to the ends of the probes and the other end I had 3 foot rods...one steel and one copper. I would put one rod in the ground...doesnt' matter what rod you use for what charge because you're just looking for the largest potential difference you can get. One rod in ground...deep, then take the other rod and walk around with it sticking it in different spots. Wherever you get the highest reading, leave the second rod there.
    Then mark where the first rod is, take it out and see if you can find a higher reading with it somewhere else, if not, put it back. If you get a higher reading, you can take the other rod and move it around and go back and forth. You're lucky if you can get 2 volts. I found 4 one time in my Qigong Master friend Rodger's backyard.
    Anyway, this will show you some good spots either plus or negative.
    For the TRV discovered rod method, it takes one rod...not for grounding purposes but to draw the aether from the ground.
    EARTH -----> ROD -----> DIODE -----> POSITIVE ON CHARGING BATTERY
    That's it! The TRV session was for logical next step enhancements to the overall SG circuits and with research combined with the data, the above is what it revealed. The line on the diode should be on the side of the battery so the positive voltage potential moves from Earth TOWARDS the charging battery positive terminal.
    This is so easy for ANYONE to do that I would recommend that everyone at least play with it and try other variations if you want but the above is the exact method that was used on Kevin's SSG with the alternative superpole magnet configuration.
    Be on the lookout for something else coming soon
    RPX & MWO http://vril.io
    Bedini SG Earth Rod Video
    Bedini SG Earth Rod video on youtube.
    1 minute long.
      Bedini SG Earth Rod diagram
        I Aaron!!!!!
        I have a question for you??
        I look for a schematic for the earth magnetic poles and i find something
        interesting!!!!!!
        We can see that the globe is split in 2 parts.The upper part is equater field
        going toward the north pole right??
        And the other part is the equater field going down to the south pole.
        My question is???
        The earth rod would be pretty efficient if we used it as the core for the coil??
        I think that,like 2 magnets ,the north attract the south right!!!
        So if we are on the upper part of the globe we must arrange the coil to attract that field into the coil right?????
        If i i'm out somewere please let me know!!!!!!
        Thank's Aaron!!
        peper10
        Hope die last!!!
          HO i forget someting!!!
          With the sg can we reverse the hole setup??
          Having all magnet on the south side insted???
          It's just to know if it's applicable to the earth rod..
          My regards..
          peper10
          Hope die last!!!
            earth rod as core
            I like how you think... using the earth rod as the core! Cool idea.
            The whole SG CAN be reversed...can wind coil backwards and use south as the normal monopole field.
            Can anyone see the video? I wonder why it tells me it is unavailable.
            VIDEO IS FIXED.........
              rod as coil effects?
              I wonder how the size of the rod (length down into the ground) will effect the coil charging and collapsing.
                I think i catch something Jettis talk about.
                He talk about the EATHER i think!!
                Anyway the starting point for the SG is the coil catching more from the eather and a good timing for triggering RIGHT????
                By the way Aaron, i try to see the vid on you tube and it's not working..
                Thank's peper10
                Hope die last!!!
                  NEW Bedini Earth Rod video link fixed
                  YouTube - Bedini SG Earth Rod
                    Hey Aaron i wonder???
                    I'm i wrong or what??
                    The picture you show here suggest that we charge the battery by the positive side????
                    If so i'm completely off the track here...
                    I gonna do my homework and studdy it again..
                    Thank's for you're patience
                    peper10
                    Hope die last!!!
                      coils on earth rods
                      Peper10,
                      John's link here:
                      New Page 2
                      Has this pic:
                      Coils on the ground probes:
                        charging on positive
                        Hi Peper10,
                        That is for the positive potential and not electron current.
                        The Quantum Key book is a good primer on the aether theories involved with some of these circuits.
                          Hi Peper10,
                          Ho!! Ok.
                          I think i misunderstand you.
                          peper10
                          Hope die last!!!
                          • #14
                            Pulling the Aether
                            Hi,
                            I had experimented with charging capacitors before by using an antenna and an earth rod. So It may be possible to instead of drawing the aether only from the earth, draw it from the sky and the earth by a bridge rectifier. Isn't this reasonable?
                            Elias
                            http://blog.hexaheart.org
                            • #15
                              Originally posted by elias View Post
                              Hi,
                              Elias
                              Hi Elias.
                              I'm not sure about that.If you look on the internet for(earth magnetic
                              poles) you gonna find that the drawings show that the 2 poles act as
                              they are sucking the magnetic.
                              So,the 2 poles are like the core of a magnet,and, the rest is the surrounding field of the magnet.
                              Like Aaron post earlier,you can see the earth rod have been used before.
                              It's not to proove something here!!!But i'm pretty sure if you dig in internet,
                              you gonna find much of information about that.
                              Thank's for you're idea.
                              peper10
                              Hope die last!!!
