LTSpice Simulation of Electronic Boost via the Isolation of Voltage & Current Sources
  • LTSpice Simulation of Electronic Boost via the Isolation of Voltage & Current Sources
    If it's one thing I've learned from over a year and a half of simulations is to segregate the voltage source of a circuit from its current source to safeguard the former by draining only the latter.
    I can't decide what thread to post this message under, so I've started this one instead. It concerns the use of an aerial -- not so much for its potential use as a voltage source, so much as -- for its use as a topload. But unlike the use of toploads on top of modern day Tesla coils acting as a voltage reference (not an aerial) for their circuits, my use -below- is as a current reference due to their immediate connection to a current coil of very low self-induction: just a few turns of stout wire (using a larger than normal AWG number). Any stray voltage picked up by its aerial -- although useful -- is not what would be its intended goal since there's only a stray amount of aerial voltage, anyway.
    I have to thank someone, whose name -here- I can't remember, who alerted me to C. Earl Amman. For it is his use of a hollow (bronze) sphere as his pair of aerials that turned me on to the possibility of its use as an FCC-friendly method of shaping an aerial so as to hopefully eliminate any undue radio broadcast interference from any eager builds of budding enthusiasts hoping to amass enough energy in their "free energy" circuits to become a veritable broadcast station of static interference -- especially if these spheres are insulated only on their outer surface. I suspect that the focal point (of a hollow sphere acting as an aerial) will be at its center if its diameter is appropriately sized per its intended wavelength. I'd venture to guess that the curvature of the outer surface will scatter the direction and phase angle of any waves emanating outwardly sufficient to cross cancel each other and be left with no local interference of any noticeable degree? Perhaps....
    Early on in the first video, below, I share an insight in which I have reason to believe (I forget what those reasons are; sorry) that it is not the magnetic field of a coil which is getting transferred through the magnetizable core of a transformer. Instead, it is a coil's electric field to which the transformer core is magnetically reacting at a 90 degree angle of reaction. So, it is the primary coil's electric field which transposes into a magnetic reaction within the transformer's core, and it is the secondary's electric field which absorbs the release of the transformer's magnetizable core.
    This is possibly my last simulation of free energy. http://vinyasi.info/circuitjs1/texts/Nikola%20Tesla/LTSpice%20-%20Tesla's%20Pierce-Arrow.zip
    alternative...
    errata...
    alternative errata...
    Correction of a mistake in the hour-long video of this same name and posted after this one.
    LTSpice simulations talked about in the videos, above...
    alternate download location for zip files...
    Source for my citation of Ossie Callanan suggesting the use of dead batteries for converting reactive power into usable power.....
    My advice : with too much information from start you get no attention to the summary of your statement. Give us opportunity to realize what you found by preparing very short like 5 minute or less video , then if somebody is interested in details will follow your work.
      I bet you would like to see C.E.Ammann and his device
      Look here https://www.4shared.com/s/fvzPNGW0Qee
        People in US have so much sources of knowledge...why they do not dig into the archives of old newspapers ? They should have the links to old photos , maybe even some copies. Those are precious sources of information. I don't understand why they do not work to get access to them (except Leland Anderson)
          Title of post says it all.
          Have you downloaded the zip file and run the simulations, or at least look at the included screen shots? I spent several hours this morning making improvements.
          What I discovered (this morning) is that it's possible to simulate the transformation of reactive power into usable power using a battery of any voltage -- even a dead one as Ossie Callanan suggests (referenced on Turion's thread devoted to the 3 Battery Generator) -- in series with a moderate resistance, say 1k Ohm or more.
          As you know, there's tons of overunity circuit ideas which produce plenty of reactive power composed of current and voltage waves out of phase by 90 degrees and not much else.
          Other than using a synchronous generator to align the waves and bring the power factor closer to unity, what's a poor man to do?
          What I discovered prior to posting is that understanding Newman helps understanding Tesla's Special (Tri-Metal) Generator along with (possibly) Tesla's Pierce-Arrow demonstration and vice versa. I had also discovered how easy it is to boost a radio signal using a concept derived from an upsidedown modern day Tesla coil, namely: instead of connecting the topload to the voltage coil (composed of hundreds of turns of thin wire), why not connect the topload directly to the current coil (merely a few turns of stout wire)?
          Thanks for dropping in.
            Download Difficulty = 100%
            I might enjoy it if I could download it without ads blocking me from doing so on my phone.
              Ok.I cut the article from the whole newspaper page.
              P.S. I wish if somebody could find a whole picture somehow... we could see more details
                Similarity to electromechanical watt hour meter
                What I discovered (this morning) is that it's possible to simulate the transformation of reactive power into usable power using a dead battery as Ossie Callanan suggests (referenced on Turion's thread devoted to the 3 Battery Generator).
                William Lyne has frequently pointed out the similarity between the electromechanical watt hour meter is a watered down version of Tesla's Special Generator.
                Well, in this simulation, the voltage coils are connected at right angles to the current coils despite they are all inductively coupled and wound in the same direction.
                  Thanks for that rare gem of a gift.
                  How auspicious that there's a Pierce-Arrow article right beside it!
                    Tesla may have patented Ossie Callanan's battery method for correcting power factor
                    Ossie Callanan may not have been the first person to utilize batteries for power factor correction. Tesla may have beat him to it by not divulging all of his intentions within the body of his patent?
                    A simulation of the first example from Tesla's patent.
                    Method of obtaining direct from alternating currents - US 413353 A - PDF downloaded from Google patents.
                    I've added a dual battery simulation to the zip files linked, above, and doubled the internal series resistance inside of each to get about the same amperage and volts since their parallel arrangement is a current division effectively doubling current within that subcircuit.
                      No free lunch, here. But maybe Ossie found a way?
                      I've learned a few things having spent yesterday simulating and morphing the circuits in three different simulators.
                      Tesla did, indeed, come up with a way to manipulate reactive power inside a circuit in such a way that one part was shifted by an additional ninety degrees out of phase between the amperage and the voltage while another section shifted back into synchronicity. In other words, one section of the circuit became more reactive indicated by a 180 degree difference in phase relation between current and voltage while the other part of the circuit shifted into zero degrees alignment. This occurred for me, yesterday. But there's no switching in my circuits, such as there was with Ossie Callanan's use of a modified Bedini SG. So, I don't know what's possible with this method beyond what I've simulated. It has a lot of potential for more research. Thus, is Tesla's patent (Method of obtaining direct from alternating currents - US 413353 A – Oct. 22, 1889) suspect for hiding this truth in an innocent manner when its title belies merely the addition of AC to DC.
                      Specific to my circuit and not intended to be generic for all cases......
                      These two batteries with their series resistance, inline, must be paired and located in a self- shorting loop. And this loop must be connected to the outside via two connections resulting in this pair of batteries and resistances being at right angles to the source of the reaction. And the voltage of the surrounding alternations, or oscillations, must be equal to or greater than the highest voltage among this pair of batteries. {See, picture, attached below.} In my case, the capacitors are the source of reactance especially since they're not needed for the circuit to work, anyway. Nor are the neon bulbs needed. This last component was added to thwart arcing at the commutator when this circuit – in its earlier stages of development – was being used to simulate my guess estimate of a Newman motor. Since there's no source for arcing to occur, this attempt at displacing arcing away from one place and into the neons is no longer necessary. Nor are the capacitors needed for this circuit to continue to put out the same level of amperage and voltage. Thus, this circuit can be reduced to merely four coils, two aerials, and one resistor in place of the two that are located alongside the batteries.
                      It's further unjustified to expect that 1.6V can be gotten from an aerial tuned to 1MHz. Since higher frequencies hold more energy hidden within their higher frequency, it is safe to assume that reality would dictate their voltage level would be less than that of lower frequencies to compensate. No free lunch, here.
                        I stand corrected. Unlimited gain without batteries is possible.
                        Specific to my circuit.....
                        .... and not intended to be generic for all cases......
                        I was beginning to have doubts whether my latest simulations are at all accurate. I was right. They're not entirely accurate for their lack of a load. I had to research online to remind myself what I had already used months ago: an A/C source of voltage to simulate a load plus the use of resistors.
                        What I discovered, to my surprise, is that unlimited gain is possible based on two simple premises: increase the self-induction of the main coil and increase the value of the resistor placed inline with it to juggle the proportional ratio of current to voltage.
                        That's it! Incredibly simple, yes?
                        It makes sense since the motor in these simulations doubles as its own step up transformer.
                        Hint: 2.6V from an aerial may not be possible without intervention from a booster subcircuit. And 1Meg Hz implies a sinewave generator powered by either an aerial or else a small solar panel. This latter suggestion comes courtesy of Byron Brubaker in his conversations with Joseph Newman.
                        Category:Motor–transformer
                        From Wikimedia Commons, the free media repository
                        Download Inverted EV Motor -- Micro Cap simulation --View Contents
                          Do I have permission to post your newspaper clipping to WikiMedia Commons?
                          I'd like to post this image of yours to WikiMedia Commons and include it in my gallery page devoted to Motor Transformer at...
                          Motor transformer - Wikimedia Commons
                          May I? I'll list you as its author using your moniker, here. I think it's very important piece of evidence to the Ammann bros. authenticity.
                          • #14
                            Yes, sure.
                            • #15
                              Done!
                              Yes, sure.
                              File:Ammann Bros. newspaper article.jpg
                              This I did to support the important video I uploaded there describing my epiphany discovery of how the Ammann EV managed to harness the air as they claim. I further claim that Tesla replicated their handiwork ten years later (as the Pierce-Arrow demonstration of 1931) to which the brothers never received any of the credit. For, hidden inside of Tesla's project box were two evacuated spheres with a heavy cable connecting each separately to his simple circuit and motor as per my simulations are suggesting. They have to be heavy gauge in order to reduce their resistance, again, as my simulations suggest.
                              Simple...
                              1. Evacuate the hollow bronze spheres to duplicate atmospheric conditions at higher altitudes in which the air thins out and replicates a similar action whenever the dielectric of a capacitor is thinned, thus increasing capacitance in both instances and a resulting rise in voltage stored in both cases.
                              2. These spheres function similar to a electric guitar (in principle) in which an electrified metallic string is stretched across each sphere's interior diameter placing it under tension. In the middle of the string may be a quartz crystal sliced to become a piezoelectric oscillator. And, maybe, on the interior side of each sphere opposite the sealed orifice where the wire exits each sphere there is attached a carbon button serving as a pickup microphone. Voila!
                              3. We have, here, an antenna with a mild boost in its ability to gather voltage from its environment.
                              4. Plus, we have an electric amplifier for boosting its output signals.
                              5. And we have an acoustic amplifier resulting from the hollowed geometry of each sphere.
                              6. And, it spontaneously produces high frequency sinewaves.
                              Pretty cool, huh?
