Nikola Tesla’s Turbine Secrets - Global Open Source Project
  • soundiceuk
    https://drive.google.com/file/d/1oAp...M9IvL7yYJ/view
    https://drive.google.com/file/d/1htl...VBdUKEZIB/view
    https://drive.google.com/file/d/1yuB...bTGUeP5gx/view
  • soundiceuk
    The replicator who is building to my spec (Tesla's spec) wrote this to me!
    "I have no doubts we can build it to run on atmospheric air, when you first told me it took a bit but it clicked in my head. I saw it happening. I can visualize when I lucid dream, images clear as day. It takes me longer to do prototypes, because my limited situation. I wanted to tell you something that happened when I added a load, some resonance thing happened, when I was loading it down more and more it started to speed up without additional pressure, I was literally burning through hard wood faster than in the video. ALL The Sudden I heard a pop, a puff of vapor exploded out of the turbine. then another pop, then another one. You know how the air has moisture in it and the exhaust is constantly sucking in atmospheric air, IT INSTANTLY CONDENSED THE AIR INTO VAPOR CREATING A HUGE VACUUM! That,s my theory of what happened, we are so close."
  • soundiceuk
    I found proof in one of Tesla's patents that this turbine can run on atmospheric air.
    US Patent 1,329,559
    https://patents.google.com/patent/US1329559A/en
    Page 3 Line 96 - 120
    "Upon the subsidence of the explosion the pressure in the chamber sinks below the atmosphere owing to the pumping action of the rotor or ventilator and new air and gas is permitted to enter, cleaning the cavity and channels and making up a fresh mixture which is detonated as before, and so on, the successive impulses of the working fluid producing an almost continuous rotary effort. After a short lapse of time the chamber becomes heated to such a degree that the ignition device may be shut off without disturbing the established regime. This manner of starting the turbine involves the employment of an unduly large combustion chamber which is not commendable from the economic point of view, for not only does it entail increased heat losses but the explosions cannot be made to follow one another with such rapidity as would be desirable to insure the best valvular action. When the chamber is small an auxiliary means for starting, as compressed air, may be resorted to and a very quick succession of explosions can then be obtained. The frequency will be the greater the stronger the suction, and may, under certain conditions, reach hundreds and even thousands per second."
    Also here a newspaper from The New York Herald October 15th 1911
    "The Tesla Collection" - "Tesla's New Monarch Of Mechanics". NEW YORK HERALD, October 15, 1911
    These are two of my many of my pieces of evidence pointing towards an almost forgotten technology that was invented just before two world wars.
    The ultimate energy source can easily be seen by the first 20 seconds of this video.
  • soundiceuk
    If you read the articles, patents, writings, drawings and photos of after the period of Wardenclyffe and Radiant Energy, they paint a different picture to what you have written Citfta.
    The Tesla turbine has been so misinterpreted it is going to take a while to undo the misunderstandings.
    I am being led by evidence from Tesla, not by my own ideas.
    Please allow me to present my findings and have them criticised.
  • citfta
    The one-way valve is just that. A one-way valve. It will do nothing to cause the turbine to run away. And although the turbine is a marvelous invention of Tesla it will not run off atmospheric pressure. It has been used now by industry for many years since they finally discovered how much more efficient it is. It also needs much less maintenance than any other turbine because it can stand some wet steam which will destroy a regular turbine. But there have never been any reports of one of them running away. They also make excellent pumps for pumping all kinds of liquids. I understand the oil industry uses a lot of them as pumps.
    Respectfully,
    Carroll
  • soundiceuk
    Originally posted by Cadman View Post
    You seem to be saying that if you add the valvular conduits then once the turbine is running the compressed air supply can be removed and the turbine will continue to run and make power.
    Is that correct?
    After initial starting of the turbine, what I see is the device self running and self sustaining with no valve!
    Also after initial starting, what I see is with the valve fitted it can run away and implode if left to cascade!
    We all need to see this with our own eyes for it to be real, but it appears to me that this is within our grasp according to my research and Tesla's writings, articles, drawings and patents.
  • soundiceuk
    Hi Cadman, I've been a mechanic / auto electrician for 21 years.
    I have done lot of exhaust back pressure testing over the years.
    When the customer complains vehicle won't go over 30mph, it won't rev up.
    The test that is carried out is to remove the upstream O2 sensor and insert vacuum gauge.
    The results shown in the previous video show me that the gauge is reading back pressure.
    Simple way to prove it.
    a) fit a vacuum / pressure boost gauge
    b) unhook the compressor
    I'm giving tips to the youtuber on his setup.
    I have already advised this.
    I'm like you, waiting for the video.
    Something else happened that we were not expecting.
    A video is being done to show that too.
    Hopefully I'll have something to show today.
  • Cadman
    Hello Soundiceuk,
    Is that correct?
    I do not see any possibility of this so far. This video shows positive pressure at all times. At 5 psi gauge that is 5 psi above atmospheric pressure or about 19.5 psi absolute. In order for this to self run it would have to have a means of compressing ambient air to 19.5 psia or re-compressing the turbine exhaust to the same. Alternatively it would need to have a means of maintaining a 5 psig pressure drop at the turbine exhaust.
    Would you care to elaborate on your method for accomplishing either of these?
    Cadman
  • soundiceuk
    After a little direction from me about how to make the turbine case, here we have the next build.
    Anyone familiar with exhaust back pressure will have a clue what is going on here.
    The turbine appears to now be able to run on atmospheric with no valve. It will self regulate according to the 1,061,206 patent.
    With the valve it will need to be controlled with the air tap or it will run away!
    https://www.dropbox.com/work/Team%20...201_182238.mp4
  • soundiceuk
    If you want to understand the energy source we are going to tap with our Tesla turbines.
    Watch the first 20 seconds of this video:
  • soundiceuk
    Tesla Turbine 2018 - © Copyright 2018 - Global Open Source Project
    After reading all of Tesla's final rotor design patent.
    We can use a single disc with no holes.
    Tesla writes that if you use an even number lets say 15 discs. The centre disc doesn't need exhaust holes.
    The other 14 discs would need exhaust holes.
    If the rotor has 10 discs then they would all need holes....
    Makes for good balance.
    I'll post the CAD files soon.
    Some off the shelf components for my 150mm 3D printed or milled design.
  • soundiceuk
    I spotted this build a few days ago.
    I left a comment saying to encase the turbine blade in a cylinder in order to get a vacuum.
    Now look what he has got!
    Next comes the one way air valve!
  • soundiceuk
    Here is a cleaned up version of Tesla's final turbine rotor design.
    British Patent 186,082
    Improvements in the Construction of Steam and Gas Turbines
    https://www.dropbox.com/s/g2vfgf94j5...86082.pdf?dl=0
  • soundiceuk
    Here is a high resolution cleaned up version of Tesla's one way air valve.
    This component is critical if you want to run on atmospheric air pressure.
    https://www.dropbox.com/s/5dmdav7f1m...Valve.pdf?dl=0
    Here is a video done by one of the youtubers that listened to my advice on the exhaust.
    The exhaust is critical to making high vacuum.
    All he needs to do now is add the one way valve and an air tap.
    Adding the 1,061,142 patent turbine onto the exhaust will amplify the output.
  • soundiceuk
    Maybe gear up a motor to spin the shaft of one at high speed while pumping water and see it at a certain speed the motor becomes unloaded. That might be a first basic test. Maybe some others with experience with Tesla Turbines can comment??
    If you look at the patents 1,061,142 & 1,061,206 as one patent, they form one machine incorporating two turbines.
    The first turbine extracts the air from atmosphere using vacuum, the next turbine pumps the air out of the first turbine.
    The second turbine is an amplifier.
    The 142 patent even fits the 206 patent. Tesla left a hole in the bottom of the casing on the 206 patent for the 142 to fit.
    The part numbers start at 1 on the 142 patent and go up to 12. They continue on the 206 patent from 13 and go up to 29.
    It is secretly one patent and one machine. With many possible configurations.
    The main function that has been hidden is it's ability to run on atmospheric air.
    DO YOU THINK THESE PATENTS WOULD EXIST IN PUBLIC DOMAIN IF TESLA WAS COMPLETELY TRANSPARENT?
