Hi all, Hi bromikey, here is the idea that came to mind the other day.
Think it fits this thread a little, since it is using a similar magnetic field nullifying concept or magnetic balancing act, to gain greater efficiency, maybe.
peace love light
Originally posted by Turion View PostSpeed up is only bad for ME in MY particular application. Doesn't mean it is bad for what Thane is doing. The proof, is ALWAYS on the bench. You never know until you build it, and I would bet there are a variety of designs that could take advantage of it in a way I never dreamed of. THINKING you ABSOLUTELY know how something is going to work when it isn't running yet is a big mistake unless it is a perfect replication of something that has been previously built and tested. You never know what the result of a small change is going to be. You can make some objective suppositions based on prior experience and material analysis, but then some unexpected reaction happens and everything you though goes out the window.
Speed up is only bad for ME in MY particular application. Doesn't mean it is bad for what Thane is doing. The proof, is ALWAYS on the bench. You never know until you build it, and I would bet there are a variety of designs that could take advantage of it in a way I never dreamed of. THINKING you ABSOLUTELY know how something is going to work when it isn't running yet is a big mistake unless it is a perfect replication of something that has been previously built and tested. You never know what the result of a small change is going to be. You can make some objective suppositions based on prior experience and material analysis, but then some unexpected reaction happens and everything you thought goes out the window.Last edited by Turion; 05-27-2020, 11:47 PM.
Originally posted by Turion View PostIf you don't mind Bro,
...........the only difference was the voltage on my battery had gone down a bit and the rpm of my motor was just 10 rpms different and I didn't realize how significant that was. In truth, ONE rpm is enough to cause failure if you are right on the line.
In electric vehicles one of the big problem to save energy was by using a gas engine to hold rpm perfect. From there clutching/transmission took over from there. The Thane style gen head uses both the null and beyond (small amounts) to overcome the ever changing rpm for in town driving. When I bring up CRITICAL MINIMUM FREQUENCY it seems way to much for many to grasp alongside all of what is being talked about (to much)
Whether you are gaining kinetic energy or just raw watt harvesting does not make one BETTER than the other as you seem to suggest for years. It is a matter of what the need is. Watching a slight speed up under load is important to the observer who does not yet comprehend your specific contraption. Presenting speed up as a bad omen is funny. I refuse to address the idiot in the debunk video he is nothing more than a propLast edited by BroMikey; 05-28-2020, 03:24 AM.
Originally posted by Deco56 View PostFound this video claiming to refute ReGenX. Can we get a response from Thane?
https://www.youtube.com/watch?v=kfRxsC9yumQLast edited by BroMikey; 05-27-2020, 10:26 PM.
As USUAL bi, you choose to see the part of my post you WANT to see and ignore the rest. The video shows that the input and output to a "speed up under load coil is the same as with a single filler coil when the system has not been tuned for the "speed up under load coil." I already KNEW this. Figured THAT out YEARS ago. MY systems ARE tuned. You either adjust the number of magnets on the rotor, change the length of the wire on the coil, or adjust the rpm of the rotor by slowing down the motor. All three will work.
What the video does NOT show is that the "speed up under load coil's MAXIMUM OUTPUT is when it is neither speeding up nor slowing down, which is what I have said all along. I addressed YOU in my post because you posted that video first, and it appears you are dragging people down the road to stupid land with you. You guys are like crappy magicians. You try to misdirect as best you can, but everybody knows what you have up your sleeve.
You have said in the past that not even I have replicated my device. You forget I have built 16 different versions of the generator, each one a mechanical improvement over the prior one. So I HAVE replicated the machine and seen it working. Greyland has seen it working. Lots of folks have seen it working. Just not YOU. And you have no idea how happy that makes me. LOL
Originally posted by Turion View Post...
bi, ... Speed up under load is a cute trick, but it doesn't get us what we want.
That sentence which I quoted above is the same as I've been telling you. As to the rest of your post, it really doesn't matter if no one, including you, can ever replicate and reproduce your device and claim with documentation and proof. Otherwise it remains the same baseless claim as it always has been.
And the video was posted by Deco56 this time, not me, although I have posted it lately. I happen to think that it debunks Thane very well. You'll debunk yourself when you can never actually produce proof of your claim.
If you don't mind Bro, I will be happy to respond to bi and his "amazing" video. I do not necessarily have the same purpose for the coils in MY generator as Thane does for the ones in HIS, but I know how the coils benefit ME.
bi,
You are forced to rely on the experiments done by others because you do so FEW actual experiments yourself. If you ever actually DID any experiments, you would be BEYOND what is shown in this one, which is elementary. Do you think I haven't done EXACTLY this experiment? Not once, but HUNDREDS of times with different coils? Do you really think he is showing anything I haven't seen before? Believe me, he isn't. You think what he shows proves we don't know what we are talking about. All it proves is that YOU don't understand. You're stuck in a box.
I have said MANY, MANY, MANY times that when you are seeing "speed up under load" you are NOT seeing the MAXIMUM OUTPUT of your generator coil. Go back and actually READ what I have posted and you will see that is EXACTLY what I have said. MULTIPLE TIMES ON DIFFERENT THREADS. Speed up under load is a cute trick, but it doesn't get us what we want.
So if we take the EXACT same circumstances we see in the video, the author is showing apples to apples where the "speed up under load" coil and the single filler coil both PUT OUT the exact same amount of power and basically the input power to the two coils is the SAME. But if we want the speed up under load coil to exhibit its MAXIMUM OUTPUT, what do we have to do? We have to DECREASE the rpm's of the motor to the point where the coil is neither speeding up nor slowing down. This means LOWERING the voltage supplied to the motor. If you lower the voltage, what does THAT do to the input? THAT is the ENTIRE BENEFIT of the "speed up under load coil" I am using in my generator. I do not WANT speed up under load. I want maximum output for MINIMUM input. Nothing he shows disproves what I have said about the coils and the way they work in my generator. Your belief that he is "debunking" these coils just shows how little you really understand of what we have been saying, because he does a DAMN good job (almost) of comparing apples to apples and you bought the whole thing.
Now Thane may dispute what the video shows. I don't. I never have. I understand EXACTLY what these coils do because I have done HUNDREDS of experiments. I don't rely on ANYONE to do the experiments for me. Neither should YOU.
What this video DOES show is why the RPM of the motor is as absolutely CRITICAL to the success of the experiment as are the coils themselves. A few feet off in the amount of wire you MUST HAVE in either direction, and your coil isn't outputting at maximum power. It took me a lot of beating my head against a wall and not understanding why a perfectly good coil I had just wound was NOT giving me the same results as the LAST one I wound the exact same way, when the only difference was the voltage on my battery had gone down a bit and the rpm of my motor was just 10 rpms different and I didn't realize how significant that was. In truth, ONE rpm is enough to cause failure if you are right on the line. I learned a lot of stuff the really HARD way that I have given away here for FREE, and still people don't listen.
If the guy who did the video would adjust the motor speed until the rpm of the motor does not go up when the "speed up under load" coil is shorted and then compare the single filler coil to the "speed up under load coil" at that same speed, you would see a TRUE comparison of inputs vs outputs.Last edited by Turion; 05-27-2020, 08:00 PM.
I posted proofs of what I claimed. ........ but actually you're just an annoyance.
Answer or just change the subject? Address the subject matter, recognize the questions coming from your fellow mates. Have a heart? Is that possible, plz explain your position, if not.
Why are you lying about others lying??? Isn't THAT a lie? Or did you tell us the truth? Plz explain. Can you answer? Hey Google dot to dot to dot answers better. Hey Google?? Hey BYE??
BYE did you say that? Why without experimental proof would you say such a thing???? Are you answering questions BYE?? Answer the question BYE Now that we all know that you are all hot air we can put up a protective shield against hurting our feelings. Do you have feelings BYE???
WTH is BYE's problem?
I was about to say that you're my problem but actually you're just an annoyance.
When a north pole facing permanent magnet on a rotor approaches a ferromagnetic core, that core end will be a south pole and the generated polarity in the coil at that same end will be a north pole.
something that came to mind yesterday.
peace love light
Also when generators don't slow down under load more power is realized. I have a 50 strand coil and running 1500rpm I reach the null at 720 feet of wire when 72 foot strands are laying together connected in series. So a mere 10 strands of my 50 are needed. The null is when a load is connected and the system does not slow down demanding more input power. The relationship for today's generators demand a 1000 unit input to get a 600-700 unit output. Each load added shows this same relationship
With these Tesla coils from electromagnets our generator input is zero for each additional output load. So that means 0 input to get out infinite output once the rotor operational cost have been established. Each added load shows no increase for input.Last edited by BroMikey; 05-27-2020, 03:03 AM.
I never said that. The second part--"the magnets are a waste of time and give you no additional output" is true.
@ Turion
You were right Dave. Let me put it this way. Induction motors want speed. You can turn down the volts and with the right cap as we have seen in my setup, lower the amps UNDER LIGHT LOADS. BUT the motor wants to turn at full speed or 1600rpm so if there is drag of any kind the amps climb. I will give an exact RPM reading soon, 2 meters are in the mail. However this can be witnessed without a meter. I have readings today of 50v X 600ma with the opposition magnets FULL SPEED or full RPM, turning it up make no difference.
Without magnets to oppose cogging drag I have readings that measure as high as 100v at 1= amp or 1100ma. Go figure. You are the man Dave. Everyone here loves and honest answer. WTH is BYE's problem?
Hi all, Hi bromikey, yes, will make a simple cad drawing of the idea, been busy with some other things at the moment, will get to it as soon as possible.
Yes, it seems that by my direct experience and observation, in these past couple months, (AKA- the cootie thing), that it could not be more obvious, this A.I., matrix or whatever it is, indeed wants us to act like them and become a zombie also, well it aint happening my friend.
God wins always and god is good.
Almost forgot, wanted to mention something in general about generator coils with ferromagnetic cores.
That seems to be defeating our efforts to generate output, because then a certain amount of the generated magnetic field from the generator coil will be neutralized by that opposing field in the core.
Well, just something that came to mind yesterday.
peace love lightLast edited by SkyWatcher; 05-27-2020, 01:50 AM.
Originally posted by Turion View PostAccording to bi, there is no cogging at speed, so the magnets are a waste of time and give you no additional output.
What I have seen is that the magnets cause less amp draw by the motor. Increased rpm, and therefore more output by the generator coils. But that's just me.
