This is what I need to drill. It is an over grown drill press without all of the shimy shivering and shaking on a 1" hole.
https://www.sterlingmachinery.com/me...3959ee0254.jpg
I like this machine. It is a smaller one for machining holes. I am looking at a shorter one.
$2400
https://i.ebayimg.com/images/g/yI0AA...jf/s-l1600.jpgLast edited by BroMikey; 08-11-2020, 09:34 AM.
For you guys wanting to save the world? Start at the beginning. Nuts and bolts first. Get the tape or ribbon as you wish and buy 1k107 model number. Nano tech ribbon rolled up in 8" square cores and cut the sides out for block material if you like. Use ultra high temp, very very thin solution lightly wetted and wiped of clean. Roll up your bobbin. Bake at 250 f for 2 plus hours. Now you have any shape.
This material will work best without generating heat in cores unlike the 1k101 material used in 60 hz cores. The 1k107 tape is more for 400hz and up a ways..
Rotors need to be non magnetic steel or magnet shielding steel. Use 1/4 plate ss machined to press fit magnets into place leaving a fraction of magnet above the surface. Use a 1-2" shaft to maintain stability use such forces. The shaft may be a grand total of 12" long. Use ss beaings, ss shaft, ss collars, they are worth the money. SS rotor hubs. SS bolts.
https://www.ebay.com/itm/Fiberglass-...72.m2749.l2649
This material is cheap for making boxes coming in at 6 times less for poly carbonate or cutting block board and is as strong as steel yet non magnetic.
The average inventor came not see this idea so a video was made to help with brain freeze.
If you disagree now in the end you will. Not everyone has the IQ so it takes time. Hang in there and you will be riding in one soon. You will probably shake your head then too but it will wear off. A vehicle so equipped parked out front of you home could be used to lower your bill.
“The ReGenX generator’s load current delay reverses and eliminates 100% of the negative effects of generator armature reaction. Because generator armature reaction is removed, 100% of the input power required during electricity generation is also removed forever!
This video is proof that the rest of you do not listen or know what you are talking about yet still willing to discredit Thane. Another foolish thought on the part of the ignorant. I hav been explaining this very nicely for 6 years, no more because most of you can't hear when people talk softly. Hard heads rarely learn, all they see is themselves, everyone else is wrong of course, another strike out king.
Sit down and listen, realizing you do not know the correct answer. Don't argue.
High end RPM setup that uses one 60 tooth gear, a meter head and a probe. The readings off of the 10 pole rotor are most accurate for the time being. I went down to slow speeds of 170 (meter) X 6 = 1020 rpm and I am seeing how this equipment is dsigned where the way it is without the gear the probe is counting frequency in hz which is a 1 second measurement and why the 6 tooth gear is added which represents 60 seconds X the freq = RPM
Another medium speed shown a freq count of 220 X 6 = 1320 RPM normally the way you should be looking at the other number of 26 or 27 as it bounced for a single point on a shaft like a bolt head then X 60 because a 60 tooth gear is used to complete the system. So then 27 X 60T = 1620 RPM for a 270hz reading. This is a counting machine. Next I ran many other test and will show hard data. One test was max speed at 295hz so then we say 295 X 6 = 1770 RPM I used the number 6 as a multiplier this time because the rotor read 10 nodes already which are the 10 magnetic poles for a total multiplication factor of 60. Remember a 60Tooth gear is require to get the best accuracy.
