Turion
I I believed Tesla wrote somewhere that for better efficiency the load should be between two positives. I'll look it up, I could be wrong.
And for some reason this circuit shows better efficiency than conventional one, i saw that here and on YT some examples.
regards
Tesla had NOTHING to do with the Tesla Switch. Ronald Brandt designed it. Bedini modified it. The original name was POSSIBLY the Brandt-Tesla circuit. It was presented by Bedini at the Tesla Symposium. Then it became the Brandt-Bedini Tesla Switch and now the Bedini-Brandt Tesla Switch or just the Tesla Switch. At least as far as I have been able to discover. Everyone has their own take on history.
Basically, all current flows through the negative line.
So that line should be heavier than the positive line, if it's not heavy enough already.
That should be something as the first thing to do, the rest may know better those who practically experimenting.
I think this thing with three batteries, running load between the positives, has something to do with flow of the current, Conventional vs. Actual flow.
Conventional Current assumes that current flows out of the positive terminal, through the circuit and into the negative terminal of the source. This was the convention chosen during the discovery of electricity. This should be wrong. Electron Flow is what actually happens and electrons flow out of the negative terminal, through the circuit and into the positive terminal of the source.
So when you run a load between two positives, how do the electrons flow?
Today I tested something practical that I was able to apply to fuel saving on my cargo van. The average mpg is 18-20 mpg tops. It is an Astro v6 about 5000lbs. I do not have it autofill yet nor heated but still it is a vapor carb. I am testing it on my generator and log splitter. The splitter is a giant 40 ton ram connected to a straight 6 cylinder year 1962. It was freshly rebuilt and runs good. It eats crazy amounts of fuel. I tweaked the jets but it sucks way to much. Plus it stinks bad while we split.
This first test was not on the motor generator, it was on an Astro motor. I started in the yard setting the vapor carb (all stainless) on a stump with the engine idling I made some air intake adjustments to see if she would percolate. Low and behold it did. I revved her up and she stalled so I added some bronze wool to arrest any large particles.
I put a quart in it as this is all it was designed for. Next I drove it 30 miles and the tank was dry. The mpg was hard to judge so today I had to take a long voyage of 140 miles to see the blood Doctor. One way is 65 miles and I needed to go to tractor supply and home depot. So not having a refill yet I put my quart in and it ran out half way there. On the way home I filled is up with another quart. When I drove there last time gas was $5 plus so I put in $40 hoping to have some left over. Not much survived just a little past E.
This time gas is just under $4 so I deliberately only put in $25 thinking I'll put more in when I get there if I need to. I put in less than would normally be needed to have a little margin left over. Even with the quart vapor carb going dry half way each direction I still had $10 in the tank when I got home which is 1 quarter of a tank. My son wanted to drive to the corner store for an energy drink so I road shoot gun. I asked how much gas is there? He said just above 1/4 tank.
$15 burned plus the 2 quarts in the vapor carb works out to 35-40mpg That is where I will be speeding time. The generator is coming powered by the Lindemann S rotor. Before it gets cold I am doing what Dave did for years, cement. I bought and modified a chipper to mulch straw down to 1" to 1/4". I did that last week. Success. Today we built a $200 wooden form 7 feet long 9 inch thick by 30 inch wide. The form stands on the edge. The mulched was digested in a 55 barrel using fly ash for several days.
This takes off the shine on the straw blades and together with portland, sand and the fly ash total 30% with 70% straw or fiber, as you wish. Half barrel troughs were cut and are placed on iron bar style frames I call tables so kneading or mixing can take place tomorrow.
I almost died in Nov 2021 so I don't have time to do things that don't give me anything back but a bunch of wasted years. You will all see something worth while now.
Have fun on your never ending goose chase. Not me. I have my SSSG to work on now that is a free energy converter.
