  • BroMikey
    Originally posted by Minsky View Post
    BroMikey. It's a huge mistake to try and argue with the gasbags offering to show the battery as the energy source in Clarence's replication. They wouldn't know energy dynamics if it bit them in the nose.
    Thats a fact.
    Here is a tutorial for our underclassmen, maybe we can bring them up to speed
    https://www.youtube.com/watch?v=wimTJw_Gpgk
    https://www.youtube.com/watch?v=PI9kAWQ_s4w
  • Minsky
  • BroMikey
    Battery 101
    Okay let us continue in the vane of rational thought.
    That vane being that it works rather than it doesn't work.
    Working from this premise we need to study our battery in Clarence
    setup. The battery is a 60amp Hour marine type battery if I am not
    mistaken.
    Many of you have never had a battery connected to an inverter trying
    to run lights or fans off of it, so it is important that you do that, if you
    are ever going to become proficient at closing the loop on many free energy systems.
    I hear those on this thread making statements that do not add up to the
    practical aspects. For instance listen to John Bedini, one of my teachers
    talk about battery size and rates of discharge and recharging values.
    https://www.youtube.com/watch?v=Mgjn-Eubyoo
    John B. is one of many intellectual minds who is very advanced concerning
    battery technology. The first thing needed to advance battery tech is to understand normal battery systems available for the past 100 years.
    Clarence battery is no different, nothing magic in his battery.
    Just a normal C20 rate 60ah battery. I have the same ones like Clarence that are 100ah batteries. These batteries are nothing special in fact my 100ah battery only gives me 35ah before it reaches 10.5vdc every single time.
    And what might be of importance to those of you who really want to understand is that the only way I can get those 35 ah out of this one hundred amp hour battery is to divide those 35ah by C20 or a 20 hour discharge period.
    If you can not understand this portion of the study and you are all out of breath then you need to go to an easier replication. Oh Bromikey is insulting us again. Nope just making sense out of who is running the calculations.
    If you can not give me a definitive answer about normal battery inverter
    operation then you do not belong here judging this project.
    Okay 35ah divided by 20 = 1.75 amps. That is correct 1.75amps and no more if I want to get the full ah rating of 35ah. Clarence battery will be about 25ah divided by 20hrs = 1.25 amps. 1.25amps discharging and no more to get the full 25ah out of that battery.
    I have 100 batteries I should know. Some of my batteries are converted to ALUM also and this is a huge improvement often doubling or nearly doubling capacity though it takes double the joule count to charge it back up again.
    Now here is what happens when you exceed the 1.25amp draw. As the battery is called upon to provide more amps than the factory rating allows
    internal heating occurs in the form of chemical friction. This will lower Amp Hour capacity up to as much as 40 percent less.
    If we pull 6 amps from Clarence 1.25amp battery rating the battery also will
    degrade faster, meaning he will have to keep replacing his battery all of the time due to the abusive demands.
    Almost everyone here making comments about how all of the energy comes from Clarence battery is showing us as a group that they have no practical common sense concerning battery, inverter operation.
    My recommendation is to get a camping inverter pure sine wave and buy different types of batteries to run so you can make an educated guess in the future. Until people can make these steps no others are possible.
    That is why I have been listening to John Bedini, because John is very much aware of what is needed to close the loop on many energy extraction devices.
    Here is a video also of the approx same size battery as Clarence has running a 500 watt light. I have done this many times using those junk batteries or NON TRUE DEEP CYCLE batteries. By the time the video is ended he is ready to recharge his battery becauce he is demanding 40amps off his tiny battery, it looks like a 100ah truck battery.
    https://www.youtube.com/watch?v=jV5suWI_KqY
    Until people make common load tests they have no idea what they are talking about.
    Here is a Microwave Oven running off of Clarence size system calling on the battery at 100amps. He fried the battery in 5 minutes.
    https://www.youtube.com/watch?v=1ZhrqvYBqCE
  • level
    Originally posted by a.king21 View Post
    If you read Patrick Kelly's pdf, he explains it in detail there. It is not connected to the grid. It uses the principle of electrostatic induction.
    He mentions the grid to emphasise that the grid is used as a dipole only.
    No electromagnetic induction, no direct connection to a hot or neutral at all.
    I will trust more what is shown and explained in Matchett's own video. Patrick Kelly may have misunderstood if that is what he said. My guess is you won't see the same results if you use a battery and inverter. I could be wrong. Back to Barbosa and Leal.
  • shylo
    The rods
    How many rods does it take?
    Whats the optimum spacing?
    I could never get the rods to add together, they put out ~ the same amount.
    I never put juice into the rods ,I just collect off them. But its' miniscule.
    Does putting a certian amount in give more out?
    If Clarences' system works ,To me it's just a matter of turning the lines of induction 90 deg. to the primary input.
    Input north & south take off east & west??
    Is that even close?
    artv
  • a.king21
    Originally posted by level View Post
    Ok, I have already commented on that video, but anyway,
    this is the original copy of that video posted by Lorrie Matchett:
    Free Energy Device ( the 3rd generation ) - YouTube
    It is hard to follow what he is doing because he didn't show a connection diagram, but from what I can gather the board with the plugs on it is powered 'from the grid', i.e. it is plugged into a wall socket, off camera.
    This is what I get from the video:
    He first plugs in the little night light bulb into an AC plug on his board and measures the grid current as around thirty something milliamps.
    He then plugs in the LED string into the other plug, and the current goes a little over forty milliamps.
    He then unplugs the LED string and plugs the LED string into the output of his device, and then plugs his device into a plug on the board.
    He shows that the grid current doesn't increase in his measurement. It is not clear which wire he is measuring the 'grid current' on, but I guess it was the hot wire.
    The caption on the video reads:
    "CURRENT DRAW ( from the grid ) Zero..."
    It seems to me he wouldn't specifically say in the video that he is measuring the current "from the grid", if he wasn't plugged into the grid, AKA the mains power.
    In the end of the video he has disconnected the multimeter from his little AC power board, which opens the circuit on the power board, and has connected to the output of his device to measure the DC output volts of his device.
    He plugs his device into a wall socket because the board with the plugs on it has an open circuit due to the multimeter being disconnected from it.
    That is how it appears to me in the video anyway, as best as I can tell. He could be powering from an inverter, but he did mention in his video caption that he was measuring the current "from the grid", so that is why I think that is what he was probably doing, but I have already explained this previously when I pointed out that he specifically mentions 'the grid'.
  • level
  • a.king21
    There is no connection to the mains.
    https://www.youtube.com/watch?v=hJyZ...ature=youtu.be
    is the one I'm talking about.
  • RAMSET
    A quick note to dragon
    Thank you
    I understand...
    This Ferro resonance has been actively investigated for quite some time [as it applies to NMR],your observations and insights are greatly appreciated.
    respectfully
    Chet K
  • BroMikey
    Take the first step
    Taking the first step means reading about the invention. The next step is
    finding out how the Patent hides the secret.
    Nilson BARBOSA, et al. -- Earth Energy Generator -- 4 patents
    GENERATOR CAPTURE EARTH ELECTRONS
    Equipment electromagnetic generator that captures electrons Earth
    It is an electromagnetic device that depending on how the connection to be connected to the grounding grid becomes free to move and capture particles energy to perform work instantly via electromagnetism. The sensor requires only a small initial force energy continually being supplied by an external power source , which can be provided by the local power utility . With this small amount of electricity consumed the sensor generates a large electromotive power . Depending on your constructive manner , the sensor can generate a power thousands of times greater than the energy that was consumed to perform the work performed and generated by the sensor , this energy that returns to the generating source ( Earth) . Use : Industrial , Commercial , Residential .
    SELF-POWERED SYSTEM FOR ELECTRICITY GENERATION
    Electromagnetic equipment that generates electrical energy in a closed loop between themselves .
    It is a mobile or landline that instantly captures electrons through the compo electromagnetism, requiring only a small initial force energy, for a few seconds. Thus is reached closing the loop using the electromagnetic force present in the universe .
    The system comprises rectifier ( AC / DC converter ), battery bank , inverter ( DC / AC ), and the captors of electrons in the headspace or electron captors land
    Being a compact and mobile system that can be designed to provide electricity to low, medium or high power at any voltage and frequency.
    The invention relates to a device that comprises at least three sets (A, B, C, D) of at least one device for generating an electromagnetic field (3) and (4), powered by an electricity source - without a core or with at least one core - the cores thereof or any extension thereof, preferably the windings or sets of windings thereof, being surrounded by at least a single conductive element forming a polarized and energized closed-circuit with itself (5), said sets of electromagnetic-field generating devices (3) and (4) being linked together by the opposing poles thereof to encourage the interaction of the electromagnetic fields thereof, which are preferably allocated between two hollow metal half-spheres (1) so as to concentrate and enhance the electromagnetic fields thereof, these interconnections causing, as a novel technical effect, the emergence of an electrical current that circulates, with or without voltage, in the conductive element forming a closed-circuit with itself (5) - point of the connections of the external loads - even if no load is placed thereon.
  • level
    I don't know what you are looking at, but I explained it clearly enough. He said in his own video Description section comments that he was connecting to the house wiring/grid, as I mentioned. Mr. Matchett also added comments to his two videos to hold off on building his setup as he wasn't so sure any more about his free energy claims. Why not take a look at his own videos and comments? I posted the link. Then you can see what Mr. Matchett actually said himself. Someone must have explained to him about the ground loop problem when connecting to the mains, so he posted an update to his video descriptions about not building his setup. If you have some valid reason for thinking otherwise, state your reasons, but please watch mr. Matchett's videos first and read his video description comments and all should be clear.
    Edit: Are you sure you are talking about the same device and schematics I am talking about? It should be clear from my comments which one I am talking about however...
  • a.king21
    Hello a.king21. I have seen Lorrie Matchett's couple of videos on this a few years ago and I remember he mentioned that this works from the 'house wiring'. In his other video he mentions that he was measuring current 'from the grid'. Based on this and from looking at his schematic I realized right away back then that what he was doing should be a ground loop in the mains.
    If you look at his video description section for the following video of his, he mentions the following:
    "It allows you to extract free electricity from your housing wiring, enough to power a string of 30-blue led mini lights and more..."
    Free Energy " One of a Kind Device " - YouTube
    If someone can get his setup to work with a battery and inverter and a connection to earth ground, then that would be something worth looking into further, but by Mr. Matchett's own description he was using the house wiring, AKA the grid, AKA the mains.
  • level
    Originally posted by Bob Smith View Post
    I'll post something I posted to another forum dealing with the B&L apparatus. It's a response to someone looking for a translation to a Spanish language video claiming to reproduce the B&L setup:
    Hello Bob Smith. I have watched Hibridor's videos before and he also seems to be using the mains hot wire to go to earth ground through the load, which would probably be a ground loop. He should be testing with an inverter and battery.
  • Bob Smith
    hi guys .. Spanish isn't my language ( a little Spanish and basic French) but this looks VERY interesting, was sent to me by a friend in Brazil .. all you Spanish speakers this is your chance to shine .. good luck with the translation .. skribat
    https://www.youtube.com/watch?featur...&v=lUtRFSqj504
    nice find!
    Only had time to watch the first video (over lunch at work).
    He's basically saying that the B&L schematic people have been working with are not producing the desired effects. He then shows another schematic that doesn't produce the effect either. Then, he shows one that does seem to produce abundant amps from the ground, starting around 7:20.
    Here's what he says at 18:15:
    "I believe B&L haven't told us the whole truth. If we input direct current without this capacitor (see right side of diagram), there is no substantial raising of current. To capture the electrons from the ground, there needs to be a means that permits, by induction, for them to be generated. And this instrument (means of induction) is still the capacitor, one of the great protagonists of electricity and electronics."
    Note, the negative input remains hanging or "in the air" as he says. He's showing 115V, 0.0-1.0A in, and at each winding of his transformer, he's getting around 168 amps. That's a lot of juice. The mains amperage draw continues to be around 1A even as he's running lights and some other gizmo (didn't catch what it was) off the output. It would seem the extra electrical charge is coming from the ground.
  • dragon
    "Ramset - Have you done any definitive testing on this Jump phenomena ??
    or incorporated this into an "energy from the ground"array ?"
    Yes I have, bluntly speaking, I have no intention of sharing that data or my work in this area at this point in time. I laid out the information for others to investigate its potential, nothing more. In relation to the B&L device think of it as a modulator - instead of a magnet your using current (electromagnet) to alter inductance. That loop to ground , assuming its around 30pf, represents approx Xc= 88 meg ohm at 60 hz. At resonance it is zero. If it passes through resonance, as an example, 120 times per second (full cycle) there is a hard pulse sent into the ground allowing current to return through the same link causing huge shifts.
    What would happen if there was an exchange of electrons through the ground loop from the current loop in clarences schematic? A shorted inverter...
    The way I interpret this device's function is to send the Line voltage into the current loop then the same line on exit is "mixed" with voltage and its amplified current. So my question would be how do you phase mix the high current in the loop with the voltage/current input from the inverter. Leaving only the ground loop as the solution to phasing.
