Barbosa and Leal Devices - Info and Replication Details
  • Completed three panel run
    Hello @ ALL,
    Completed the three panel build.
    Same process as before.
    Unit indoors enclosed.
    Previous run time was 2 hours.
    Made this build run time.
    Run time was 5 hours 18 minutes.
    Will keep this build and make improvements.
    Will take some time - maybe three + weeks.
    Clarence
    • Originally posted by clarence View Post
      Hello @ ALL,
      Clarence
      I think you are on to something good. This video is hard to hear yet
      the man shows a light powering a PV cell pack indoors. This leads us
      to see that efficiency is good in this form of energy transfer.
      However the light from the room in his video is also being picked up as
      you can clearly see the angle of the PV cell is not directed solely at the
      LED with heat sinc.
      Not bad at all. In your case you are only looking for a direct transfer
      not a recirculating system. great for power isolation
      [VIDEO]https://www.youtube.com/watch?v=PU5JvO1opkk[/VIDEO]
      Here is a chart of various PV panel efficiencies in full sun light so naturally
      the indoor arrangement will not be as high. somewhere around 20 percent.
      Then there is the LED conversion efficiencies say around the same.
      For small amounts maybe.
      • Fires-are y"all safe?
        Originally posted by wantomake View Post
        Hello Clarence,
        Not been posting for awhile, but have looked in some time to see your post.
        I've still got my single toroid setup on the work bench but not been able to do any further testing. Inverter, good charger, bank (9) high amp batteries, the whole setup. I even have (3) PV panels 85 watts each to use as I want.
        I know you'll not disclose yet what your setup is. I understand. When you are ready I have most of what's needed to start helping if I can.
        Glad you still keeping the fire burning. Yes we got many forest fires around the area. Wrong choice of words.
        wantomake
        Hello wantomake,
        With regard to the wildfires - are all of you safe at present.
        Saw all of the destruction on news.
        Was concerned?
        Clarence
        • Safe distance
          Thanks for asking,
          I live in the foothills away from the fires in upstate SC. Of course the Tennessee fires are some distance from us. We had much smoke weeks ago but most fires are out now thanks to the rain and hard working Fire fighters.
          Not been in the shop much lately due to life and cold rain. Still watching and hoping for your project and testing.
          Blessings my friend,
          wantomake
          James
          • Charge Controller
            [QUOTE=wantomake;295644]Thanks for asking,
            wantomake
            James[/QUOTE
            James,
            my efforts are at a stand down till DEC 21.till then have been trying to evaluate the use of a MPPT controller versus a smaller regular PWM
            controller the PWM should suffice for a smaller array while The MPPT is said to be best for multiple grouped small arrays to get the best out of its use.
            the 30 amp MPPT I have is not a small doggie - its huge. I feel that some
            solid state component that size and that involved does not operate without energy use cost. This is probably what is limiting the run time at present.
            It seems to be sapping just enough PV output to keep the one battery from
            taking enough charge to Build-Hold-Stabilize its start out voltage.I have both types to work with so that is what I will do between now and the 21 st .
            speaking of rain and cold, here it's rained three days with a now total of 11 inches. Bayous, creeks and such DO NOT like those amounts. Flood warnings out now.
            Any stray comments you have just shoot me an E.
            Blessings James,
            Clarence
            • Originally posted by Vinyasi
              Is there some other way to get the attached photo to me, 'cuz I sure would appreciate your data for study. Thanks.
              Hello Vinny
              What Clarence is doing is covered in the very beginning of the thread.
              Why you cannot see the pictures? I'll see if I can help by seeing them.
              Let me go check, BRB
              Not real sure who pulled out their pictures yet. Clarence did an induction
              cooker and tesla coil and bifilar coil and so much more.
              I have no way of knowing which picture you were interested in as there
              are so so many.
                Hello BRO,
                Maybe this will help ?????
                Clarence
                Yeah yeah that's a great shot Clarence, hey Vinny? I always figured
                put a 50 amp breaker on it in case I hooked it up backwards just on
                idle
                • Beware of the weasel _ a real p o s
                  idle
                  Hello Bro,
                  You and ALL need to be aware that Weasel is a Hacking Scum Bag Of ****
                  so don't be fooled by this brain dead idiot. I have done away with my photobucket account and will revert to the old JPG method to get info across
                  from now on.
                  The only help THAT needs is under the GREEN.
                  Later
                  Clarence
                  • Originally posted by Vinyasi View Post
                    No. Reverse wiring was not in his book. What he said was, "in a peculiar way".
                    But he was interviewed by a Paul Scarzo and, in that interview, he admits to accidentally hooking them up backwards on two separate branch circuits in one of the apartments in his complex. He also has admitted the backwards requirement, more than once, in emails to me.
                    ...or search for the video series using the search terms:
                    tesla's tri-metal generator
                    Hello Bro,
                    from now on.
                    Later
                    Clarence
                    WOW who is that guy? Do you mean Vinny? Or whatever his name is?
                    You mean Vinyasi, right. Someone else called him Jim G. maybe that is
                    his name? Anyway I really don't understand their motives.
                    Did he hack your computer? Or your pictures?
                    Maybe someone already knows who this guy is. I noticed he pulled out.
                    I figured he wanted to learn from us. What did he do?
                    I'll post your stuff on my site and nobody will ever get in. How did he
                    get your username and password?
                    Send me all your pictures and I'll send you the links in an email
                    and the picture can be freely accessed without incidence by all.
                    I can put up 50 pictures in 10 minutes.
                    • Originally posted by wantomake View Post
                      wantomake
                      James
                      I hope all is well. Some have suggested that this is a deliberate act
                      but we have had dry weather right?
                      I have not looked closely at the data surrounding the size and scope
                      of all of these fires but it does seem that to many individual fires popped
                      up all of a sudden. 21 arrested already from what I am hearing.
                      Unless my reports are inaccurate which occurs regularly on these
                      CNN fake news sites. One day the news says the sky is black and the
                      next day we are all suppose to believe it's now turned to peach.
                      May the Lord watch over you.
                      Michael Rowland (Central Kansas)
                        Hello BRO,
                        Yes I mean the ******* you mentioned ! !
                        Sneaky little Bastard that he is.
                        Right when IT first posted some photos from
                        my Photo Bucket account I knew right then what he had done.
                        The WEASEL thinks he was smart by using the back door
                        method to get into my account. I would explain but it would only
                        enable maybe some other WEASEL to do the same. IT can do the same thing to YOUR PHOTO ACCOUNT also.
                        That is why I was trying to warn you and all others about the bastard.
                        When you have the time send me an E and I will explain.
                        IT needs a 44caliber REALITY !
                        LATER,
                        Clarence
                          Hello BRO,
                          LATER,
                          Clarence
                          Gotchya, The world is full of idle folks doing their dirty little deeds
                          thinking it is cute. I had a problem like that is the past but no more.
                          I use a method impossible to hack so I am the dictator here, the
                          way it should be.
                          Why in the world would a pencil neck geek be doing something so guffy?
                          He lays on his pillow and does video sideways, a bit strange but
                          who knows what lives there. I have emails coming to me where the
                          hackers are posing themselves as a company I deal with. If I fall
                          for their little ploy they have me filling out info.
                          Sneaky it right, the header looks just like my phone company or
                          my electric company then they want me to sigh in. What a joke,
                          I have never fallen for that since my credit card was hacked.
                            Hello BRO,
                            If its alright with you Can I E my posts to you with photo and you
                            pass it on to forum as coming from you - may make it easier and you can
                            save all photos to your self ?
                            Would be indeed a blessing to others - Maybe a pain in the ass for you tho ?
                            Please advise By post or E BRO either way is good.
                            Thanks as Always,
                            Clarence
                              Hello BRO,
                              Thanks as Always,
                              Clarence
                              Done did deal, iron clad, etched in stone security as I don't want to
                              lose our hard work and also think it a crime to keep it all a secret.
                              I know that you have an open heart to share
                              I would be delighted to post your pictures anytime and when you want
                              anything changed just let me know and I'll do what is needed.
                              Like I said, I can do it fast and easy. Well it's my own domain I pay for
                              each year so instantly everything goes up. I had hackers try to come
                              in and the security systems prevent easy access.
                              In fact that system will track down offenders.
                                Thanks BRO,
                                You should have my first E photos to you by now.
                                BTW you are free to do with any and all of them as it fits your needs
                                also.
                                Bless you Bro!
                                Clarence
