Hi Clarence
what type of core material did you use ferrite or laminated as a friend reminded me before I buy the core
also can I use a 220 v ac 60 hz inverter and 220 v ac 60 hz toroid
At first that seemed odd to me also but the water may tend to short out ground currents. While pure water is an insulator all it takes is a small amount of salt or impurity in water to turn it into a good conductor. Too much water may make input and return ground rods appear as one.
It would seem ground conditions in your specific area (moisture content) will be a factor in rod separation if ewizard's assumption is correct.
Any advice the grounding network? I think this is the most critical part (my previous effort didn't work because of that). What is the spacing between the rods? I might only be able to go about 6 feet because I might hit bedrock; I read the spacing should be twice the rod length. Is there a way to check if the there is enough ground rods by checking the resistance between the neutral post at the inverter and the captor ground terminal?
Hello wayne49s. This is a very good question. In regards to earth grounding for electrical systems, such as electrical grounding for electrical panels, according to code the minimum distance between two ground rods is about two meters or about six feet. This is actually a compromise distance however. I have read that the optimal distance between two connected ground rods to get the least resistance to the earth is actually 7.6 meters or about 25 feet!
The reason for this is a ground rod needs an area all around it to optimally dissipate any voltage on it to the earth. If another ground rod that is electrically connected to the first ground rod is closer to the first ground rod than 7.6 meters, then the voltage from each ground rod is 'opposing' the voltage on the other ground rod. So it may actually be more effective to have four ground rods in a square pattern distanced about 7.6 meters apart than having several more ground rods spaced much closer together. In the Barbosa and Leal type device the goal may not necessarily be to have the lowest resistance connection to the earth, but on the other hand it may very well be, and wider ground rod spacing may be a better way to go.
The longer the ground rod, the more earth area will be utilized, so, for typical earth grounding purposes anyway, the longer the ground rod you can use the better. So an eight foot ground rod should be better than a six foot ground rod.
I see that Clarence is also earth grounding the neutral from his inverter with four ground rods. When I read through the Barbosa and Leal patent documents that were translated into English, I didn't see that they are mentioning grounding the neutral like that. If that is right, then it might also be worth a try to compare performance with the inverter neutral connected to ground rods, compared with the inverter neutral not connected to any ground rods at all.
I haven't tried building a Barbosa and Leal device (yet ), so the above is just some things to consider. Doing performance comparison tests with different arrangements as suggested above should help to determine if one arrangement is much better than another.
Clarence, what lead you to decide on a distance of three feet between ground rods?
The earth is a big ball of steel/iron so when the energy sees a steel rod
that is nothing special to the earth. The copper is something special to
electrical charges because copper has a very low resistance.
So when the energy sees your copper rod it wants to go to the path
or least resistance leaving the high resistance path through the iron ball.
Stick with Clarence and his gift to us. Receive his gift of many man hours
of trial and error. All of Clarence struggles to overcome the lies of the patent
documents. Clarence gift is only good if we all receive it.
Thanks Clarence, I heard you the first time
In my opinion it have more to do with the magnetism than a kind of galvanic effect... If so, a big mass or area of steel may attract it... But maybe I'm wrong...
Clarence, what is your opinion on this important part of the system?
What type of grounding rod is best? Do they need to be copper coated? Does galvanized work or stainless steel?
Thanks Bro Mickey
Im trying to make as close as possible on Clarence desi9n
Since the output of the inverters are 110 v ac x 2 and in our country
220 v ac Live and Neutral ...... im planning to adapt the 220 v ac 60 hz
primary
thanks
Welcome
484 is your number for 60hz 234vac or 220vac some say 240vac.
Be sure you tell me the size of your toroids. If they are close to Bridgeports then you will be right on. It is the industry standard in most cases.
You will be right on.
Me and hitby are thinking send some ac into the captor at 30,000volts.
The captor excites AND injects ac power using rods then collects many times more from the earth.
But you are going to be away from this design so i hope everything works out. Gotta try something.
Thanks Bro Mickey
primary
If transformer cores are purchased for 50hz operation the specs of that transformer must be given 50hz.
Volts/turn@50HZ and 60hz windings are not long enough so excessive current draw will break down the wire. I think it is a 17 percent variation from 50hz to 60hz. Big changes.
To refresh on transformer practices look here. I hope you enjoy it.
Thanks Level,
I just want the winding turns size for a 110 v primary since cores can easily be bought here in China
most are 22o v ac 50 hz primary Can this be applicable to the circuit also????
Im planning to buy on Sunday so just making sure i got all the info needed
If you are going to wind your own toroidal core no matter what Clarence tells
you then I can help you and others so they do not fail. Many people can not get the exact Bridgeport cores where they live and shipping would cost them $200 USD.
Clarence has also pointed out that a third transformer is not needed, however the tiny set of 2 loops electrically connected to the 4 input grounding stakes is technically the third transformer.
Yet Clarence is sure about his diagram having tested this already so please everyone stick to the diagram that Clarence has put up. What I have been doing separating individual circuit branches for your review may be misinterpreted as an open door for redesigning Clarence work.
It is not an open door for changing anything, just a segmented view to help us all get focused on Clarence layout a piece at a time.
If totoalas wants to wing it and wind his own primary for 117vac then he or I could call technical support and ask them how to wind our own and that is what I have been telling everyone that I have been doing for years.
Those guys don't care, they tell me what I want to know WHEN I buy a core, so if you are buying a core that is for 60hz operation at 300va then use 21awg wire and winding only half way around like the picture Clarence posted. If you live inside the USA and can get the cores cheap already wound for $125 each, save yourself the trouble.
If you are able to wind a toroid then you already spent the money on a winding machine and understand how hard winding toroid's are.
totoalas!!! you must look for the information on your core and yes 5.2 dia. Each core material supplier has a number that looks like this
Volts/turn= ???
At "Bridgeport" ALPHACOREDDIRECT it looks like this V/TURN@ 60Hz 15kG
Look at this chart for P/N 110 there you will find a 5.2" O.D core listed. About $40 shipped inside the USA.
Next look at the Volts/Turn@60hz the number says .483
This means that each time you wrap a loop of wire around THIS specific core you will get .483volts
Now to find the number of turns is 117vac divided-BY .483 = 242 turns
Now if you are going to use a thinner wire to wind a 234volt transformer (117vac +117vac = 234vac) then you will need twice as many turns.
Maybe 24-25awg wire for 234vac operation at 484 turns at 50hz?
Are you going to operate at 50hz? If so you can not use 60hz winding information.
Hello totoalas. See Clarence's reply above about reading post #6.
According to that note, Clarence custom ordered the two toroids without the secondary, so that may be why the part number is designated as TD300-1120-P, rather than TD300-1120. I am attaching the specs on the Bridgeport Magnetics TD300-1120 toroid, for which I would guess the toroid dimensions should be the same as the TD300-1120-P, except that the TD300-1120-P doesn't have the secondary wound on it. Clarence can confirm if these toroid dimensions match his toroids or not.
Hello LEVEL,
you are amazing sir. your excellent grasp at all times is an outstanding value to all of the members Sir.
The TD300-1120-P is the toroid that I buy and use. know Level that I previously Built the larger SINGLE toroid Modules and fired them up easily and they put out almost the exact same level of Captor AC amps as B&L's did in their early three Gray Box Demo. their value on the second unit was 116.+ and mine was 126.+ that is why I can say and know that this toroid is excellent for the job.
toroid winding size and info before i buy the core 5,2 inches? thanks
