Barbosa and Leal Devices - Info and Replication Details
  • No picture please
    Originally posted by clarence View Post
    Wantomake,
    Use the 250 one - you have to use a GDT rated at HIGHER voltage than the mains or inverter voltage or the GDT WILL BLITZ the voltage straight thru and trip breakers!
    The toroids are BUTT to Butt - found that if you place them face to face then
    the input leads get in the way.
    Face toFace Or ass to ass -makes no difference as long as they MATCH !
    Nose to Ass doesn't work ! HA! HA!
    Clarence
    Clarence,
    Please don't paint that picture in my mind!!!
    I just ate !!!!
    wantomake
    • Congrats Clarence!
      The blue #12 coils are really the electron trap then?
      Ha, I confess. I bought two of these toroid transformers from Bridgeport Magnetics way back when and when I finally admitted to myself that I didn't have what it takes to solve this B&L patent, I used them on another project, destroying one in the process.
      I'll definitely have to try again now.
      Thank you for persevering until you solved it and my hat's off to you sir for sharing your work.
      Respectfully,
      Cadman
      • Toroids
        Ok, thanks for the clarification. I just didn't know what the number of loops was on those toroids. To help anyone else, it's the:
        "TD300-1120-P, 300VA, 60Hz, Primary 120V, 160 degrees winding on toroid surface, no secondary winding" available from Bridgeport Magnetics.
        • Ground rods
          Clarence,
          With your success, it gave me the inspiration I needed to put in 3 8' ground rods tonight. I'm waiting for the 150v GDT's to come in. Can't wait to try this thing! I've got a pure sine wave inverter, so I'm very interested in trying it with that also.
          • Congratulations
            Congratulations on your successful efforts and on a topic thread which illustrates what this forum is all about - shared experience with respect and support. I both appreciate and admire what I have read here. Best wishes to you, Clarence, and to all who seek to replicate what you have accomplished!
            • Improvement
              [QUOTE=wantomake;
              wantomake[/QUOTE]
              Wantomake
              I just made an improvement regarding the Two toroid in phase shorted loop shown in previous PIC'S as the Blue # 12 AWG wire wrapped around the toroid winds.
              Instead of it just being a touch connection with the ground return I instead connected it with a short section of the ground return wire. This lets it still remain as a shorted loop but allows the alternating hertz frequency of the shorted loop to actually "PUMP" electrons through the ground wire and really does "ENHANCE THE GROUND RETURN" Action.
              I confirmed this by using my clamp meter. Before the change with or without
              loads on the system the shorted in phase blue wire loop always showed a steady amp reading of .4-.5 amps.
              Now with it connected with part of the ground return wire as part of it's shorted loop the amp reading drops to .2 amps.
              This shows that the ground return electrons are easing the current strain
              on the shorted loop while it is pumping them through (alternation wise) .
              May sound strange the way I put it but hopefully you get the idea anyway.
              Thumbnail attached.
              Clarence
              • Originally posted by clarence View Post
                ... most people would just say that's only a damn ground loop to avoid the meter....
                Put a couple of 1A fuses in the wires of the cord from the KAW meter. Then pull 27A current out to run your appliances.
                If the fuses don't blow, that should put that argument to rest.
                • I'll do it
                  Cadman,
                  Good Idea - I'll do it.
                  Clarence
                  • Ground grid
                    Clarence and All builders,
                    I finished the toroid rewind, loop #12 gauge winding, all circuit setup built as specified by your pics. Also added GDT to the setup.
                    My AC voltage reading was 123 vac without load. Using a 100 watt clear bulb as load, the ac dropped to 90+- volts.
                    But my input .4 amps matched the output .4 amps. No matter what load I tried the same readings. I tried a second load connected and that halfed the load power to first load to 45+- av volts and dimmed the bulb.
                    I used an amp clamp and cheap KAW,and a fluke meter, so I believe they are close enough to accurate readings.
                    My ground grid is only 4 grounding rods which I'm hoping is the problem. In the past(as a test) I've used 14" galvanised nails to add to the grid (with alligator leads) to see if energy increases with more rods. Well it does add more energy as I added more nails.
                    So my ole friend help me out here. Should I add more grounding rods to my grid? That's the only difference in our setups. I remember you had 60 or so rods. Are you using that many now?
                    Help!!
                    wantomake
                    • Yes
                      Help!!
                      wantomake
                      Wantomake ,
                      Yes, that probably is the problem ole friend. After all this is an energy from the ground devise.
                      Also, I am using the 60 ground rods.
                      Here is an important note for all members , way back in the day (2013)
                      when Barbosa and Cleriston Leal were personally questioned about everything pertaining to their devise, the one asking the questions pushed them about the ground rods with respect to how many and how far apart.
                      They had no problem about the question and answered by sayingthe the minimum shoudbe somewhere around 26 rods an they should be about three feet apart and all of them planted in a ring/elongated oval/circular type with the two wire ends connected TOGETHER and then from that connection point
                      there should be a single wire of the SAME SIZE that was used in the rod ring.
                      They mentioned that the connecting wire should have an Ohm value of no greater than 0.1 ohms.
                      The ONLY AWG wire size that Ifound that met that criteria #6 (Green) AWG wire. That's what ALL of my 60 rods are connected with and also the feed wire from all of them.
                      They said use smaller wire and there would be PROBLEMS. I took them at their word.
                      When I was drawing 26+ amps with loads my input voltage from the mains dropped from 121 down to 118 volts. There WILL BE A DROP IN LINE VOLTAGE - it comes from usage.
                      Hope all this helps clear the way for you buddy!
                      Thanks for asking to J !
                      Clarence
                      • Ring
                        Clarence,
                        On the rods, are yours in a circle? Or are they more like a grid? At 60 rods, it seems like that would be a pretty big circle. I think I've got the space, but I'll have to go take some measurements. If yours is working in a more compact area, I'd be interested in knowing.
                        • Schematic
                          Cadman,
                          Clarence
                          Hi Clarence! Good job
                          Could you, or somebody else to post a schematic of this device?
                          I mean the new schematic?
                          Thanks👍
                          • No schematic - picture only
                            Thanks👍
                            FRANKLIN,
                            The best schematic would be the photo I posted on post # 1581 - this page#53.
                            All you have to do is look at it.
                            Clarence
                            • This way
                              Originally posted by digits10 View Post
                              Clarence,
                              digits10,
                              The thumbnail shows my configuration of rods around my house.
                              Best,
                              Clarence
                              • Grid cost
                                Clarence,
                                Thanks for the information. That makes good sense.
                                26 grounding rods
                                26 connectors for wire to rod
                                26 rods at three feet apart in circle = 78 feet +-
                                78 feet #6 awg (green) wire (welding cable)on eBay 40' ($27) x 2
                                10 - 15 feet(?) From shop to circle #6 awg wire
                                Are my calculations right? Maybe. But it will take me a while to finish this. But will see what I can do.
                                Please everyone keep building. If this(?) can work from an inverter/battery setup, then if power outage of any nature happens you'll still have power.
                                If I remember correctly B&L started with this idea. There's more after this.
                                wantomake
                                Edit: I guess my coffee budget will get cut......well that's not going to happen !!!!
