A1Mo-Gen: Tesla's Gift "The Electromagnetic Reactor"
  • A1MoGen: 7 phases/7 coils
    Dual commutator Tesla motors that used standard OEM brushes, 2 commentator segments = 2 coils energized
    It was a very simple process to run the motor in series connection.
    Pos to Neg to positive with the terminal cables.
    For the A1MoGen, I don't recommend that the coils be run in series the traditional way of positive to neg to positive with the terminal cables...
    I have reason to believe that the traditional way may hinder performance or maybe burn out coils.
    A better approach is to actually making the coils look more like the three-phase motor's coil phases...
    One wire makes two coils 180 from each other. This will allow you to use a thicker gauge wire.
    *Important* You can Only use 1/one commutator!
    Keep it Clean and Green
    Midaz
    • Well, the "Brush" companies can do anything but for the amout of time, money and CAD designs for new brush plates and wider brushes..... It's not worth it for me at this time.
      Time for my original plan, first plan, PLAN A!
      1.) We will Do everything with the parts that we have already for the P56 frame kit!
      2.) We will have over 4000 Rpms @ 36v
      3.) we will have superior torque than the OEM
      Midaz
      Need a drill or drill press, a commutator pulley & 17awg
      • My original/1st plan ... Step one ... Brush plate mods!!!
        First things first... I am NOT using two/dual commutators ... Just 1/one commutator!
        [VIDEO]https://m.youtube.com/watch?feature=youtu.be&v=gxh9l6HNIKk[/VIDEO]
        https://m.youtube.com/watch?feature=...&v=gxh9l6HNIKk
        The Imperial kit included 2 brush plates = 8 brushes total
        1.) Four brush units will be removed from one brush plate.
        2.) The 4 units must be rotated 180 and fastened to the other brush plate with nuts and bolts. All 8 brushes will be on 1 plate!
        (I checked the measurements. It fits)
        3.) The tension springs must be inverted and rotated.
        It's not 7 coils like I need for the full A1MoGen but we do have 3 ~ 4 coils but mainly 3 singular coils energized per pair-inputs...
        * 2 brush pair-inputs X 4 phase singular coils(8 coils) = 16 coils max to drive the load! *
        Keep it Clean & Green
        Midaz
        Work with what you have! #itwilldo
        • Unbelievable! ! ! !
          So after all that, like a couple years of your BS about how great A1MoJo is, you're going to rip off one of his comms and cobble together some monstrosity which has no chance of working even a fraction as well as the OEM version.
          Unbelievable! ! ! !
            Unbelievable! ! ! !
            Dude
            It is what it is. Using two/dual comms is very flexible. But...
            Do you remember Hunting Ross? He did a single comm design. It's not as flexible as the tesla's dual comm motor but
            it does the job/almost the same principles!
            Just in case you may have overlooked it
            Please read my quote from 2 days ago
            It's just the way I see it when multiple phases (4) must be energized at once from the same brush!
            Midaz
            Basically, this DIY A1MoGen build = 3~4 overlapping coil phases = max 100 turns of 17 AWG motor!!
            Torque!? Not bad, not bad at all!
            • I remember H. Ross. From my recollection his motor wasn't much to talk about. Perhaps you can provide the link to something impressive that he did.
              So why the about-face on your A1MoJo dual comm "Tesla's gift" super dynamo?
              Did those world renowned motor professionals get back to you yet?
              • A1MoGen has 93% coil usage
                Dude
                Like I wrote before... "Nothing has been a GAME CHANGER so far."
                Everyone has done a standard OEM brush setup.
                I saw my vision from way back when. The only way to unlock the full potential is with extra and/or wider brushes. The A1MoGen is an alternative that use 26 coils out of 28 possible coils...
                Basically, the 28 pole A1MoGen has 210 turns of 19awg passing EVERY pole! That means that EVERY pole, that is directly interacting with the stator magnets, is producing some serious torque!
                93% coil usage for the A1MoGen -vs- 28% for past dual/single comms builds! That a 332% differance!!!
                The full A1MoGen has more Mojo at one/1 brush set than any past build! Yes, it has real Mojo!
                Bistander, if you can, correct me if I'm wrong.
                Midaz
                The A1MoGen is Hot Rodding for Tesla's dual comm Brushed DC Motors! High-performance electric motors for cheap!
                • Bistander,
                  Get a grip son! Understand this....
                  Anything over 48v is an overkill! What you do pay for is amps!
                  If you dump 400amps into the full version A1MoGen/Jo! Your 0-60mph time will be... WTF!
                  And stay cooler longer!
                  Fact: Most people just want to have a good time with electric motors.
                  Stand Bi and think about that!
                  • Showtime
                    Then put the thing in your motorbike and show us.
                      Yeah, It is about showtime!
                      Anyway, back to working with what we have... Yesterday I told you that I'm using one comm and modifying a brush plate. The modified brush set up will energize energize a maximum of 4 coils. To get the maximum benefit of the set up,
                      each Singular coil phase must be 9 Armature Poles.
                      Here's the break down with 17agw at one brush-pair
                      Singular coil phases(180 apart) are winded 9 armature poles
                      Pole #1 ---> O turns ---> Zero/0 torque
                      Pole #2 ---> 25 turns ---> start North magnetic... Repulsion mode
                      Pole #3 ---> 50 T ---> North repulsion
                      Pole #4 ---> 75 T ---> N. Bisector between poles 4 & 5
                      Pole #5 ---> 100 T ---> North repulsion
                      Pole #6 ---> 100 t ---> end North magnet
                      Pole #7 ---> 100 Turns ---> Zero/0 torque
                      Pole #8 ---> 100 Turns ---> Zero/0 torque
                      Pole # 9 ---> 100 t ---> start South magnetic... Attraction mode
                      Pole #10 ---> 100 t ---> south attract
                      Pole #11 ---> 75T ---> S. Bisector between poles 11 & 12
                      Pole #12 ---> 50 T ---> south attract
                      Pole #13 ---> 25 turns ---> end South magnetic... Attract mode
                      Pole #14 ---> O turns ---> Zero/0 torque
                      Basically, when all inputs are used, You have a max of 100 turns of 17AWG motor
                      Midaz
                      • Bi,
                        Since you know a lot about motors...
                        Originally posted by Bi
                        I have followed Ufopolitic's thread and I am quite knowledgeable on electric machines.
                        Unbelievable! ! ! !
                        Unbelievable! ! ! !
                        It seem as thou it would be fitting for YOU to explain to everyone on how the OEM is so superior over the A1MoGen!?
                        Here's you big chance to educate the B.S.ers!
                        Don't let the crickets drowned your voice out! Because everyone on the forum knows that you know it all.
                        Waiting for you in detail technical analysis
                        Midaz
                        • Just do it
                          Midaz
                          This is what I found unbelievable. ... you dropping A1MoGo to make a single comm motor with some 8 brush weird wound armature motor. I can't believe you can devise a winding pattern which would increase the coil utilization over that of the OEM verzion which is likely about 85% and only misses coils in the neutral zone (between magnets in essentially zero flux) and undergoing commutation. And I doubt you would be able to fashion a system to position 8 brushes radially around a commutator on a 4 pole machine and successfully commutate.
                          I don't think you know motor theory and I am not going to attempt to teach you. But I've been watching your posts since your run-in with Ufo on his Asymmetric thread. I just want to see A1MoJo tested on your motorbike.
                          From Nike: just do it.
                            Thanks for your detailed technical analysis. It was amazing. It was packed with knowledge I didn't know.
                            You're great. You opened everyone's eyes...
                            to the stuff we already knew
                            Anyway dude, I'm busy... #workingwithwhatihave.
                            Btw... I wouldnt use a solid block for the brushes! I figured that out along time ago... 2yrs ago!
                            If your here to help or present new info, that's welcomed. If not, you bore me!
                            Midaz
                            • Help?
                              OK. You don't do much in the way of conventional motor parameter calculation or measurement, so it is difficult for me (or anybody else, I suspect) to follow all the numbers of coil turns and equivalent wire gauge and somehow relate that to machine performance or quality. However I think I detect an error evident in recent posts where you appear to add both turns and wire size which erroneously yields a double benefit. It's like you cannot put electrical components in series and parallel at the same time. Either coils are in parallel and turns don't add, or in series and size doesn't add. You can't have both.
                              https://www.chiefdelphi.com/forums/a.../t-129536.html
                              Here is a link to a forum having a reasonably intelligent discussion concerning motor design constants like kv & kt, and parameters universally used in motor analysis. You'd benefit greatly to learn what they're doing and see how you can apply sensible techniques to your project instead of seemingly pulling numbers and brag out of your butt.
                              I'm going to leave you alone to play with your special gift from Tesla. I'm sure Nik would be proud of what you've accomplished with it. NOT one joule of work done. I can't wait forever to see you test it. It'd probably fail miserably anyway.
                              Good bye,
                                First of all, one speak for yourself! .. turns, wire gauge, torque, rpms, wattage... And... What was the baseline!
                                if I have a mistake, post the mistake for everyone to get a better understanding ... Or
                                pulling numbers!? I'm Bragging!? What are you talking about!? I checked for mistakes, everything seems to be correct! ...
                                YOU came here, wrote a a lot & brought NOTHING new to the plate except for YOUR attitude!
                                Good bye,
                                Since you're having trouble comprehending, I'm happy to leave you with this...
                                The Tesla dual/2 comm 3 pole motor can only be winded one way! Now expanded to many poles!
                                for nothing!
                                1+1=2 ... Not 11
                                Midaz
                                having fun working with the parts that I ALREADY have
