NEW OFFICIAL VIDEO BY VELJKO MILKOVIC
How to Make a Two-Stage Oscillator More Efficient
https://www.youtube.com/watch?v=xYRZMBw0mGs
* English subtitles available in the video player settings *
IMPROVING THE EFFICIENCY OF THE TWO-STAGE MECHANICAL OSCILLATOR BY USING CERAMIC BALL BEARINGS OR ELASTIC (FLEXIBLE) PENDULUM
Veljko Milkovic demonstrates ways how to make a two-stage oscillator model more efficient.
Based on all independent scientific papers published so far, as well as videos of replicas of the two-stage mechanical oscillator that can be found on the Internet, it is noted that all these mechanisms are constructed using steel ball bearings.
These steel ball bearings are a hidden brake, which is harmful during operation because it reduces the inertia and thus the efficiency of the entire device (this is a harmful phenomenon in the case of oscillations, but not in the case of rotations as well). Therefore, it is recommended to all researchers and engineers around the world to use ceramic ball bearings and an elastic (flexible) pendulum to obtain significantly less friction.
According to their characteristics, ceramic ball bearings have a lower coefficient of friction. In addition, ceramic balls are lighter than steel balls, resulting in less inertia which further improves their efficiency. Adequate selection of ball bearings can significantly increase the efficiency of the oscillator in terms of the duration of oscillations during laboratory or practical tests. This improvement is achieved precisely by reducing friction and inertia, which results in a longer duration of oscillations, thus greater efficiency and lower energy consumption for their maintenance (e.g. in case of maintaining the pendulum oscillation).
Ball bearings are eliminated in the elastic (flexible) pendulum design, therefore less energy is lost in ball inertia and friction, resulting in even greater efficiency.
The two-stage mechanical oscillator and its practical application have been studied all over the world in university centers, institutes and by enthusiasts for 20 years; with 2 doctoral theses (Ph.D. dissertations) published so far [the third one in the final stage], 39 scientific research papers, 5 university graduate theses, 5 papers from different scientific conferences, as well as 10 other papers related to this invention.
https://www.vemirc.com/en/references-citation/
Veljko Milkovic' Two-Stage Mechanical Oscillator - main news & discussion thread
NEW VIDEO BY VELJKO MILKOVIC
Veljko Milkovic demonstrates his latest achievements in the field of two-stage oscillator development presenting a new improved model with an elastic (flexible) pendulum and elastic (flexible) lever which is far more efficient than the previous oscillator versions.
This fast and superior model has been significantly improved with elastic oscillations that give a better result with both the pendulum and the lever. The work is still underway on further technical improvements.
This advanced technology is being investigated on all continents. There are now over 500 companies from
Southeast Asia that are producing, developing and practically applying the machines based on the principle of Veljko Milkovic’s two-stage oscillator.
New Fast and Improved Two-Stage Oscillator (VIDEO)
https://www.youtube.com/watch?v=7wn15yJ9JYY
As I was told years ago, sometimes you have to give up your teaching to see the real truths in front of you. When I proved one of the laws of Phys. to 4 students of it was not true, they looked in disbelief. I then told them that it would be bad for their career it they kept looking. They did anyhow. I said, just keep it for future reference and never say anything to your professors or you will catch hell in the end. Hope they did.
thay
Veljko Milkovic's two-stage oscillator with flexible (elastic) pendulum surpasses all rotary devices and is the only free energy machines that has been practically used worldwide.
https://www.youtube.com/watch?v=PwlKWcO79J0
https://www.facebook.com/milkovicv
There is a 1,000$ cash award for a counter-argument that the pendulum oscillations are more efficient than any rotations.
There are already the useful machines, bearing the name of Veljko Milkovic, in offer on Alibaba.com, a global retail e-platform.
https://www.alibaba.com/trade/search...eljko+milkovic
There is also a new fast pendulum model in the current development demonstrating much better performances.
The sustainable future is bright!
milkovic-pendulum.jpgAttached Files
to gain visual reinforcement of the motion starting with the pendulum.
in the video notice the direction of the hand.
https://youtu.be/GkNJvZINSEY?t=259
The Milkovic anvil pulse may have similar relationship to constructive interference.
The frequency beat of the anvil having very slight difference in rate.
https://youtu.be/4M72kQulGKk?t=126
The mechanical drive of the pendulum derives its impulse from a catenary curve
applied to the pendulum arc at a slightly faster beat.
Approximate rotational drive mechanism rotated ccw 90 degrees:
507 Mechanical Movements, 374
Sketchup software can scale a catenary for correct dimensions of a roller cam assembly.
https://youtu.be/M4QUO0PaI_ELast edited by mikrovolt; 02-20-2018, 03:38 AM.
Inventory of the Veljko Milkovic 2 stage oscillator an efficient mechanical gravity assisted pendulum power device.
The correct positioned mechanical parts allows a momentary condition,
the gravity deceases gradually as pendulum swings up causing dip in potential. Instrumentation (fish scale) load cell data acquisition log.
Getting the pendulum started has an initial force expenditure that becomes negligible when driven continuously (child on a swing).
Also a hammer jolt is delivered thru the metal from the anvil is* beneficial in opposite directions allows undamped pendulum swing.
Conventional observation shows that at the ends of the swing the pendulum is lightest and conversely the pendulum is heaviest at center.
As the pendulum gets heavier the cantilever increases lifting the massive lever and while metal relaxes on the other end.
https://youtu.be/5ho0_obiakM
As feasibility goes. Contending with political and financial control, large scale would be slow acceptance more favorable for non energy application.
Cost seems good considering how many solar panels it would take to give cost effective equivalent power.
because government/energy denying permission to construct and operate large large, a mid sized (400 lb ?) 2 stage Milkovic in the garage makes sense.
A large scale pendulum was built and tested however it was only a single stage pendulum.
The video comments: It;s time to return to gravity assisted power. Gov and energy corporations willing ?
https://youtu.be/-1n-C5o8fZ0Last edited by mikrovolt; 02-13-2018, 05:33 AM.
https://www.youtube.com/watch?v=L2mdAvdPhT4
this can be practically used for this pendulum oscillator
New papers from India
ENERGY CONVERSION PHENOMENON IN IMPLEMENTATION OF WATER LIFTING BY USING PENDULUM EFFECT
http://www.ijiert.org/admin/papers/1...E2%80%9915.pdf
Design and Fabrication of Hand Water Pump with a Pendulum
http://israse.com/digital/assets/papers/1ICRASE-71.pdf
This is a great breakthrough. I have played with one of these pendulum-levers enough to know that there is definitely an energy gain. Closing the loop is very difficult. I was using a rotary solenoid powered pendulum, but retrieving feedback electricity from such slow moving mechanism proved to be beyond my simple means at the time. Also, a stepper motor would probably have been a better choice, for electrical reasons.
The closed loop video doesn't show enough detail to get an idea of how it is being accomplished, but clearly the designer is a very clever individual.Last edited by serendipitor; 10-09-2016, 01:16 AM.
Originally posted by VEMIRC View PostNew pendulum pump replica from some Indian university
https://www.youtube.com/watch?v=0BuTAXVq7Io
It is obvious that is Milkovic's two-stage oscillator and it seems they closed the loop...?!
Pendulum-Gravity Motor in India
https://www.youtube.com/watch?v=2QrMoH6yfY0
New papers from India:
Microcontroller Based Performance Study Platform For Two Stage Mechanical Oscillator
http://www.ijmetmr.com/oloctober2014...kjilani-32.pdf
Design and Fabrication of Hand Water Pump Operated By a Pendulum
http://ijesta.com/upcomingissue/11.04.2016.pdf
I do not take the result of 12 times overunity seriously.
In the case of lead-out energy, there is often no direct relationship between the Input Energy by the user to the amount of energy lead-out or brought-in from the environment.
Any brought-in amount will increase the efficiency of the device.
Originally posted by wrtner View PostThere are numerous Veljko Milkovic threads. For instance:
http://www.energeticforum.com/renewa...aw-motion.html
Why start yet another one?
On July 4, we discussed the following:
Reproduced from overunity.com
One comment:
If you can use gravitational energy continuously, you are effectively tapping into the essence of the Universe. The entire universe has masses of different sizes. They attract each other. We, the Earth, the Sun are all attracted by other bodies from all sides. We are effectively immersed in a sea of gravitational forces. We are being pulled from all sides. If the pull on one side is greater, the force can do work or provide energy.
What you are claiming is that the Milkovic 2SO can already use such energy. Please justify...
The key concept is that the pendulum can be 99% efficient. If we examine the seesaw action carefully, we will see that the weight is lifted twice with every push. The lifting occurs when the pendulum bob is at the lowest position. At that position, the velocity is highest. That also means the centrifugal force is greatest. The lifting of the weight is due to the weight of the pendulum bob plus the centrifugal force at that instant. The pendulum must be swinging with a large amplitude to have a large enough centrifugal force component to lift the weight.
So long as the pendulum is swinging with such a magnitude, the seesaw action will remain.
A normal lever can maintain a swinging/seesaw or oscillation action for some time if it is perfectly balanced. However, a true seesaw action can be maintained forever if the forces on the two arms are appropriately varied. In a playground, that appropriate action is achieved by the persons leaning or rocking their bodies.
In the Milkovic 2O, that appropriate action is achieved by the swinging of the pendulum.
The seesaw action of the lever can be made to do work such as creating a loud noise, crashing nuts or pumping water. Energy must be used to do such work. The question is - where does the energy come from? The non-observing layman or even scientist will automatically answer: "It comes from pushing the pendulum!"
The observing scientist will say: "The amplitude of the swing of the pendulum is hardly affected if the high centrifugal force motion is maintained." In the RHead100 video 5, slight finger motion can lift the 74 pound weight twice to a total height approximately (or more) the distance of the finger push. https://www.youtube.com/watch?v=AulAeyAjtzk
If the output energy (banging, crushing or pumping) does not come entirely from the finger push, can there be other explanation?
A plausible explanation not violating any laws of Physics is that the extra energy comes from gravity. The Milkovic 2SO leads-out or brings-in gravitational energy.
