Tesla's Special Tri-Metal Generator
  • #91
    not on Youtube?
    Did not find it this time on Youtube or Google!
    but got this for you:
    Borax or Baking Soda Rectifier and the glow.
    Has all need info..
    Just use steel or lead, plus Aluminum and light 120 volt AC the neutral wire, and be safe.
    ... it was a few years back for me. But it does work, with baking soda. Not as good as the present market as it's larger and in solution.
    Same site:
    Steel copper link I found:
    Thermocouples Made From Ordinary Copper and Steel Wire
    Well I did a test a few days ago with Aluminum Copper Stainless Bronze
    To find out which one has the least "Eddy current's"
    I used 2 x 1 inch thick for the pure copper, 6061 aluminum and bronze.
    I set them to the same slope that the neo magnet could slide down ~20-30 degrees?
    Copper was not to good!(slowest one), as Aluminum. The Bronze was better, And some stainless grades have no EDDY current while others do with same series (303) I had a 316 with no eddy current and then a 316 with eddy current
    Had some Stainless tubing 300 series but not sure grade that was good.
    Carbon , lead no eddy current.
    Nice video, well I'm not no Chemist but it very interesting stuff.
    • #92
      Mark McKay's EV Gray motor analysis indicates Hutchinson Effect in TriMetal Generator
      Which becomes obvious in viewing the three stages of development of the EV Gray motor....
      1. Marvin Cole - the Searle Effect yielding no beneficial use, whatsoever, of the Hutchinson Effect. Levitation indicates a waste of energy for what should have been the exclusive use of what the EV Gray motor is intended for: locomotion, not flight.
      2. Richard Hackenberger's two phases of development. ....
      2a. Pre- FCC Raid in which Richard was blowing up a second set of batteries to dump some (but not all) of the excess energy produced by the EV Gray motor, versus
      2b. Post- FCC Raid yields full scale Hutchinson Effect by pumping compressed air through the interior of the specially designed chassis to prevent arcing and avoid attracting the attention of the FCC.
      The FCC raid was the second of the two raids which the EV Gray motor was made to suffer through.
      The Hutchinson Effect is a radio interference in an electrostatic field. The EV Gray motor must have been utilizing this effect to be able to have a COP of nearly 300! Tesla's Special Tri-Metal Generator must also have been using the Hutchinson Effect by blowing compressed air through the Nazi version of Tesla's device. An AC mechanical watt-hour meter and a DC homopolar/unipolar disk could both exhibit this effect, and each in their own way.
      A DC homopolar/unipolar disk could separate the magnetic field from its electric field causing one to drag behind the other by the proper arrangement and use of aluminum, copper and iron as noted in my prior video...
      The Lenz Effect is a DC time lag between a leading electric field and a dragging magnetic field.
      An AC mechanical watt-hour meter separates the voltage and amperage components of an AC sine wave coming from the power grid in order to operate as an induction motor to spin its aluminum disk. The immersion into an electrostatic field of these two electromagnetic (radio) waves constitutes the Hutchinson Effect.
      What helped me come to these conclusions is this video...
      magnetic field on aluminum, by lumen0
      https://www.youtube.com/watch?v=a0YCTwWvykw
      ...which seems to imply an hypothesis that a second set of electric/magnetic fields are cloned perpendicular from the first set whenever eddy currents are generated in aluminum.
      Mark McKay's analysis of the EV Gray motor...
      Am I A Raison Head?: The Definition of a Transformer
      View links to ODT files at bottom of the above blog which all lead to: Hermes Atar Trismegistus-the Swedish Teacher of Wisdom
      Or else, download as a 43 Mb zip file from...
      https://drive.google.com/file/d/0B8F...ew?usp=sharing
      ~or~
      http://tinyurl.com/evgray
      Or, from here...
      http://vinyasi.info/Tesla_Tri-Metal_...Gray-motor.zip
      • #93
        good results...
        Has all need info..
        I'm starting to come under sway of an hypothetical opinion that the 'reflective' component of Mr. Dort's definition of aluminum in Tesla's Tri-Metal Generator may be cloning an electric/magnetic set of fields at right angles to the primary set, and thus predispose aluminum for producing the above baking soda/borax rectifier results - especially the negative resistance noted at the bottom of that link.
        {Copper being the 'active' and iron being the 'magnetic'. - Mr. Dort (junior) as quoted by William Lyne in his "Pentagon Aliens" book.}
        Same site:
        This could imply that whenever diamagnetism is in evidence, then an exothermic reaction is also occurring, but only noticeable whenever the magnetic and electric fields of a DC situation (or, voltage/amperage phase separation of in an AC electromechanical watt-hour meter?) are suitably time delayed? {The Lenz Effect is a DC time lag...} Not a stretch of the imagination since copper coil windings, especially surrounding a non-air (ferrous) core electromagnet producing enough heat sometimes to melt its wax coating its coil windings?
        But would paramagnetic become endothermic?
        I guess this shows how aluminum and copper are both advantageous to use in conjunction with iron for Tesla's Tri-Metal Generator since back EMF, in the form of eddy currents, is just what is needed to be engineered into his Special Generator?
        • #94
          Solving Tesla's Riddle? = "200 pounds of iron per horsepower gain."
          200 pounds of iron means add more iron windings to an aluminum cored transformer and thus lengthen the wavelength.
          How Its Made Electric Pole Transformers, by İhsan GŁney
          Nathan Stubblefield's Earth Batteries (DC transformer)
          A Stubblefield earth battery buried among the roots of an old oak tree yields a tannic acid electrolyte. But the tree may be linked to the trigger coil via a wire attached to an iron nail driven into the tree?
          Tesla's Tri-Metal Generator - William Lyne and Paul Scarzo - 33rd Parallel, excerpt .
          • #95
            Transposing Nathan Stubblefield's Earth Battery to Tesla's Tri-Metal Generator...
            Transposing Nathan Stubblefield's Earth Battery to Tesla's Tri-Metal Generator in an electro-U-Boat.
            New Page 2
            Gerry Vassilatos on Stubblefield Earth Energy
            Scientific American article on Nathan's Ground Radio
            Inventory list of what's at Murray State University on Nathan
            search Murray State collections on Nathan
            • #96
              Working towards a solid state version of Tesla's Tri-Metal Generator.
              • #97
                MIT sells tiny Tesla coil kits
                • #98
                  Replacing solid state Tesla Tri-Metal Generator air flow with non-gaseous dielectric.
                  Replacing the air flow of a solid state Tesla Tri-Metal Generator with a liquid or solid dielectric.
                  • #99
                    Tesla's Tri-Metals are a simple mystery of what electrodynamic role they play.
                    Tesla's Tri-Metals are a simple mystery of what electrodynamic role they play in producing the Hutchison Effect.
                    Rather than create a muddle for ourselves worrying about arcane para-, dia- and ferro- magnetic properties of these three substances of aluminum, copper and iron (for example) -- not that these three magnetic properties aren't valid to consider, but a far simpler approach to defining Tesla's Special Generator in terms of these three metallic substances may be to merely define what role do they play in conventional electric circuits to produce the Hutchinson Effect?
                    Copper windings around an iron cored electromagnet represents radio waves interfering with each other immersed in an electrostatic field produced by the use of aluminum for constructing the plates of a capacitor.
                    We have five examples of the Hutchinson Effect, the first of which is quite common, namely: a pole transformer, the EV Gray motor, Tesla's Special Tri-Metal Generator, Nathan Stubblefield's Earth Battery, and the analysis of 911 by a forensic scientist: Dr. Judy Wood.
                    • Analysis of the Hutchison Effect in a pole transformer.
                      How a pole transformer is put together...
                      https://www.youtube.com/watch?v=EJTLs6xFhY4
                      • One more example of the Hutchison Effect: quiet murder within our homes.
                        The murder of John Bedini and his brother Gary Bedini via the Hutchison Effect using the power grid.
                        We are bred to believe in Hollywood's version of assassination: a hit man is hired by the mafia to "take someone out". So melodramatic and so suspenseful. But what about a more quiet method so transparent that we're led to believe that the victim died of natural causes?
                        One classic example is that of a soldier who dies just before battle of mere fright alone. Who killed him? Himself while under the influence of fear and the sight of the opposing army facing him.
                        But the link to the video, above, is about the very human tendency to overly personalize our problems to the point of their becoming so potentially lethal that no face-to-face assailant is needed to remove us from among the living, because our own life, or death, is always in our mind's eye whether or not we choose to periodically, or at times of high danger, manage our conscious attention to promote our general well-being at the expense of trying to solve all of our problems instead of merely some of them (the smaller ones whose solutions won't kill us).
                        This tendency is our vulnerability - and if magnified by the use of the Hutchison Effect via the power grid entering into our homes and buildings - substitutes Hollywood's version of murder with another one of equal merit effectively evolving the ancient "magical spell, or hex" into its technological modernization.
                        The solution is to periodically depersonalize our problems by turning our attention to the impersonal aspect of existence using whatever tricks at our disposal to encourage this approach.
                        • Tesla's Special Generator may be a replacement for Nathan Stubblefield Earth Battery.
                          Tesla's Special Generator may be a work around replacement for Nathan Stubblefield's Earth Battery....
                          ....in today's world, such as it is, polluted with AC noise in the very ground beneath our feet.
                          Mark McKay's EV Gray motor analysis indicates Hutchison Effect in Tesla's Tri-Metal Generator.
                          https://www.youtube.com/watch?v=EB_ulOjXRFQ
                          Nathan Stubblefield's Earth Batteries -- A natural alternative to Tesla's artificial Special TriMetal Generator?
                          New Page 2
                          William Lyne's description of the AC power station may be providing nothing more than "seed power" augmented from another source (William claims it's the watt-hour meter) to power our loads as is quoted from his interview by Paul Scarzo in the 33rd Parallel series although I would prefer to call it a "carrier wave" upon which rides: the voltage varying signals emanating from our load and the current provided by our electrostatic environment.
                          Tesla's Tri-Metal Generator - William Lyne and Paul Scarzo - 33rd Parallel, excerpt.
                          • Does the FCC regulate the radio interference contribution to the power grid?
                            • Toward a more accurate definition of the Hutchison Effect.
                              Definition - A consonant or dissonant interference between a transverse wave and a compression field. The compression field may be composed of matter or electrostatic energy.
                              • The importance of a dead short in any attempt to replicate Tesla's Special Generator?
                                Could an important ingredient -- which is missing in our design of replicating Tesla's Special Generator -- be a dead short between the source and load branches of a circuit?
                                [John Bedini pointing to...] Tom Bearden, "Don't kill the (voltage) dipole".
