  • UFO,
    I saw that post and tested it both ways.
    Seems to run the same, either way.
    I will try to post a video tomorrow.
    Mark
    Dear friend,
    That is the ONLY way it is supposed to run, you are activating Input Coils...now try the other diagonal terminals (opposed to the ones it runs and it should also run...go back to my previous Blue Back (Where TF is the Witch) diagram and connect like that...then measure it..
      Hi UFO,
      Hi Cifta,
      Thanks Carroll,
      Can you do me a favor?, Please?
      Whenever you answer, pls do it outside the quote mark PHP codes...or else I just read this:
      Hi UFO,
      Blank
      Thanks Carroll,
      Blank
      Respectfully,
      Carroll
      Hello Dear Carroll,
      Please, may I ask where did you read, in what part, did I write the word..."Total Output=18 Volts"? Your meter shows 18 volts and it is across the generator output plus the battery voltage in series.
      Ok Carroll,
      Let me explain why I did that...The Effective Armature Voltage on a Motor, is calculated based on its Voltage-Current transiting its Armature Coils...In Symmetric Motors we must subtract C EMF because Symmetry is constantly reversing the Coils Voltage to achieve rotation, by forced Magnetic Poles switching, this creates a reverse current and voltage flow...Are you picturing this?
      Mr Peter Lindemann shows Us an old Navy Electric Book, where a Battery is portrayed as the C EMF and connected opposite to Input, meaning plus to plus and neg to neg...which I agree entirely with...Coils retain their energy in their magnetic fields...just like a non polarized Cap...now every time it charges, then it "blows it back" at our Input...Mine does not do that...instead it sends it via second set of brushes...to output being a positive value and favoring rotation...so we can not subtract, because My "battery" reverses naturally, just like any given inductor...at the time is Pulsed Off...by that time it is already connected and discharging its voltage and current down our outputs...so, we can not subtract that value, but add it...
      May I ask you if you had the time to watch my video Asymmetry to Enlightenment?...Go direct to 4:28 I have Symmetry described there as Mr Lindemann's Video shows, then jump to 10:40 and watch my Motors at work...
      A Motor Armature Power is given by Ea-Ec=Effective Voltage (not output) Not exactly true. You have to include armature current to calculate true armature power.
      Dear Carroll, Current (Amperage) is an Electronic Flow "Population" Value per section of conductor, simplified...nothing more to it...Voltage is the Potential difference between Point A and Point B of a given length of conductor of Electronic Flow...Parameters are reading both electronic flow...one at a cross section and the other at two ends and computing the difference in potentials...They are both about electronic flow...nothing more to it...We have learned to separate this as if they would be comprehending different based Constants...and they are not...They are about same electronic flow measurements, but in different ways, One at a limited minimum timing (One Second, and a "Coulomb" defining Electronic Volume is then understood as "One Ampere" based on that great French Scientist...The other based on Potential Difference between two points as Volts...rendering its name to Alessandro Volta, great Italian Scientist...different times...
      Anyways...Amps are Measured in Closed Loops only...and that is a disadvantage to measure my Motors...they are never closed...always flowing freely...where there is not opposed traffic...but at most, a heavy traffic, like a "rush" but all electrons flowing same "one way"...never colliding frontally.
      See one thing most are missing or disregarding here, just because dedicating time to calculate Amperage at constant open loops..No one has dedicated a minute to analyze My Magnetic fields...and would never understand my motors if you do not see them...
      Effective Voltage is our Rotor Voltage Power, given by Counter EMF, which, since it is a reverse value to our Input...is then subtracted..to our Source Input...are we right til now? Yes effective voltage is input voltage minus CEMF.
      Ok, My Motors do not have C EMF...What do we do now?
      In Peter Lindemann is very simple deal, He gets in 12.1 V...and C EMF is -9.0V
      This if we use very simple math gives Us a Voltage value of 3.1V...are we ok to here?
      Yes.
      Grreat!!
      Then we have an Ev (Effective Voltage)...not Total Output, Carroll, of 3.1 Volts as Armature Voltage Power...right? Yes that also is correct.
      Grreat!!
      Ok, Dear, so then, I will let you "Calculate" My Motor math as Ev amount (not output)...How much, do you think that is? There is no way to calculate the Ev without knowing the current going through the armature and also the armature resistance.
      So what do we do??
      Resistance could be calculated by each pair of coils at stationary level, and add'em up...but that would be a wrong result, just because, they are never "all" touching-contacting in series...so it is completely "unpredictable" How many times coils are sweeping comm elements at two-one (2-1) ratio per Nano/Milli second of rotation...meaning, there is only two choices...either Coil Pairs are solid contacting comm element...or Two at same time, but then resistance between them two... would have to be calculated as parallel, not serial connection...meaning R1(Coil 1)+R2(Coil 2)/divided 2...
      And remember I mean Effective Voltage, not Total Output Then why did you use your measured output and claim it was the EV?
      You tell me...
      Now COP, derives from Ev/Ea, meaning Effective Voltage divided Input Voltage...In Mr Lindemann's video, it renders a COP of 3.1/12.1=0.256
      You are confusing COP with effieciency. They are not always the same thing.
      Ok...let me see if I understand what you wrote..."they are not always the same thing..."
      Meaning not always...maybe tomorrow...or Friday...but never "always"?
      Dear Carroll, COP, (Coefficient of Performance) is the Final Residue or left over Electrical Value inside the Motor Armature, after deducting the C EMF to your Electrical Input, ..Divided its Input...
      Motor Efficiency is only measured by the Mechanical Force of the Motor's Shaft, as "P out"/P in and given in Nm, Horse Power or Watts calculations
      However works based on same Formula as COP, but where P Out is given by shaft force, not electrical residue at armature...
      Whenever you finish doing this math...then we could calculate my COP properly then...
      I do not know why we are all arguing over something so simple...if we would be talking about Maxwell's Quaternions Formulas...I would understand, or even High Level Algebra ...but...not in so simple math...
      Please understand I am not saying your motor is not doing all you claim. In fact I am greatly impressed by the design of it. I have never seen anything quit like it in all my years of working on motors and generators. I am only saying you are not doing the calculations correctly.
      Thank You Carroll, no one here will know how to do the "calculations" right...including Me, We were never taught Asymmetrical Systems...
      Never seen anything like it?...Did you ever care to look at Nikola Tesla Electrodynamic Machines lay outs, back in 1888 to 1910?
        Same question from my side!
        This is a drawing of the generator mentioned.
        The left two are the old 6V models not being compatible to the right hand side 12V model.
        Pic1
        Pic2
        Pic3
        PIC4
        Jst got one at ebay: 14V / 32A / 28 bucks.
        From what i remember the earlier vw generators, the type used for the lockridge device had thinner and longer slots. The type used in the earlier years. Also there was some winding difference. but dont recall if it was the armature or the feild coils. this info was gathered from a vw generator rebuilder from california earlier this year.
        Much easier to get a Gm delco generator and cheaper. most parts fit through all the years. there is a long and a short case on those.
        these have 14 armature slots and 28 bars.
        UFO-- while on the subject of these GM Delco generators. i wonder if it would be appropiate to ask how to wind the 14 slot and 28 bar armature.
        These are pretty easy to get to experiment on . I have ruined about 50 of these the last couple of years trying different renditions of the lockridge. The residual magnetisim always seems to be a wolf in sheeps clothing. i can get it to speed up in rpm putting a load on it, close to 900 rpm. When motorising. But when being drive its a different story same as when coasting. thanks for your input.
        • My opinion
          Originally posted by DadHav View Post
          UFO. Check and see if I have this right. By making this connection you have the input voltage across one of the windings then you connect the second wind in series to the first. At this time you have a voltage drop across the first wind with the addition of whatever you can generate on the second winding. Sounds exactly right about 18 volts I can get the same thing with a standard generator setup and either way you cannot use the increase voltage without the input current going up. I have explained the same exact connection dozens of times on the Monopole forum and on my videos. I use an extra coil of a window motor in series with the power coil. The output is taken from the start of the power coil to the end of the added coil. the result is about an 80% increase in voltage. I never had the nerve to call this a COP of 1.8 because I don't have .8 volts over unity to add back to anything or us it in any way that would prove over unity. Take a look at this video to see what I'm talking about:
          Window Motor Runs Window Motor. - YouTube
          You will see much more stuff on the output running at more voltage than the input. But this is still not over unity no matter what the COP on a piece of paper says. The young experimenters here and on most other forums are looking for something they can see in reality. Over Unity = Self Run or Charging several batteries from one. If your over unity is only on paper then you need to explain this to everyone who is following you here.
          Here is a video for the benefit of the two inventors who did the generator test and it may also interest others. This is a video that I was going to save to show how much better the modification was but now I can see I wont need it for that.
          http://www.youtube.com/my_videos_edi...id=VwRmkYhxqXE
          That's right I was going to try the same test the others did and I may have even encouraged them so I'm the one who should take it on the chin not them.
          John H
          Hi all,
          Let me try to clarify basic approach to "over-unity".
          Over-unity is always pure magnetic performance.
          So we need to think magnetically!
          How?
          In my opinion asymmetric approach is big advantage in the dc motors(rotor)- engineering because of avoiding collision between input magnetic field and induced magnetic field -back emf.. but..we need to think about THIS:
          Anytime we have: copper-pm magnets topology,we will ALWAYS have magnetic drag because of counter mag. field induced in copper wires when approach pm. magnets...so it mean that we do not have here an clear no back emf performance.
          If we want to have better cop and even over-unity than we need to have no back emf performance at all and achieve PURE MAGNETIC COUPLING BETWEEN ROTOR AND STATOR without inducing any add. magnetic field.
          So,an topology combination with copper and pm. magnets will NOT provide pure magnetic coupling without induced back emf performance in copper wires!!
          Now what to do..?
          Or we need to change topology and replace pm. magn. stator- with pure electromagnet-(copper and soft iron ),
          or to replace rotor with pure soft iron with no magnetic memory(no steel)!!
          Any other combination leads to induce add. magnetic field,dragging and back emf performance between rotor and stator!!!
          In pure magnetic topology there is not INCREASING amps draw when is motor shaft on load-just slowing down but INPUT POWER STAY THE SAME!!!!!
          The output power will depend only from the magnetic power coupling from the stator electromagnets(how thy are strong) and how close is iron rotor(or asymmetric copper rotor) to the stator!!!
          So,in such topology WITHOUT PERMANENT MAGNETS- we will have with this asymmetric rotor mode:
          asymmetrically wounded copper rotor and copper stator.
          All what we need is properly pulse on/off stator and rotor and have pure magnetic coupling without induced back emf what is the case with pm magnets,or :
          we can replace copper rotor with pure soft iron rotor and have also pure magnetic coupling.
          Additionally we can always in this topology collect even 90% of collapsing magn. field energy from the stator electromagnets with well known diode plug fashion and ALL POWER FROM THE SHAFT WILL BE FOR FREE WITHOUT AFFECTING INPUT POWER ON LOAD!!
          That is my opinion.
          waterfall
          • Originally posted by Ufopolitics
            This diagram doesn't show any efficiency measurement at all. There is no power
            output at all, so it's all loss, just measure the input power and that is the loss there.
            To determine efficiency you need a measurement of input "power" and a
            measurement of "intended" or "wanted" output "power" then divide the output
            power by the input power and multiply the result by 100 to get a percentage.
            But without a load there is no output so all the input is a loss.
            • Just For Your Eyes Farmhand...
              Hello Farmhand,
              How are you?...fine?
              Great...You Farmhand do not change...Man!!
              The thing is...
              I know exactly what Efficiency is...
              What everything is...but
              beyond just that...I've got the proof it works...no matter what anyone here says...
              Real working models man...did you see my video?
              here take a look since you are here...pls do not miss it...I dedicate it to you...serious...I mention you there Farmhand...turn volume up...
              20090823173537 - YouTube
              but later on I would have another one...see if you could "debunk it"...
              And yes, I imagine it first, design it make it work in my head...then build it and it works at first shot...do you?
              Keep your "optimistic mind as always"...you will really get far...very...
              Many regards
                I'm afraid I have to agree with Farmhand on this one. I think I am beginning to understand the principles on how this stuff works and why it can be COP>1 (see Gray thread: http://www.energeticforum.com/renewa...tml#post202066 ).
                I think the gain is to be found primarily in the magnetics and not in the electric part of the circuit, although it appears to be possible to introduce some asymmetry over there also. I think one can use (relatively) high voltage pulsed discharging in order to create a strong magnetic field, which is contained and stabilized by the core (an extrapolation form Leedskalnin's experiment), and then use the generator brushes in order to capture the BEMF. Since the power of the magnetic field is determined primarily by the amount of current fed into the coil and a closed-loop iron core can apparently amplify and stabilize such a magnetic field, one might be able to reach a COP>1 on the electric side as well.
                So, I see a lot of potential in this design and I am very grateful for Ufo to have published this. We can all make replications for very little money and do our own measurements. So, I see Ufo's disclosure as a gift, which enables me to study and enhance my understanding.
                So, may be it's a better idea to start new threads for discussing measurement methods and for discussing the theory (perhaps the theory can be discussed on the Gray thread, since it appears to connect).
                That may be much more fruitful.
                • Dollar store motor
                  Originally posted by b_rads View Post
                  Maybe I can clear up what my test was about.
                  The little battery fan motor from the dollar store is about as cheaply made as you can get. The brushes are very thin gage copper foil, certainly not made for 1.5 amps. I used the higher power as it showed exaggerated differences between the motors. Comparing unmodified to modified motors is comparing apples to oranges, but does give expected baseline results to compare with.
                  Retested with new unmodified motor and modified motor with new brush cap. The unmodified results: 2.6 Volts unloaded (2 AA batteries) ran the motor at 2 volts and 220mA for 0.44 watts. The modified ran at 1.5 volts and 280mA for 0.42 watts. Putting ground to the case does act like a resistor dropping the voltage. For this I got higher RPM’s (approx 700) plus generator output – enough to light an LED.
                  Using the 2 AA batteries, I do not see any abnormal wearing of the brushes nor could I tell that the motor was running hotter. I will be attempting the slip-ring method on a better motor next to confirm the results I saw in this test. All in All, this test did confirm that the motor did run more efficiently, at higher RPM’s, and with generator output as a bonus.
                  Brad S
                  Brad,
                  I replicated your little dollar store slip-ring motor today. I have the Radio Shack motors but I wanted to try your approach first. The RS motor is actually a very hard build for me and I don't know if I will even attempt it. It is not really a kitchen table project. Your little "slip-ring" three pole motor from the dollar store IS doable by almost anyone. My store was out of the fans but I found the same motor in an electric toothbrush. I used the same wire that the motor came with by carefully unwinding it. Thanks for the excellent video on how to make the motor modification. I am discovering many wondorous things with just this newbie starter motor. My "Penny" oscillator runs off the generator part great.
                  @UFO
                  This is a facinating thread and you have the attention of many people. Thanks for sharing what you know.
                  Lidmotor
                  • So that is great I got both of you guys here...
                    Hello Lamare, hello Farmhand...
                    And Hello to all...
                    Well, I am just going to throw out there for you guys very simple questions...
                    Then You tell me...
                    Finally...does any Inductor, coil of magnetic wire...wrapped up on anything except steel..., lets say a piece of plastic...fiberglass..
                    If I pulse it ...collapse the field right?
                    Now the question for you BOTH, Lamare and Farmhand...
                    DOES THE INDUCTOR FINALLY CHANGES ITS MAGNETIC POLARITY WHEN I PULSE IT?
                    I want straight YES/NO...really do not want to hear any more Physics Explanations...kind of tired of them all...
                    I just need that answer...if possible...so I could close my "loop"
                    tonight
                    • UFO,
                      You said you were friends or at least speak with Romero. Is this what he did at first when he said he rewound a turnigy motor to attach to his generator? Not stating validity of Romero device since he himself claimed it was a hoax. (Still undecided). Just wondering Bout that turnigy hobby motor.
                      • Originally posted by minoly
                        But JB is using this in an entirely different way than you are here UFO. Your way is producing usable power/torque.
                        So what is JB's way producing if it is not producing power/torque Patrick?
                        John K.
                        http://teslagenx.com
                          John K.
                          He doesn't know John, he just want to sound like he does. Bunch of Mumble....LOL
                            Wow! Matt with the ideas speaks again. How's that 3bgs coming along.
                            Its coming along good had to make few changes though, that happens in course of development. Wouldn't expect you to understand though, its a different game when all you do is copy people's work, but then again your not capable of that are you?. LOL
                            Just some mumble from minoly.
                            • Hi all
                              @citfta
                              I agree with you.
                              Your exposition is clear, accurate and with exquisite education.
                              If the tests are wrong in the approach then lead to erroneous conclusions. I fear this may be the explanation.
                              What are the facts?
                              DiD --> Data is Data, not explain thories with puzzled answers.
                              What are the Amps? Can be difficult read Amps then we must design the experiment to talk about work/power. But work/power input versus work/power output.
                              If we modify one original 700w motor.This does not mean that the modified motor produce the 700w. Can be more or less. Again, we need tests.
                              Can be self-sustaining?
                              Which is the response curve with load/work?
                              Many questions ... LOL
                              Hopefully become clearer to all the doubts.
                              http://Cacharreo.com.es/foro
                              • Hi Ufo.
                                As best as I can see, when looking at the 5 pole motor, it seems that one of the 5 poles segments is energized both north and south at the same time, when the brushes are touching 2 segments of the commutator at the same time. The more worn in the brushes are, the longer it will last. Its at the time the pole passes the middle of the magnet.
                                |o|N|N|S|S|
                                |N|N|S|S|o|
                                Will this effect the way the energy is passed on to the output brushes through the coasting stage.
                                Thanks netica
