I wanted to start this thread, as a repository for all research/example that point toward this simple fact.
Why do you ask? Because it could just be one step away from proving the possibility of telepathy (receiving and emitting waves).
here goes nothing:
Fractal antenna - Wikipedia, the free encyclopedia
fractal property of nature
Patterns of Visual Math - Fractals in Nature
Fractal in Human Body
Applications of Fractals - Human Body
George O. SQUIER: Tree Antennas
George O. Squier ~ Trees as Antennas ( Scientific American, June 14, 1919 & British Patent Specification # 149,917)
The New “Power Plants”: Trees Make Electricity?
The New “Power Plants�: Trees Make Electricity? : TreeHugger
It is your Brain that determines the color:
Seeing color | Causes of Color
How do we hear?
How do we hear?
note: Remember that every interaction we have as human with our surrounding is just an electric impulse interpreted by your Brain (add this to electric universe theory)
example:
Implanted electrodes enable a paraplegic man to stand, regain leg use
GOD Helmet
God helmet - Wikipedia, the free encyclopedia
Neurobiologists Find that Weak Electrical Fields in the Brain Help Neurons Fire Together
link:
Neurobiologists Find that Weak Electrical Fields in the Brain Help Neurons Fire Together - Caltech Media Relations
Shape analysis of MR brain images based on the fractal dimension
http://citeseerx.ist.psu.edu/viewdoc...=rep1&type=pdf
here goes nothing:
A fractal antenna is an antenna that uses a fractal, self-similar design to maximize the length, or increase the perimeter (on inside sections or the outer structure), of material that can receive or transmit electromagnetic radiation within a given total surface area or volume.
Such fractal antennas are also referred to as multilevel and space filling curves, but the key aspect lies in their repetition of a motif over two or more scale sizes,[1] or "iterations". For this reason, fractal antennas are very compact, are multiband or wideband, and have useful applications in cellular telephone and microwave communications.
A good example of a fractal antenna as a spacefilling curve is in the form of a shrunken fractal helix.[2] Here, each line of copper is just a small fraction of a wavelength.
A fractal antenna's response differs markedly from traditional antenna designs, in that it is capable of operating with good-to-excellent performance at many different frequencies simultaneously. Normally standard antennas have to be "cut" for the frequency for which they are to be used—and thus the standard antennas only work well at that frequency. This makes the fractal antenna an excellent design for wideband and multiband applications.
If you are still not convinced that that fractals, being a math topic, are very important in real life, your opinion might change after finding out that you yourself are made of fractals!
It is not a joke nor a scientific curiosity, this strange discovery of Gen. George O. Squire, Chief Signal Officer, that trees --- all trees, of all kinds and all heights, growing anywhere --- are nature's own wireless towers and antenna combined. The matter first came to his attention in 1904, through the use of trees as grounds for Army buzzer and telegraph and telephone sets, which, in perfectly dry ground and in a dry season, functioned poorly or not at all with ordinary grounds. Right then he began experiments with a view to seeing what possibilities, if any, the tree had as an aerial. But in 1904 radiotelegraphy was far more undeveloped than at present, and vacuum amplifying tubes were not thought of.
It appears that a small electrical component company near Boston has figured out how to get electricity out of trees. MagCap Engineering is pretty sure they’ve come up on the next renewable energy revolution. By pounding a nail into the trunk and a conductor into the ground, a faint but consistent charge is detected in a wire running from the tree to the earth.
Typically, humans have three different types of cones with photo-pigments that sense three different portions of the spectrum. Each cone is tuned to perceive primarily long wavelengths (sometimes called red), middle wavelengths (sometimes called green), or short wavelengths (sometimes called blue), referred to as L-, M-, and S- cones respectively. The peak sensitivities are provided by three different photo-pigments. Light at any wavelength in the visual spectrum (ranging from 400 to 700 nm) will excite one or more of these three types of sensors. Our mind determines the color by comparing the different signals each cone senses
How do we hear?
The human eardrum is a stretched membrane, like the skin of a drum. When the sound waves hit your eardrum, it vibrates and the brain interprets these vibrations as sound.
example:
GOD Helmet
God Helmet refers to an experimental apparatus used in Neuroscience, primarily in the field of neurotheology. Originally called the "Koren helmet" after its inventer Stanley Koren, it was conceived to study creativity and the effects of subtle stimulation of the mesiobasal temporal lobes.[1] Reports by participants of a "sensed presence" brought public attention to the God Helmet through appearances in several TV documentaries showing it in use.[2]
The apparatus, placed on the head of an experimental subject, generates weak fluctuating (i.e. "complex") magnetic fields. These fields are approximately as strong as those generated by a land line telephone handset or an ordinary hair dryer, but far weaker than that of an ordinary fridge magnet. It is used extensively by Michael Persinger, a neuroscientist at Laurentian University in Sudbury, Ontario, Canada. Persinger has published extensively about the effects on the human brain of the "complex" magnetic fields generated by the God helmet and other similar devices.[3] Many subjects have reported "mystical experiences and altered states"[4] while wearing the God Helmet
"So far, neural communication has been thought to occur almost entirely via traffic involving synapses, the junctions where one neuron connects to the next one. Our work suggests an additional means of neural communication through the extracellular space independent of synapses."
Olena Buczko*, Paweł Mikołajczak
Faculty of Mathematics, Physics and Computer Science, Maria Curie-Skłodowska University,
pl. M.Curie-Skłodowskiej 1, 20-030 Lublin, Poland
Abstract
This paper presents some results concerning the application of the fractal approach to the
analysis of shape of white brain matter in the magnetic-resonance (MR) images. The fractal
dimension of white brain matter was calculated using the box-counting algorithm.
Abstract
