Who killed JFK?
  • #31
    These are frames 312-313 which show the glaring difference between the rear without any obstruction and the blasted hole. The hole didn't start forming until after 312. The gif file is the best one I found and depicts the rear gaping open twice in 1/18 of a second. In a real debate, the Oswald looneys could not ignore the hole on the rear because that's where they say it entered.
    • #32
      Hey look, A man sitting down just like jfk was, getting shot in the back of the head and his head and body move forward, the exact opposite of jfk's violent throw-back of his head and body. It's all about finding the right comparisons, which I did years ago. The clear mist is a sure indication of where the bullet enters. In the case of Jfk, it entered directly over the right eye which produced a small, neat hole. In the bottom gif you can see skull detaching from the rear.
      • #33
        I started looking at the Zapruder film almost seven years ago and it went from there. I got the closeup of Greer's arm going over in 9-2010. That's what's made it factual. I paid a guy a whopping thirty dollars to enhance it. Once that was clear this case was closed for everyone willing to look past all the nonsense that came before it. If Greer's left arm really moved back toward JFK just the way it appears to in Zapruder, then he was definitely the shooter. They apparently had to create a cartoon of Greer shooting jfk, which is quite comical to say the least.
        jfk assassination films-orville nix - Video Dailymotion
        • #34
          The passenger retrieved the handgun Greer used on Kennedy, which is seen in frame 319 and around 30 earlier frames during which Greer transferred it to his left hand. Kellerman's head literally went face down toward the floorboard on the driver's side.
          The passenger, Roy Kellerman reaches way to his left and retrieves the gun after jfk is assassinated. He apparently braced his left arm on the seat and grabbed the gun with his right hand. The arrows indicate his head and upper right arm. The only time in recorded history where a hair reflection fell off a head is in Zapruder frame 318. You can see his head go right down to the driver's side floor. Note the white seen in frame 320, confirming that it was not an artifact or shadow but something very real that could not be removed, apparently.
          https://www.youtube.com/watch?v=zP_9Cbn_m20
          Zapruder Frames - Costella Combined Edit
          • #35
            We do know for sure that the fake reflection is in perfect sync with the front entrance. And Greer is looking right at jfk before, during and after the shot. IT EVEN RECOILS.
            • #36
              The clear bullet impact smoke at the point of entrance is unfalsifiable. The bullet entered directly over the right eye. There is a red spray which is indicative of an exit but that was added to cover the area where the bullet actually entered. The clear bullet impact smoke is where the bullet entered, that's just the way it is. The Nix film headshot does NOT depict any red spray, just the bullet smoke. That's independent proof that the red mist was added to jfk's face in Zapruder's film.
              • #37
                During the alteration of Zapruder they compressed the impact and rear skull gaping into one frame and did their best to isolate this evidence by keeping it in between most subsequent frames, but slow-motion exposes it, clearly. 313, 319, and 337 show the hole.
                312, no gape.
                313, complete rear gape.
                312-313 Nails it.
                • #38
                  "The President was struck in the forehead. All of the brain matter went out the back of the head. It was like a red halo, a red circle with bright matter in the middle of it, it just went like that. (She means the mist disappeared into the air). The back of his head blew off, and it doesn't make sense to be hit from the rear and still have your face intact. He must've been hit from the front or side, but the back of his head blew off." Great quotes from eyewitnesses.
                  https://www.youtube.com/watch?featur...&v=WHvfDijnASM
                  THE RED BLOOD SPRAY CAME OUT THE REAR AS THE WITNESSES CONFIRM. THE GOVERNMENT GOONS PUT IT ON THE FRONT, BUT COULD NOT REMOVE THE GAPING HOLE AND SKULL DETACHING.
                  • #39
                    There is no subculture. I proved it three years ago after a 14 month obsession over the Zapruder film and this now proven fact. That led to the Nix and Muchmore films which both show Greer's left arm moving with the headshot.
                    Marrs Rebuts JFK Driver As Shooter Theory
                    It's no longer a mystery why this slob, Jim Marrs told this huge lie just three years ago. He completely defines a true conspiracy kook. Making up bulldung to sell books and on the other hand denying the obvious truth about JFK being killed by his own bodyguard, SECRET SERVICE AGENT, DRIVER.
                    He lied because he knew he could probably get away with it indefinitely but those days of claiming authority are over. Jim Marrs cannot debate against this proof because he'd have to answer to the running video which depicts the exact opposite of his absurd lie. He would have to prove the negative that Greer's hands can be seen clearly and are NOT off the wheel moving around while he passes a mystery object bleached white/grey just like they clearly are.
                    I have studied first-generation clear prints of the Zapruder film and it is apparent that while it may be questionable as to why Greer turned and looked back at Kennedy and then could not recall that fact for the Warren Commission, at no time did his two hands leave the steering wheel of the limousine. There are plenty of real conspiracies out there without dragging this old wheezer up again.
                    Mountebank, pronounced "MOUN-tih-bank," has an interesting origin, in the Italian phrase "monta in banco." It describes a "doctor" who would "mount a bench" in the marketplace. Standing a bit higher than the crowd enabled people to hear his sales pitch and see the potions and powders he claimed were medical cures that never failed — claims as bogus as his credentials. A mountebank is a fast-talking crook pretending to be an expert.
                    pro·sa·ic (pr-zk)
                    adj.
                    1.
                    a. Consisting or characteristic of prose.
                    b. Matter-of-fact; straightforward.
                    2. Lacking in imagination and spirit; dull.
                    • #40
                      JFK was killed by his own administration/government because of his opposition to the Vietnam War. And just a lot of other things. He supposedly said he wanted to dismantle the CIA. The KENNEDYS WERE HATED, BIG TIME.
                      http://www.globalresearch.ca/jfk-ass...public/5346419
                      LS: What do you see as the prime motive(s) to get Kennedy killed?
                      MB: To make a long story, which I elaborate in the book, short: JFK had made definitive steps to end the cold war. He had denied the involvement of the army in the Bay of Pigs invasion, which he had inherited from his predecessor, he had solved the missile crisis in Cuba through direct and secret contact with the Soviet-leader Khrushchev, he had ensured a nuclear test-stop with the Soviets, and he had ordered the withdrawal from Vietnam. All this against the will of the military, the CIA, and even against many members of his own administration.
                      LS: If one looks at the crime from the perspective of “motive, means, opportunity,” which groups are the most likely culprits? Some of the usual suspects may have had a motive, but neither the means nor the opportunity, right?
                      MB: Yes. This is a crucial point with many JFK theories. A lot of people had motives, be it the hardcore commies in Russia, China, Cuba, be it the Israelis because of JFKs dismissal of nukes in Israel, be it the Federal Reserve because of his idea for a new US dollar backed by silver, the mob because of his dismissal to invade Cuba to get their casinos and brothels back, the racist Southerners because of his engagement for civil rights… but no one of them had the means and opportunity for the murder and above all the means to cover it up over the years.
                      LS: Which party had the necessary components of “means and opportunity” available?
                      MB: Only the CIA and the military – and the FBI and the Johnson administration for the cover-up. A moment after the shootings, a policeman ran up to the grassy knoll, his gun pulled out, and stopped a man there, asking for his ID. The man showed a Secret Service card and the cop let him go. Several other men on Dealey Plaza also showed genuine looking Secret Service IDs when asked by cops – but there were no real Secret Service men placed on the knoll and the plaza this day.
                      These IDs were fakes but the FBI and the Warren Commission didn’t investigate this at all. Only in the 80s it came out who was responsible for the printing of Secret Service IDs and passes at that time: it was the CIAs Technical Division, headed by Sydney Gottlieb of “MK Ultra” fame. This fact alone rules out that the mob or the Russians, Cubans, Chinese or some other autonomous killers did this on their own bill. And even if these groups would have been able to fake genuine looking Secret Service IDs – the fact that this deception was not investigated, immediately brings Hoover’s FBI into a top-position of suspects.
                      • #41
                        Originally posted by frisco kid
                        Here's an email exchange between Tyler Newcomb and myself in regards to an audio interview of Jean Hill acquired by them around 1971. Tyler is working to get some of this vintage audio online. I will keep you abreast of Tyler's progress unless he starts posting himself. Below is an excerpt from Tyler's foreword in Murder from Within which was republished in 2011. Jean Hill confirms more directly in this interview that there was a shot in the front of Jfk's limo and that is just icing on top of icing at this point.
                        The exact quote on the tape was "Yes" when asked…"But you do remember at least one shot from the front of the car"
                        On Aug 4, 2013, at 1:17 PM, "." <.com> wrote:
                        Creepy for sure, including Roy! What about that transcript of Jean Hill? Even just some of it. Are these from your interviews? Are they accurate?
                        Zapruder Film Shows JFK's Driver Firing Fatal Head Shot (August 7, 2007)
                        1. Mary Moorman - school teacher standing next to Jean Hill. She said she saw Greer shooting back but thought he was shooting back at the assassin. SOURCE: Warren Commission and taped interview by Fred Newcomb.
                        2. Jean Hill - Jean Hill saw what happened too, but when she tried to bring up the subject of a gun being fired in the car, Senator Arlen Spector (a 33rd degree Mason) would change the subject or say "it's time for a cup of coffee
                        Murder from Within: Lyndon Johnson's Plot Against President Kennedy: Fred T. Newcomb: 9781463422424: Amazon.com: Books
                        During this time Dad (FRED NEWCOMB) and his two associates Gil Toff and Roy Dennis telephonically interviewed nearly 50 witnesses comprising 30 hours of tape. Many of these interviews became the basis for the book. One cannot listen to some of the Dallas Police officers interviewed (who smelled “gunpowder right there in the street” and heard shots “right next to me”) and not come away convinced there really was gunfire from within the motorcade. One cannot listen to 2 police officers stationed at Parkland Hospital who were standing next to the Limo and who each saw a bullet hole in the windshield and not become convinced of evidence tampering by the Secret Service.
                        Jean Hill saw Greer shoot Kennedy
                        She was just speculating that Greer was shooting back at whomever was shooting at the President. This was an easy way of saying it without exactly saying it. But in those moments she may have thought it because it would be shocking to see your President killed intentionally by the men who took an oath to protect him from assassination attempts. Mrs. Hill clearly turned to the left as the limo passed by in response to the shots and Greer suddenly braking during his second turn to execute the coup de grâce.
                        Testimony Of Mrs. Jean Lollis Hill
                        Mr. SPECTER - What occurred at the time of the fourth shot which you believe you heard?
                        Mrs. HILL - Well, at that time, of course, there was a pause and I took the other shots---about that time Mary grabbed me and was yelling and I had looked away from what was going on here and I thought, because I guess from the TV and movies, that it was Secret Service agents shooting back. To me, if somebody shoots at somebody they always shoot back and so I just thought that that's what it was and I thought, well, they are getting him and shooting back, you know; I didn't know.
                        Mr. SPECTER - Where was the President's car at the time you thought you heard the fourth shot?
                        Mrs. HILL - The motorcade came to almost a halt at the time the shots rang out, and I would say it was just approximately, if not---it couldn't have been in the same position, I'm sure it wasn't, but just a very, very short distance from where it had been. It was just almost stunned.
                        Mr. SPECTER - And how about the time of the fifth shot, where do you think the President's car was?
                        Mrs. HILL - That was during those shots, I think it wasn't any further than a few feet---further down.
                        Mr. SPECTER - Which shots, now---you mean the fourth, and perhaps the fifth and perhaps the sixth shot?
                        Mrs. HILL - Yes.
                        Mr. SPECTER - You thought that perhaps the second burst of shots you heard were being directed toward him by the Secret Service?
                        Mrs. HILL - I Just thought, "Oh, goodness, the Secret Service is shooting back."
                        Mr. SPECTER - What was your impression as to the source of the second group of shots which you have described as the fourth, perhaps the fifth, and perhaps the sixth shot?
                        Mrs. HILL - Well, nothing, except that I thought that they were fired by someone else.
                        Mr. SPECTER - And did you have any idea where they were coming from?
                        Mrs. HILL - No; as I said, I thought they were coming from the general direction of that knoll.
                        Mr. SPECTER - Well, did you think that the Secret Service was firing them from that knoll?
                        Mrs. HILL - I said I didn't know-I really don't.
                        Mr. SPECTER - You just had the general impression that shots were coming from the knoll?
                        Mrs. HILL - Yes.
                        Mr. SPECTER - And you had the general impression that the Secret Service was firing the second group of shots at the man who fired the first group of shots?
                        Mrs. HILL - That's right
                        Mr. SPECTER - But you had no specific impression as to the source of those shots?
                        Mrs. HILL - No.
                        Jean Hill was looking at the limo when Greer shot Jfk. FRAME 310.
                        Had the question been "from in front of the car or simply, in front of the car" that could certainly have meant somewhere outside of the car but those words weren't spoken. FROM THE FRONT OF THE CAR LEAVES DOUBT THAT HE MEANT INSIDE THE CAR. TAKE OUT FROM AND YOU HAVE, THE FRONT OF THE CAR. VERY SPECIFIC. The key word here is, the, instead of in.
                        I can think of two natural ways to word questions that indicate a shot from the front, but not from inside the car. Adding the word 'from' in the second question would be unnecessary because it could still mean in the car. That debate will never happen because Roy Dennis didn't say those words.
                        Do you recall at least one shot from the front?
                        Do you recall at least one shot in front of the car?
                        Roy Dennis: But ah, you do recall at least one shot from the front of the car? Vocaroo | Voice message
                        Jean Hill: Yes.
                        • #42
                          Bill Hicks on the JFK Assassination - from Revelations - YouTube
                          Al
                          • #43
                            There are no eyewitnesses who saw a hole on his face and if you can find one, there are forty who saw it on the opposite side. Of course the back of his head is gone in Zapruder. There is no debating that. The hole over the eye was altered in some way, but that's where it entered. The films are exactly what would be used in a debate, no doubt about that. That's exactly what I did successfully to the point of no challenge.
                            There's nothing blurry about the rear blow-out, the attempts to hide it, or skull detaching. It's perfectly clear and it matches an endless eyewitness count. The ficitious entrance wound that ain't on the rear has to be where the massive rear hole is, on the rear. The Commission Crazies can't go anywhere near the rear any longer, since the hole has been acknowledged. There is no longer any doubt about the rear exit, NONE.
                            • #44
                              V. Palamara: Notes on Bill Greer
                              It took almost 47 years to prove Greer was jfk's real assassin. We know now the only one important thing Greer kept secret.
                              Greer retired in July 1966 after having undergone a stomach operation and Jackie Kennedy sent him a letter thanking him for being with the President until the end.
                              He said he "saw blood on Connally's shirt" and looked back only "one time", in direct contrast to the Zapruder film. He went on to say that he "didn't really see the President at all".
                              Said the Zapruder film "was proven legitimate".
                              Claimed to have not seen anyone on the triple overpass.
                              Regarding the assassination itself, Greer claimed that "we never stopped...there was no reason to stop...no need to stop." In regard to the direction of the shots, he said that "everyone was hit from the rear...my back was covered with it [debris from head shot]." When told that Connally has always insisted that he was hit with a different bullet than had hit JFK, Greer said "I feel that way, too. They [the Warren Commission] had lawyers working on it...these lawyers had already made up their mind". Greer also believed that the back wound [which he referred to as being in the "back of the shoulder"] did not go through and that that was also the first thought of the autopsy doctors in attendance.
                              Greer claimed he was "in the OPERATING ROOM at Parkland" [emphasis added] and stated that JFK's clothing "were in my custody from Parkland to Washington."
                              Greer denied that there was a hole in the limousine's windshield. He said there was only a "star"; a spidering crack.
                              Greer did not know why the photographers were out of their usual position in front of and close to JFK's limousine that fateful day in Dallas, but did not seem to regard this as suspicious.
                              Regarding agent Roy Kellerman, Greer said twice that he was "a very fine gentleman." Regarding President Kennedy, Greer said "He and I were pretty close friends. He treated me just wonderful."
                              Regarding William Manchester and his book "Death of a President", Greer said harshly "He's garbage...didn't like it at all", further commenting on Manchester's criticism concerning his age and reflexes behind the wheel [Greer thought that his experience was an advantage, coming from "years of experience" , and certainly not a disadvantage]. He went on to say that he thought that Jim Bishop's book ("The Day Kennedy Was Shot") was the best book of all regarding the events of November 22, 1963. (However, keep in mind that his comments were made in 1970)
                              Greer said, somewhat cryptically, "there's alot of things I know that no one else knows." (!)
                              Finally, Greer said that the Warren Commission closed up shop too soon and that "there might have been a conspiracy in another part of the country." [!!!]
                              https://www.youtube.com/watch?v=nYdB3e6yQ9E chaney
                              • #45
                                John F. Kennedy Assassination Homepage :: Warren Commission :: Hearings :: Volume II :: Page 128
                                There are few things more ironic than jfk's real assassin describing his own shot and ultimately debunking Oswald and the grassy snow job. At the end of Greer's testimony here, he takes his finger over his right forehead and drags it along his right temple to his right rear. Note how Greer doesn't turn around and speed off until he's sure his shot connected.
                                Greer confirmed his own shot with the help of Arlen Specter. Over the right eye out the right rear. It's that simple. Greer already pointed over his right eye, therefore, upper right side refers to that specific location.
                                Mr. Specter.
                                Did you just mention, Mr. Greer, a hole in the President's head in addition to the large area of the skull which was shot away?
                                Mr. Greer.
                                No. I had just seen that, you know, the head was damaged in all this part of it but I believe looking at the X-rays, I looked at the X-rays when they were taken in the autopsy room, and the person who does that type work showed us the trace of it because there would be little specks of lead where the bullet had come from here and it came to the--they showed where it didn't come on through. It came to a sinus cavity or something they said, over the eye.
                                Mr. Specter.
                                Indicating the right eye
                                . (Greer pointed over his right eye)
                                Mr. Greer.
                                I may be wrong.
                                Mr. Specter.
                                You don't know which eye?
                                Mr. Greer.
                                I don't know which eye, I may be wrong. But they showed us the trace of it coming through but there were very little small specks on the X-rays that these professionals knew what course that the bullet had taken, the lead.
                                Mr. Specter.
                                Would you describe in very general terms what injury you observed as to the President's head during the course of the autopsy?
                                Mr. Greer.
                                I would--to the best of my recollection it was in this part of the head right here.
                                Mr. Specter.
                                Upper right?
                                Mr. Greer.
                                Upper right side.
                                Mr. Specter.
                                Upper right side, going toward the rear. And what was the condition of the skull at that point?
                                Mr. Greer.
                                The skull was completely--this part was completely gone.
                                Mr. Specter. Now, aside from that opening which you have described and you have indicated a circle with a diameter of approximately 5 inches, would you say that is about what you have indicated there?
                                Mr. Greer. Approximately I would say 5 inches; yes.
                                Mr. Specter. Did you observe any other opening or hole of any sort in the head itself?
                                Mr. Greer. No, sir; I didn't. No other one.
                                Mr. Specter. Specifically did you observe a hole which would be below the large area of skull which was absent?
                                Mr. Specter. Did you have occasion to look in the back of the head immediately below where the skull was missing?
                                Mr. Greer. No; I can't remember even examining the head that close at that time.
                                John F. Kennedy Assassination Homepage :: Warren Commission :: Hearings :: Volume II :: Page 124
                                Mr. Specter. What did you observe with respect to President Kennedy's condition on arrival at the Parkland Hospital?
                                Mr. Greer. To the best of my knowledge he was laying, it seemed across Mrs. Kennedy, looked like laying across her lap or in front of her, I am not too sure which, I opened the doors--the doors were opened before I got to it, someone else had opened the doors and they were trying to get Connally out, and Mrs. Connally out of the seats so they could get to the President.
                                Mr. Specter. What did you observe about the President with respect to his wounds?
                                Mr. Greer. His head was all shot, this whole part was all a matter of blood like he had been hit.
                                Mr. Specter. Indicating the top and right rear side of the head?
                                Mr. Greer. Yes, sir; it looked like that was all blown off.
                                Mr. Specter.Yes.
                                Mr. Greer. I run around the front of the car and got hold of a stretcher or thing and I got hold of it to keep it steady while they lifted the President's body onto it and then I helped pull the front end of it into the emergency room.
                                Upper right side, going toward the rear fired by Greer.
                                That is dislodged scalp on the top back of his head. Humes said so, but I have it on my other computer. He downplays the wound over the right eye because that's where the bullet really entered. Big hole on rear, small hole over right eye. It's that simple. "HIS FACE WAS NORMAL", except for the entrance over the right eye.
