Thread: Bedini SG
Old 06-15-2010, 04:09 AM
minoly's Avatar
minoly minoly is offline
Silver Member
Originally Posted by Slinky View Post
Hey Minoly, i'm pretty sure my wiring is correct although the answers the the above would make me certain.
What don't I know and what have I done wrong is my normal problem solving method
This leaves the puny magnets and coil to be suspect, i'll get on spec and head down there when assembled if I got nowt spinning by then.
I have had that schematic on my desktop for months trying to fill in the gaps, so elegant and simple but a huge rabbit hole at the same time. The theory is surprisingly absorbing.
Will I get the blow by blow flow description at the monopole group Minoly?
Electrons, current, ions, magnetic fluxes, scalar and radiant is a lot to comprehend on top of this gibberish called electronics.
I had heard there were members hanging around and posting but refusing to make the tests and devices, is this true still?
Hey Slinky,
your probably right on w/ the magnet size speculation. That, the number of turns/core size. Do you have close to 6 ohms on the power winding? I watched the daftman's vid - he sure takes the simple SSG ckt and makes it look elaborate and elegant. wish I had a link or a photo for you, you can build that entire ckt right on the transistor - no extra wires.
there are enough good people there that if your efforts are in earnest, you will find the help you seek.
I think the same can be said for many here as well. it just so happens there is a ton of data and support there on the monopole for this.
