Old 06-04-2010, 11:45 PM
Bit's-n-Bytes's Avatar
Bit's-n-Bytes Bit's-n-Bytes is offline
Silver Member
Send a message via Skype™ to Bit's-n-Bytes
Originally Posted by genessc View Post
Ah ok. Sorry I don't get back here more often. The switch I setup outputs 24volts at whatever current based on tuning. It uses 6 batteries at 12 volts each in two banks of 3 batts. The outputs I'm running thru some slightly modified 50va trafos and the 220volt output from the two trafos in series is almost dead on square wave with the way its setup now. I'm currently playing with cap sizes... as I made my iteration so that its a 4 slice controller thats sequential, T1 and T3 were the off timers and T2 and T4 are the ON timers. The caps charge pretty fast, similar to bedinis hyper charging effect from the SG or SS SG.
Do you have a schematic for your two cap pulser?
I'm also thinking to output the 220v into a 120v primary that outputs 600v but should be a good bit higher than that with the square wave being pushed into it.
Take care man,
Gene
Gene, it's a few threads back posted by vissie (NVisser).
Bit's
