  #78 (permalink)
Old 09-30-2007, 12:56 AM
ERKAN ERKAN is offline
Junior Member
Not workin
I pulled everything appart. Then I took new diode, resistor and transistor. Now I get 111mA and litle of humming when magnet is on the coil. I also replaced the neo magnets with normal ones. Neo magnets were very small and the new ones are 3/4" diameter. But whele is still not spining. WhenI put the coil next to the magnet it repels. I don't have a core in my winding.
I have one question: "If you disconnect smaller wire winding should motor work?". When I disconnect the second coil I get 0 amps. If circuit is energized and than connect the smaller wire winding it is still 0 amps. I have to turn the power off and than urn it on in order to work.
What am I doing wrong?
