  #5 (permalink)
Old 04-15-2007, 08:15 PM
Peter Lindemann Peter Lindemann is offline
Senior Member
Designing a motor
Eric,
The magnetic attraction motor, whether it is Teal's electric solenoid engine, my "S" rotor, or other designs, can produce mechanical energy at a different rate of conversion than a standard induction motor, due to the lack of Back EMF. Exactly what this new conversion rate is is still not known, and must be determined by experiment.
You can see from my DVD, the Back EMF is responsible for neutralizing between 50% and 90% of the applied energy in a standard induction motor, depending on load conditions. Assuming a moderate load, it seems reasonable, then, to conclude that it may be possible to create a 1 hp motor that only draws 200 watts. If the electrical recovery system can return 85% of this, then the machine will run on 200 watts, produce 1 hp of mechanical energy, and return 170 watts to the batteries. This suggests that 1 hp of mechanical energy may be able to be produced for 30 watts. This is how Teal accomplished what he claimed.
At this point all of these things must be re-worked out by experiment.
Peter
