  #11 (permalink)
Old 09-22-2007, 02:22 PM
adam ant's Avatar
adam ant adam ant is offline
Senior Member
im glad you brought this up, and i wanted to speculate on your design before, but without any of my own experimentation i didnt want to intrude.
if you look at the real Perendev motor,
the magnets are not facing each other exactly, they are slightly tilted/offset.
if you were to put a SLIGHT tilt on your magnets(or slightly shave an angle into them), i bet you would get the thrust you need.
also, he has his rotor inside of the stator, which would make the rotor fully saturated with the magnetic flux of the stator. you have the plates facing each other, and it seems like it would simply be like two Sumo-wrestlers pushing against each other... no movement.
you can even try this by holding two of those magnets close to each other. if you have them perfectly parallel, there is only a straight, outward push. but if you start to manipulate one of them, you will feel a thrust off to one side.
-bryan
