Old 04-09-2010, 02:06 AM
sucahyo's Avatar
sucahyo sucahyo is offline
Platinum Member
Ben's gift inspire me this. This design require two relay with 4 parallel contact such as FRM3-4B5. It is based from Ronald Brandt version in "report on 4 battery switch".
All the switch (S1 to S6) should closed/gated/turned on when the appropriate relay turned on.
Relay 1 control S1, S3 and S6. Relay 2 control S2, S4 and S5. Relay is powered by source battery.
To comform to C20 charging/discharging, resistor is put in the negative part, maybe a coil would be better.
resistor value is = battery voltage * 20 / battery capacity
example = 24V * 20 / 7A
example = 68.5 ohm
If longer delay time is needed, capacitor can be added in parallel with the relay coil. Power consumption will depend on relay power consumption.
Edit: capacitor should not be added to the second relay because it will produce all relay on condition, my mistakes.
