  #2 (permalink)
Old 07-28-2007, 07:13 PM
Aaron's Avatar
Aaron Aaron is online now
Spiritual Entrepreneur
current powerful technologies
There are a lot of "non-exotic" energy technologies that are available in the here and now and just need more recognition. Here are a few:
vacclaisocryptene - was classified during the war. closest thing to a friction free oil additive for engines, etc... so good it went to the moon. Improves engine life, boosts performance and reduces emissions.
New Quest International has a fuel additive that has over 30 years track record. Florida dept of transportation did a 1 year test on multiple vehicles and it gave them over 12% boost in fuel mileage. Reduces emissions. I got almost as good of results with this compared to the pills below.
BioPerformance - used to have gas pills now is only powder. Attorney general in Texas closed them down claiming it was a scam. They are now back in business because through strict EPA testing, they proved it works. Reduces emissions and improves mileage. I personally went from 300 miles on a tank to 400 miles on a tank in a Honda Civic with 1 pill in 10 gallons of fuel.
Brown's Gas torch - a welding torch that uses only water for fuel. plug into the wall and you have an amazing device. the flame can neutralize radioactivity on contact by over 95%. Eagle Research makes the best ones commercially available. Go check out what it can do.
Hy Tech - Ceramic paint additive. Developed by NASA. Can reduce heating and cooling bills in a home by up to 70% in some cases.
Hy-Tech insulating paint products are based upon our exclusive blend of insulating ceramic microspheres or "vacuum beads", that are designed specifically for mixing into paints, coatings and composites to form a tight interlocking matrix which reduces conductive heat through the painted surface. The ceramic barrier reflects up to 90% of the heat back to the source. My personal feeling is that every city should make ordinances required that this additive MUST be added to every gallon of paint that goes on the outside and inside of every home and especially commercial businesses. SPACE HEATING is about 33% of the average home energy bill...the single biggest expense for energy. Having the insulating additive with interior paint will lock in the heat and will be the single most reduction this expense.
Radiant Heating Panels - One of the most cost effective ways to heat a room without wasting energy warming the air. Eheat seems to have the most efficient and best priced panels. 3 cents per hour to use.
Marathon Hot Water Heater - world's most efficient hot water tank. Have it holding hot water at a certain temp...24 hours later, it only drops 1 degree. Also lifetime warranty...put one in and good for the life of the house. Never needs replacement like the junky metal ones that are so popular. Check out this video on its constructions... very very nice quality.
Geothermal Heat Pumps - one of the most efficient ways to heat or cool a home and it a very conventional technology but outrageously expensive right now. These prices need to come down to affordable levels for average homes.
Staber Washing Machine - the only horizontal axis top loading washing machine made in the states. Uses 67% less water, 50% less energy, 75% less detergent.
Pulstar plugs - not a spark plug...a plasma plug CURRENTLY AVAILABLE but about $25 each. Need these prices to really come down!
Enerpulse is headquartered in Albuquerque, New Mexico. We're a 10-year old company that specializes in developing environmentally friendly ignition products through the application of pulse power technology. With the assistance of Sandia National Laboratories in Albuquerque, we developed Pulstar™ to increase the peak power of the spark by 20,000 times and ignite gasoline in the engine's cylinder more completely, with less cycle-to-cycle variation. The result is more engine torque, more horsepower and better fuel economy. Sandia labs...need I say more? These are the real deal!!! Not as good as Robert Krupa's firestorms, but those aren't available.
Solar Light Tubes need to be used more to bring those prices down too even though they are reasonable...they should almost be a standard piece on a home to reduce lighting costs. They cost a few hundred bucks a piece up to more depending on size.
LED Lighting - this is WAY MORE EFFICIENT than fluorescent bulbs. Not sure how the light quality compares yet for the screw in led bulbs meant to replace incandescents. I've been involved with the led industry for years mostly for healing applications but in the past... a screw in bulb using led's used to cost about $70-$90. Now less than $10. The brightness isn't as much as an incandescent but can be... just matter of time. but they do cost probably about 25 cents per year to use. They aren't practical yet for normal lighting but closets, hallways, etc...
Sunfrost - world's most efficient refrigerator. Some say it is nice some say junky. Either way, these prices need to come down and more fridge makers need to use thicker foam and should paint both sides of it with the insulating paint additive. Keep the heat from moving into the fridge and the compressor will hardly ever have to kick on!
Save Gas - free common sense things anyone can do.
Learn 16 tips on how to maximize fuel economy. PDF
Basically with all the above, bring down prices by boosting volume of use.
