Old 02-17-2010, 05:53 AM
FuzzyTomCat's Avatar
FuzzyTomCat FuzzyTomCat is offline
Silver Member
Send a message via Skype™ to FuzzyTomCat
Redirect from - COP 17 Heater | Rosemary Ainslie | Part 2
http://www.energeticforum.com/84576-post186.html
The model proposes that charge has the property of mass with the material properties of velocities and thermal capacities associated with that mass. These particles do not conform to the standard model and remain hidden within three dimensional solid or liquid objects or amalgams. They are extraneous to the atom itself and only interact with the atomic energy levels that, in turn, comprise independent fields of the same fundamental particle. These extraneous fields are responsible for the bound condition of the amalgam. This interaction between the fields and the atomsí energy levels results in a balanced distribution of charge throughout the amalgam. Measurable voltage reflects a transitional state of imbalance throughout these binding fields that, subject to circuit conditions, then move that charge through available conductive and inductive paths to reestablish a charge balance. In effect the circuit components that enable the flow of charge from a supply source are, themselves able to generate a flow of current depending on the strength of that applied potential difference and the material properties of the circuit components. Therefore both inductive and conductive circuit components have a potential to generate current flow in line with Inductive Laws.
Classical assumption requires an equivalence in the transfer of electric energy based as it is on the concept of a single supply source. Therefore voltage measured away from the supply on circuit components is seen to be stored energy delivered during closed circuit conditions of a switching cycle. The distinction is drawn that if indeed, the circuit components are themselves able to generate a current flow from potential gradients, then under open circuit conditions, that energy may, be added to the sum of the energy on the circuit thereby exceeding the limit of energy available from the supply. Therefore if more energy is measured to be dissipated at a load than is delivered by the supply, then that evidence will be consistent with this thesis. The experimental evidence does indeed, conform to this prediction.
http://www.energeticforum.com/84750-post190.html
It is a little known truth that no-one actually knows what electric current is - let alone how or why it flows. In the same way no-one knows what causes gravity. These both, together with the strong and weak nuclear forces, are lumped together - very broadly, under the term 'forces'. And a force is known to be that something that can be used to give energy. But here's the thing. Nor does anyone actually know what energy is. You get whole divisions within universities dedicated to the study of clean energy, reusable energy, reticulated, recycled, economic, efficient, green - all in depth discussions and all about energy. Yet not one of these academic experts actually knows what energy is - the thing itself. Ask them and they will waffle on about 'change' or they will point to measurements that boggle the mind with their predictable accuracies. But energy? The thing that flows, that lights your light, that heats your stove, that gives you the will to learn, walk, wake up in the mornings, that thing? No-one actually knows what it is. All we know today is roughly where to find it, and exactly how to exploit it.
http://www.energeticforum.com/84755-post191.html
That having been said - also by the same token - those same expert academics also know an exhaustive amount about the measurement of that energy. And that measurement is so skilled that they can predict the outcome of a physical or chemical effect to extraordinary levels of accuracy. It is this knowledge that has led us into this technological revolution that allows us, among many other benefits, the use of our computers, our cars and the general conveniences of modern day life. I do not mean to diminish the vast wealth of knowledge available to us courtesy these experts. And they, in turn, have archived the excellent pioneering efforts of those Giants in physics who first pioneered this knowledge. All this work is a treasure of information and is an enduring and proud heritage of our civilisation. It has taken us from the confused presumptions of the dark ages to the clear light of science based, as it now is, on experimental evidence as proof of a thesis or theory.
http://www.energeticforum.com/84765-post192.html
All I am pointing to is the fact that physics today still has outstanding questions. And while these questions are really big questions, they all relate to our inability to actually see anything on a really minute scale. This includes everything on the scale of an atom and smaller. Beyond a certain size and at a certain given velocity our knowledge of anything is limited to that knowledge that can only be gained through inference. We have photographed electrons but know nothing of their structure. I have actually seen a photograph of the shadowy structure of atoms. An extraordinary feat in photography. But it simply looks like a nest of eggs laid out and cooling in something that also looks like a clinging morning mist. The atom's motor, its actual structure, remains hidden inside its shell. What little we know about particles is their charge or the 'direction' they take within a magnetic field and some extraordinary details related to the 'spin' of that particle when it can be held, tenuously suspended, away from it's natural environment. Scientists work with 'clues' and patterns of behaviour to gain an increasing understanding of the thing itself. And this art of inference has - notwithstanding these difficulties, enabled an extraordinary feat. We have the periodic table as tribute to the rarefied progressive logic that unravelled the atom's secrets. This and the fact that we know of a great many particles, an entire particle zoo as some call it, is all by virtue of the courtesy and the skills of expert knowledge, expert observation and expert assessment. Our progress in science is an enduring tribute to the skills of our mainstream scientists and their remarkably incisive logic. But yet our knowledge is limited, constrained as it is in any study of the very, very small.
http://www.energeticforum.com/84814-post200.html
Which all brings this subject back to the mysteries of current flow. Electromagnetism was actually discovered by Orsted in 1821. Faraday was intrigued with the phenomenon but was only able to devote time to this at the death of his mentor Davy, in 1831. He was able to show that a changing electric field induced a magnetic field and, correspondingly, a changing magnetic field would induce an electric field. Faraday was unschooled or self taught so it was left to Maxwell thereafter to do the mathematical modelling of this. The result was the formulation of the Laws of Induction. But while this has been well modelled and extensively used there is very little said on the phenomenon of a magnet on magnet interaction. Given the right proximity two magnets will move apart or together with some considerable force but without necessarily inducing a corresponding electric field. There is no clear evidence that an an electric field is either required or extant. And if an electric field is in fact absent in a magnet on magnet interaction, yet an electric field cannot manifest without a magnetic field, then the implications are profound. It points to the possibility that a magnetic force is somehow a primary force, compared to which an electromagnetic force is merely a secondary field effect. This thesis proposes that indeed the magnetic force is a primary force which is also the model's first departure from classical or mainstream thinking.
http://www.energeticforum.com/84831-post201.html
The actual intention of this field model was to explore the possibility of there being a single elementary force. Was there something - one simple principle - that somehow governed all the forces - something that could account for the nuclear forces, for the electromagnetic interactions and for the effects of gravity? The possibility that this could be found was and is seductive. It would point to the real possibility that energy itself could be uncovered and that this, in turn would reveal some underlying principle that governed all the forces. And a magnetic force was an ideal candidate precisely because it had been so entirely overlooked. It is a field that is widely used, but little understood, well known in general but mysterious in its particular. What was needed were some tools of logic, whereby the properties of magnetism would be 'inferred' very much in the same way that our mainstream scientists had 'inferred' so much about the properties of atoms and particles. Mainstream, however, had the advantage of dealing with what is measurable and evidential. What was now needed was to unravel the properties of something that remained hidden from view - something invisible - something possibly on a scale of 'small' that even exceeded the miniscule and intangible properties of the atom itself.
http://www.energeticforum.com/84903-post205.html
Just as an overview - I've covered the fact that there is very little known about the properties of charge or current flow. What is known is 'inferred' knowledge as the actual material of electric current flow remains as 'hidden' today as it was in the times of Faraday. But nor is there any question as to the comprehensive nature of what is actually known about the electromagnetic interaction. The use of this force is, self-evidently, the single most incontrovertibly well understood and well used of all the forces. It has taken us to the moon, to Mars and even beyond our own solar system. It has also enabled the tools of mass communication that has engendered a kind of 'latter day' Tower of Babel. And the tower is high, so high that it stretches beyond our stratosphere and into the delicately exquisite instrumentation in our orbiting satellites. But there is an outstanding question as to whether we are dealing with a secondary force or a primary force. The proposal here is that a magnet on magnet interaction does not invariably induce an electric field. Yet an electric field cannot manifest without a corresponding magnetic field. Perhaps therefore the magnetic field is a primary force. And if so, then - being as it is hidden from view, how can we better extend our knowledge of this force. What tools can be used to expose hidden properties in the field that can be inferred to be consistent with its evident and manifold effects?
