Old 02-15-2010, 04:34 PM
witsend witsend is offline
Gold Member
And as suggested in the previous paragraph, this is related to the effect of an orbiting field and the relationship of each particle in the field. In effect it describes a symmetry that is really jolly profound. The particles would all be moving in one direction or with a single justification. This justification relates to the charge of the field. Always forwards, never backwards, always right to left or left to right. Never does it move in two directions - else there would not be the clear distinction between the north and south poles of a permanent magnet and these two properties are always perfectly defined.
But the orbit itself holds a paradox. There is that within an orbit that suggests perfect neutrality. If one drew a line through the centre of an orbiting magnetic field - anywhere at all - and provided it always goes through the centre of the field, then one half on the orbit would precisely oppose the other half. If one half goes forwards the other half goes backwards. If the one half is moving to the left the other is moving to the right. This suggests that the field is neutral but the justification of each magnetic dipole also presupposes a 'charge' property - or a single direction in space. So any magnetic field would also have a perfect charge distribution and that would render the field neutral. But its particles, assuming they comprise the field, would in fact be charged. Each part of the field is therefore charged. Yet the entire field is also entirely neutral.
