Old 02-09-2010, 04:59 AM
witsend witsend is offline
Gold Member
Guys - Another attempt to getting this on topic. This is in the introduction to the paper that I tried to get onto Scribd. It goes to the 'difference' between classical and this model. I'll explain it more fully this evening.
The model proposes that charge has the property of mass with the material properties of velocities and thermal capacities associated with that mass. These particles do not conform to the standard model and remain hidden within three dimensional solid or liquid objects or amalgams. They are extraneous to the atom itself and only interact with the atomic energy levels that, in turn, comprise independent fields of the same fundamental particle. These extraneous fields are responsible for the bound condition of the amalgam. This interaction between the fields and the atomsí energy levels results in a balanced distribution of charge throughout the amalgam. Measurable voltage reflects a transitional state of imbalance throughout these binding fields that, subject to circuit conditions, then move that charge through available conductive and inductive paths to reestablish a charge balance. In effect the circuit components that enable the flow of charge from a supply source are, themselves able to generate a flow of current depending on the strength of that applied potential difference and the material properties of the circuit components. Therefore both inductive and conductive circuit components have a potential to generate current flow in line with Inductive Laws.
Classical assumption requires an equivalence in the transfer of electric energy based as it is on the concept of a single supply source. Therefore voltage measured away from the supply on circuit components is seen to be stored energy delivered during closed circuit conditions of a switching cycle. The distinction is drawn that if indeed, the circuit components are themselves able to generate a current flow from potential gradients, then under open circuit conditions, that energy may, be added to the sum of the energy on the circuit thereby exceeding the limit of energy available from the supply. Therefore if more energy is measured to be dissipated at a load than is delivered by the supply, then that evidence will be consistent with this thesis. The experimental evidence does indeed, conform to this prediction.
