  #6 (permalink)
Old 09-08-2007, 09:51 PM
Ewhaz Ewhaz is offline
Member
Cecium Carbonate
There is also testimonials about the use of Cesium Carbonate as well, this being an alkalizing agent used to raise the body's PH to levels where the cancer begins to die off.
There isn't just one useful cure for cancer, there are thousands, literally. And on top of that they are all relatively safe and very effective. There is no reason what so ever to attempt chemotherapy at all. Do your research and share it with your family, make the best decision about what path to follow. Good luck on your quest!
Links:
Cancer cells stopped quickly and safely with Cesium using pH Therapy
Cecium Carbonate and Cesium Cloride kills Cancer Cells
You may also just want them to begin taking vitamins, especialy calcium and vit D, Magnesium, zinc, Vit C,
Calcium helps alkalize the body as well. Magnesium and Zinc and the Vit D all help your body metabolize the Calcium properly.
Magnesium and Vit C help boost the Immune system. Both are usualy depleted by the body as they easily pass through it. Taking Large doses of vitamin C (up to 10 to 20 grams a day, divided into batches of up to 5 grams each or up to bowel tolerance (it acts as a laxative in large doses, tolerance is usually from 3 grams and up) so test this and read up on mega dosing on C before doing it) Magnesium, some studies suggest, Increases the effectiveness of the immune system and help double its effectiveness. This is a hard element to build up any kind of useful saturation in the tissues. Best way to do this is to take baths in Epsom salts or an equivalent. There are some metallic bath salts out there that will do a better job of absorbing through the skin and raising Magnesium levels.
This is just some of the information I know, there is a lot more out there concerning this, its called orthomolecular molecular medicine. The basic premise is that the body can heal it self, if given the proper nutrients to do it. Again, this is just one of MANY ways to cure cancer (and a host of other diseases), but the more information you have the better you'll be able to act considering the nature of your situation.
(To the mods, Sorry for being very off topic here, but considering the situation, I thought it best.)
