  #14 (permalink)
Old 09-03-2007, 02:22 AM
jerdee jerdee is offline
Junior Member
Originally Posted by Mario View Post
I've just tried that little bifilar experiment as shown in the link but I get the exact same field strenght on both coils, driving at the same voltage and current.
Have you tried it? I also did a quick test on the Bedini SS, I had two power strands on one transistor, so I tried connecting the top (end) of one strand to the bottom of the other one, basically if they were parallel in the beginning now they were in series. I got a much higher voltage but the freq was way lower. But the charging rate was the same for both the setups.
Mario
I just did the same experiment this afternoon. I used one strand and two in series for blocking oscillation…along with two in series for power strands. In both cases, the oscillation was slower. This is not the best way to configure multicoils for the SS.
What’s interesting …is the aligned fields of the Bifilar w/ wfc load in between creates a larger compressed potential of the LEM wave. When cathode is properly insulated or conditioned this should further the compressed potential LEM wave. This will cause a larger imbalance allowing the vacuum to interact freely. I have a strong feeling that the Lawton circuit should use a Bifilar or more coils instead of two independent inductors. I may be wrong. But from what I gather from Aaron’s experiment, the field must be aligned. The D12.pdf does not show this! Also, the Lawton circuit does not pick off the electrons furthering the imbalanced high-energy state of the atomic atom. We are only seeing on half of the picture here.
