  #3 (permalink)
Old 12-07-2009, 07:40 AM
boguslaw's Avatar
boguslaw boguslaw is offline
Senior Member
Originally Posted by Ted Ewert View Post
Hi Ben,
I like your circuits. You may want to try a Sidac in the gate circuit of you cap pulser. I used one that way and it worked great. If you don't know what they are, here's a general description:
The sidac is a silicon bilateral voltage triggered switch with
greater power-handling capabilities than standard diacs. Upon
application of a voltage exceeding the sidac breakover voltage
point, the sidac switches on through a negative resistance region
to a low on-state voltage. Conduction continues until the current
is interrupted or drops below the minimum holding current of the
device.
These are really handy little devices. They only cost about $.50 each and come in a variety of voltages. Much better than a zener in this type of application.
Littlefuse makes them and you can find them at Mousers.
Ted
Can you compare it with transil ? Transient voltage suppression diode - Wikipedia, the free encyclopedia
What is better ? How much power can SIDAC conduct ?
