  #38 (permalink)
Old 08-28-2007, 04:35 AM
amigo amigo is offline
Senior Member
Originally Posted by adam ant View Post
hey amigo, your setup looks really good. i havnt yet started to build this stuff yet, im still gathering data, and resources before i begin.
with having a coil situated only on one side of your rotor, do you experience an unbalanced rotation? by that i mean is there unequal stress(on your bearings) on one side due to the electromagnetic "pressure" from your coil?
thanks-
bryan
Hi Bryan
I think fabrication in home environment to begin with is a nightmare. I live in a high-rise apartment building so you can imagine a limited amount of woodwork and metalwork one can do.
Now, my rotor appears unbalanced as it is, when I was gluing plastic discs together I think I put too much glue in a layer on one side. Then, because I mounted two bearings on the sides of the rotor and did not have a proper mounting points the whole thing seems to be off axis slightly (heck I'm lucky it spins without too much wobble).
I do not have means to measure any stress except to visually discern that there is some drag happening. I think the better setup is the roller skate wheel one where gravity aids the process.
I suggest you start somewhere, see what kind of materials you can gather and build your first prototype. Finding the right parts sometimes proves to be a real pain - not everyone has a machine shop available to them. Besides, your SSG can't look worse than my first one
From there you will realize mistakes and correct them on your own pretty fast. I was amazed myself with ideas I came up to fix things after the first trial run, even though I had to scourge for parts and come up with all kinds of ways to supplement the lack of real machined components.
