  #9 (permalink)
Old 08-27-2007, 08:56 PM
nali2001 nali2001 is offline
Member
Thank you Peter, John and Aaron for making the document public.
Is Eike Mueller still with us? I mean it would be interesting to have him comment on this as well?
Hopefully people will do the experiments. It is not really that hard to build a simple proof of concept relay based switching system. And it would allow for energy ‘recycling’ at the very least. And so provide a way to get better battery efficiency for virtually every application.
I mean you could use it to run a 90% efficient motor and recharge the second battery even if it is only a little, which would normally be send back to the same battery to destroy the dipole. (Correct me if I don’t make sense) So with this ‘recycling’ you can make nearly every motor into an o.u device when you look at the total energy balance. Although I must say that some things like radiated heat and back emf are tricky to include. I mean is radiated head from a bulb ‘lost’ or not? Wouldn’t that mean that a 100% efficient heating element will not put a charge into the second battery at all?
I always find it amazing that such ‘simple’ devices are kind of ‘unheard of’ and untouched by next to all researchers.
Hopefully this information will spark some interest and research again (after like 20+ years?)
Again thanks for the info!
It is much appreciated!
Kind regards
Steven
