Old 11-14-2009, 08:29 AM
FuzzyTomCat's Avatar
FuzzyTomCat FuzzyTomCat is offline
Silver Member
Send a message via Skype™ to FuzzyTomCat
TEST #9 - New Shunt & Re-test of TEST #8
Hi Everyone,
Here is Test #9 with the new shunt a 0.25 Ohm resistor from "Caddock" High Performance Film Resistor, "non-inductive" 30 Watt, type MP930-0.25-1%, this is a re-test of TEST #8
*The TDS 3054C oscilloscope probes are a type Tektronix P6139A with the standard 6" grounding leads.
Channel 1 - Mosfet source shunt
Channel 2 - Mosfet drain
Channel 3 - 555 Timer pin #3
Channel 4 - 24 VDC "Liquid" Lead Acid Battery Bank
Channel-3_555_SNAPSHOT
( 555 Image Readings Taken Prior to 24 Volt Battery Connection )
40us_11-13-09
40us_11-13-09.png Image
40us_11-13-09.CSV Spread Sheet File
20us_11-13-09
20us_11-13-09.png Image
20us_11-13-09.CSV Spread Sheet File
2us_11-13-09
2us_11-13-09.png Image
2us_11-13-09.CSV Spread Sheet File
1us_11-13-09
1us_11-13-09.png Image
1us_11-13-09.CSV Spread Sheet File
100ns_11-13-09
100ns_11-13-09.png Image
100ns_11-13-09.CSV Spread Sheet File
This is a test using only two oscilloscope probes with one probe tip on Channel-1 between the Mosfet and Shunt and Channel-2 between the Shunt and the Battery Negative (B-) terminal.
Both probe grounds Channel-1 and Channel-2 connected to a separate isolated AC ground point "NOT" to the battery negative (B-) terminal
Channel 1 - Mosfet Source to Shunt
Channel 2 - Shunt to Battery Negative
Channel 3 - 555 Timer Pin #3
(no probe connection - reference only)
MOSFET_SHUNT_BAT_N_555_11-13-09
MOSFET_SHUNT_BAT_N_555_11-13-09.png Image
MOSFET_SHUNT_BAT-N_555_11-13-09.CSV Spread Sheet File
All Images and data by a Tektronix TDS 3054C from the Tektronix Corporation
Glen
Last edited by FuzzyTomCat; 11-14-2009 at 07:24 PM. Reason: added 555 timer snapshot info - 100ns mismark - added scope probe info
