  #15 (permalink)
Old 08-27-2007, 02:45 AM
amigo amigo is offline
Senior Member
Originally Posted by Peter Lindemann View Post
Amigo,
The simplest circuit to use is based on the solid-state oscillator found on page 46 of Bearden's book Free Energy Generation. The trigger winding is connected to the transistor base with a 2k resistor, and the base is connected to the Emitter with a 10K resistor and to the collector with an 18K resistor. This arrangement sets the TRANSISTOR into oscillation. This is what John called his "self-oscillating" circuit. Not all transistors will oscillate this way, but some will. The BD234C is one that works. A single diode off the second winding (like the Simplified School Girl circuit) goes to the positive silver electrode and the negative silver electrode is connected to the top of the coil. The third coil and everything else can be eliminated.
This circuit makes excellent, small particle colloidal silver.
Peter
Hi Peter,
I do not have that book yet, would it be possible for you to post the circuit here instead? Does that circuit still need moving parts (motor assembly with magnets)?
Thanks again.
